AW: AW: AW: AW: [PATCH 11/12] kern_ntptime: Add define in order to remove warning
Sebastian Huber
Fri Apr 8 06:35:55 UTC 2022
On 08/04/2022 08:28, Gabriel.Moyano at dlr.de wrote:
>>>> PPS device drivers should use the kernel space API. Since we don't
>>>> have a user and kernel space in RTEMS, the kerne space API should be available also if __rtems__ is defined.
>>> So, you mean to remove the #ifdef _KERNEL using #ifndef__rtems__.
>> It is an
>> #ifdef _KERNEL
>> #else /* !_KERNEL */
>> #endif /* KERNEL */
>> In RTEMS we need both APIs, one for PPS drivers and the other for applications.
>> If we don't want to change the header, then PPS drivers have to do something like this:
>> #define _KERNEL
>> #include <sys/timepps.h>
> Yes, that's why added the #define _KERNEL in kern_ntptime.c.
> What it is your suggestion here?
We have currently no API which needs a _KERNEL define. Maybe we should
postpone the decision and keep the need for _KERNEL define at this point
in time.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
