[PATCH 01/39] testsuites/ada/support/*: Change license to BSD-2
Fri Apr 8 14:45:29 UTC 2022
Updates #3053.
 testsuites/ada/support/address_io.adb         | 25 ++++++++++++++++---
 testsuites/ada/support/address_io.ads         | 25 ++++++++++++++++---
 testsuites/ada/support/float_io.ads           | 25 ++++++++++++++++---
 testsuites/ada/support/fp.inc                 | 25 ++++++++++++++++---
 testsuites/ada/support/integer.inc            | 25 ++++++++++++++++---
 .../ada/support/rtems_calling_overhead.ads    | 25 ++++++++++++++++---
 testsuites/ada/support/status_io.ads          | 25 ++++++++++++++++---
 testsuites/ada/support/test_support.adb       | 25 ++++++++++++++++---
 testsuites/ada/support/test_support.ads       | 25 ++++++++++++++++---
 testsuites/ada/support/time_test_support.adb  | 25 ++++++++++++++++---
 testsuites/ada/support/time_test_support.ads  | 25 ++++++++++++++++---
 testsuites/ada/support/timer_driver.adb       | 25 ++++++++++++++++---
 testsuites/ada/support/timer_driver.ads       | 25 ++++++++++++++++---
 testsuites/ada/support/unsigned32_io.ads      | 25 ++++++++++++++++---
 14 files changed, 308 insertions(+), 42 deletions(-)
diff --git a/testsuites/ada/support/address_io.adb b/testsuites/ada/support/address_io.adb
index f549f57ffe..1c09e95496 100644
--- a/testsuites/ada/support/address_io.adb
+++ b/testsuites/ada/support/address_io.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
 --  Address_IO / Specification
@@ -13,9 +15,26 @@
 --  COPYRIGHT (c) 1989-2009.
 --  On-Line Applications Research Corporation (OAR).
---  The license and distribution terms for this file may in
---  the file LICENSE in this distribution or at
---  http://www.rtems.org/license/LICENSE.
+--  Redistribution and use in source and binary forms, with or without
+--  modification, are permitted provided that the following conditions
+--  are met:
+--  1. Redistributions of source code must retain the above copyright
+--     notice, this list of conditions and the following disclaimer.
+--  2. Redistributions in binary form must reproduce the above copyright
+--     notice, this list of conditions and the following disclaimer in the
+--     documentation and/or other materials provided with the distribution.
+--  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+--  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+--  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+--  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+--  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+--  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+--  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+--  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+--  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+--  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+--  POSSIBILITY OF SUCH DAMAGE.
 with System.Storage_Elements;
diff --git a/testsuites/ada/support/address_io.ads b/testsuites/ada/support/address_io.ads
index 8a4fce98d3..03dc0d1955 100644
--- a/testsuites/ada/support/address_io.ads
+++ b/testsuites/ada/support/address_io.ads
@@ -1,3 +1,5 @@
 --  ADDRESS_IO / SPECIFICATION
@@ -13,9 +15,26 @@
 --  COPYRIGHT (c) 1989-1997.
+--  are met:
 with System;
diff --git a/testsuites/ada/support/float_io.ads b/testsuites/ada/support/float_io.ads
index 5e1a90bf92..c052dca1ba 100644
--- a/testsuites/ada/support/float_io.ads
+++ b/testsuites/ada/support/float_io.ads
@@ -1,3 +1,5 @@
 --  Float_IO / Specification
@@ -13,9 +15,26 @@
+--  are met:
 with Text_IO;
diff --git a/testsuites/ada/support/fp.inc b/testsuites/ada/support/fp.inc
index eb6f5528a9..108265fa94 100644
--- a/testsuites/ada/support/fp.inc
+++ b/testsuites/ada/support/fp.inc
@@ -1,3 +1,5 @@
 --  fp.inc
@@ -15,9 +17,26 @@
+--  are met:
 -- private definitions for macro use
diff --git a/testsuites/ada/support/integer.inc b/testsuites/ada/support/integer.inc
index c47f68efd4..80d1aba695 100644
--- a/testsuites/ada/support/integer.inc
+++ b/testsuites/ada/support/integer.inc
@@ -1,3 +1,5 @@
 --  integer.inc
@@ -9,9 +11,26 @@
+--  are met:
diff --git a/testsuites/ada/support/rtems_calling_overhead.ads b/testsuites/ada/support/rtems_calling_overhead.ads
index 5f94e0505a..93180b61a8 100644
--- a/testsuites/ada/support/rtems_calling_overhead.ads
+++ b/testsuites/ada/support/rtems_calling_overhead.ads
@@ -1,3 +1,5 @@
 --  RTEMS_CALLING_OVERHEAD / SPECIFICATION
@@ -15,9 +17,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/support/status_io.ads b/testsuites/ada/support/status_io.ads
index 301e7a2ba1..882b09a1dc 100644
--- a/testsuites/ada/support/status_io.ads
+++ b/testsuites/ada/support/status_io.ads
@@ -1,3 +1,5 @@
 --  Status_IO / Specification
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/support/test_support.adb b/testsuites/ada/support/test_support.adb
index 6a46b427ce..661d30a896 100644
--- a/testsuites/ada/support/test_support.adb
+++ b/testsuites/ada/support/test_support.adb
@@ -1,3 +1,5 @@
 --  Test_Support / Specification
@@ -13,9 +15,26 @@
 --  COPYRIGHT (c) 1989-2011.
+--  are met:
 with Interfaces; use Interfaces;
diff --git a/testsuites/ada/support/test_support.ads b/testsuites/ada/support/test_support.ads
index a15574782e..a6a2c5a460 100644
--- a/testsuites/ada/support/test_support.ads
+++ b/testsuites/ada/support/test_support.ads
@@ -1,3 +1,5 @@
 --  Test_Support / SPECIFICATION
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/support/time_test_support.adb b/testsuites/ada/support/time_test_support.adb
index aab0c75dfe..8bc0daf756 100644
--- a/testsuites/ada/support/time_test_support.adb
+++ b/testsuites/ada/support/time_test_support.adb
@@ -1,3 +1,5 @@
 --  TIME_TEST_SUPPORT / SPECIFICATION
@@ -13,9 +15,26 @@
+--  are met:
 with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/support/time_test_support.ads b/testsuites/ada/support/time_test_support.ads
index aeed677ba2..482238c3ca 100644
--- a/testsuites/ada/support/time_test_support.ads
+++ b/testsuites/ada/support/time_test_support.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/support/timer_driver.adb b/testsuites/ada/support/timer_driver.adb
index 389499ccc8..eff958a5c7 100644
--- a/testsuites/ada/support/timer_driver.adb
+++ b/testsuites/ada/support/timer_driver.adb
@@ -1,3 +1,5 @@
 --  Timer_Driver / Body
@@ -12,9 +14,26 @@
+--  are met:
 with Interfaces;
diff --git a/testsuites/ada/support/timer_driver.ads b/testsuites/ada/support/timer_driver.ads
index 00642dfe90..6919fcfeb7 100644
--- a/testsuites/ada/support/timer_driver.ads
+++ b/testsuites/ada/support/timer_driver.ads
@@ -1,3 +1,5 @@
 --  Timer_Driver / Specification
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/support/unsigned32_io.ads b/testsuites/ada/support/unsigned32_io.ads
index 4d1a7e6e87..63f267a8a8 100644
--- a/testsuites/ada/support/unsigned32_io.ads
+++ b/testsuites/ada/support/unsigned32_io.ads
@@ -1,3 +1,5 @@
 --  Unsigned32_IO / Specification
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
2.24.4
