AW: AW: AW: AW: AW: [PATCH 11/12] kern_ntptime: Add define in order to remove warning
Gabriel.Moyano at dlr.de
Wed Apr 27 14:00:01 UTC 2022
> On 08/04/2022 08:28, Gabriel.Moyano at dlr.de wrote:
> >>>> PPS device drivers should use the kernel space API. Since we don't
> >>>> have a user and kernel space in RTEMS, the kerne space API should be available also if __rtems__ is defined.
> >>> So, you mean to remove the #ifdef _KERNEL using #ifndef__rtems__.
> >> It is an
> >> #ifdef _KERNEL
> >> #else /* !_KERNEL */
> >> #endif /* KERNEL */
> >> In RTEMS we need both APIs, one for PPS drivers and the other for applications.
> >> If we don't want to change the header, then PPS drivers have to do something like this:
> >> #define _KERNEL
> >> #include <sys/timepps.h>
> > Yes, that's why added the #define _KERNEL in kern_ntptime.c.
> > What it is your suggestion here?
> We have currently no API which needs a _KERNEL define. Maybe we should postpone the decision and keep the need for _KERNEL
> define at this point in time.
Is it possible to comment them out with /* */? Because adding the #define _KERNEL and #include <sys/timepps.h> could generate some issues while compiling and this depends on the position where the header was included
