AW: AW: [PATCH 07/12] kern_tc.c: Remove verification of th_generation for pps functions
Sebastian Huber
Fri Apr 8 05:55:53 UTC 2022
On 07/04/2022 15:16, Sebastian Huber wrote:
> On 07/04/2022 15:10, Gabriel.Moyano at dlr.de wrote:
>>> Which sequence of function calls and timings cases the problem? This
>>> should be definitely a test case.
>> The generation is updated every time tc_windup() is called. So it is
>> more or less a race condition when it happens.
> This is not a race condition. The sequence counter is supposed to ensure
> a consistent state. You can't simply remove this.
> Maybe the PPS support requires that we use two timehands even for the
> uniprocessor configuration. For this, we have to understand under which
> conditions and use cases the generation change is an issue.
In kern_tc.c there is this comment, which is a result from a discussion
on a FreeBSD mailing list:
* In FreeBSD, the timehands count is a tuning option from two to 16. The
* tuning option was added since it is inexpensive and some FreeBSD
users asked
* for it to play around. The default value is two. One system which
did not
* work with two timehands was a system with one processor and a
specific PPS
* device.
* For RTEMS, in uniprocessor configurations, just use one timehand
since the
* update is done with interrupt disabled.
* In SMP configurations, use a fixed set of two timehands until someone
* reports an issue.
We definitely need a test case for this corner case. Adding a second
timehand has a size impact. On a 32-bit machine there is sizeof(struct
timehands) == 120.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
