AW: AW: AW: [PATCH 07/12] kern_tc.c: Remove verification of th_generation for pps functions
Gabriel.Moyano at dlr.de
Wed Apr 27 13:13:03 UTC 2022
> On 07/04/2022 15:16, Sebastian Huber wrote:
> > On 07/04/2022 15:10, Gabriel.Moyano at dlr.de wrote:
> >>> Which sequence of function calls and timings cases the problem? This
> >>> should be definitely a test case.
> >> The generation is updated every time tc_windup() is called. So it is
> >> more or less a race condition when it happens.
> > This is not a race condition. The sequence counter is supposed to
> > ensure a consistent state. You can't simply remove this.
> > Maybe the PPS support requires that we use two timehands even for the
> > uniprocessor configuration. For this, we have to understand under
> > which conditions and use cases the generation change is an issue.
> In kern_tc.c there is this comment, which is a result from a discussion on a FreeBSD mailing list:
> * In FreeBSD, the timehands count is a tuning option from two to 16. The
> * tuning option was added since it is inexpensive and some FreeBSD users asked
> * for it to play around. The default value is two. One system which did not
> * work with two timehands was a system with one processor and a specific PPS
> * device.
> * For RTEMS, in uniprocessor configurations, just use one timehand since the
> * update is done with interrupt disabled.
> * In SMP configurations, use a fixed set of two timehands until someone
> * reports an issue.
> We definitely need a test case for this corner case. Adding a second timehand has a size impact. On a 32-bit machine there is
> sizeof(struct
> timehands) == 120.
What do you think about something in the middle between adding a second timehand and not adding it at all for non-SMP configurations?
Let me explain better the idea; the pps_event() uses only 3 variables of the object timehand: th_offsetcount, th_bintime and th_scale. The values of them could be saved instruct pps_state during pps_capture(). This will only happen in case of non-SMP configurations. Then, the verifications need to be adapted for SMP or for non-SMP, e.g. the th_generation will be checked at the end of pps_capture() for both configurations but only for SMP in pps_event().
