[PATCH 02/39] testsuites/ada/samples/*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:30 UTC 2022
Updates #3053.
testsuites/ada/samples/base_mp/init.c | 25 +++++++++++++++++++---
testsuites/ada/samples/base_mp/mptest.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/base_mp/mptest.ads | 25 +++++++++++++++++++---
testsuites/ada/samples/base_sp/base_sp.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/base_sp/init.c | 25 +++++++++++++++++++---
testsuites/ada/samples/base_sp/sptest.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/base_sp/sptest.ads | 25 +++++++++++++++++++---
testsuites/ada/samples/hello/hello.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/hello/init.c | 25 +++++++++++++++++++---
testsuites/ada/samples/hello/sptest.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/hello/sptest.ads | 25 +++++++++++++++++++---
testsuites/ada/samples/nsecs/init.c | 25 +++++++++++++++++++---
testsuites/ada/samples/nsecs/nsecs.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/nsecs/sptest.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/nsecs/sptest.ads | 25 +++++++++++++++++++---
testsuites/ada/samples/ticker/init.c | 25 +++++++++++++++++++---
testsuites/ada/samples/ticker/sptest.adb | 25 +++++++++++++++++++---
testsuites/ada/samples/ticker/sptest.ads | 25 +++++++++++++++++++---
testsuites/ada/samples/ticker/ticker.adb | 25 +++++++++++++++++++---
19 files changed, 418 insertions(+), 57 deletions(-)
diff --git a/testsuites/ada/samples/base_mp/init.c b/testsuites/ada/samples/base_mp/init.c
index 78a357bd7e..bd955d0500 100644
--- a/testsuites/ada/samples/base_mp/init.c
+++ b/testsuites/ada/samples/base_mp/init.c
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
/* configuration information */
diff --git a/testsuites/ada/samples/base_mp/mptest.adb b/testsuites/ada/samples/base_mp/mptest.adb
index 95e7901d4b..cd1aa42a5b 100644
--- a/testsuites/ada/samples/base_mp/mptest.adb
+++ b/testsuites/ada/samples/base_mp/mptest.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- MPTEST / BODY
@@ -13,9 +15,26 @@
-- COPYRIGHT (c) 1989-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/samples/base_mp/mptest.ads b/testsuites/ada/samples/base_mp/mptest.ads
index f246b4e0ed..c30c5e5520 100644
--- a/testsuites/ada/samples/base_mp/mptest.ads
+++ b/testsuites/ada/samples/base_mp/mptest.ads
@@ -1,3 +1,5 @@
-- MPTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/base_sp/base_sp.adb b/testsuites/ada/samples/base_sp/base_sp.adb
index aaa1ab3bca..0a8d44e267 100644
--- a/testsuites/ada/samples/base_sp/base_sp.adb
+++ b/testsuites/ada/samples/base_sp/base_sp.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/base_sp/init.c b/testsuites/ada/samples/base_sp/init.c
index 1ad2d67207..a30ef29428 100644
--- a/testsuites/ada/samples/base_sp/init.c
+++ b/testsuites/ada/samples/base_sp/init.c
@@ -1,3 +1,5 @@
/* config.h
* This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-2007.
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
+ * are met:
diff --git a/testsuites/ada/samples/base_sp/sptest.adb b/testsuites/ada/samples/base_sp/sptest.adb
index 75a472e8d9..1f532d369c 100644
--- a/testsuites/ada/samples/base_sp/sptest.adb
+++ b/testsuites/ada/samples/base_sp/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with TEST_SUPPORT;
diff --git a/testsuites/ada/samples/base_sp/sptest.ads b/testsuites/ada/samples/base_sp/sptest.ads
index e35751cd32..e2de7585da 100644
--- a/testsuites/ada/samples/base_sp/sptest.ads
+++ b/testsuites/ada/samples/base_sp/sptest.ads
@@ -1,3 +1,5 @@
-- SPTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/hello/hello.adb b/testsuites/ada/samples/hello/hello.adb
index f7748f3607..ffb3204930 100644
--- a/testsuites/ada/samples/hello/hello.adb
+++ b/testsuites/ada/samples/hello/hello.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/hello/init.c b/testsuites/ada/samples/hello/init.c
index f7c3f4f65a..aaa261d75a 100644
--- a/testsuites/ada/samples/hello/init.c
+++ b/testsuites/ada/samples/hello/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/testsuites/ada/samples/hello/sptest.adb b/testsuites/ada/samples/hello/sptest.adb
index a0bb90a19e..feac6e45b8 100644
--- a/testsuites/ada/samples/hello/sptest.adb
+++ b/testsuites/ada/samples/hello/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with TEXT_IO;
diff --git a/testsuites/ada/samples/hello/sptest.ads b/testsuites/ada/samples/hello/sptest.ads
index 62993b0220..129f67b26d 100644
--- a/testsuites/ada/samples/hello/sptest.ads
+++ b/testsuites/ada/samples/hello/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/nsecs/init.c b/testsuites/ada/samples/nsecs/init.c
index 3935e10dcc..a069f5b7c8 100644
--- a/testsuites/ada/samples/nsecs/init.c
+++ b/testsuites/ada/samples/nsecs/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/samples/nsecs/nsecs.adb b/testsuites/ada/samples/nsecs/nsecs.adb
index 0a8f84a606..095d375e6f 100644
--- a/testsuites/ada/samples/nsecs/nsecs.adb
+++ b/testsuites/ada/samples/nsecs/nsecs.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/nsecs/sptest.adb b/testsuites/ada/samples/nsecs/sptest.adb
index 9befa62c9e..25c1104b46 100644
--- a/testsuites/ada/samples/nsecs/sptest.adb
+++ b/testsuites/ada/samples/nsecs/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with Ada.Integer_Text_IO;
diff --git a/testsuites/ada/samples/nsecs/sptest.ads b/testsuites/ada/samples/nsecs/sptest.ads
index 97fa00ac2c..9e318e7e14 100644
--- a/testsuites/ada/samples/nsecs/sptest.ads
+++ b/testsuites/ada/samples/nsecs/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/ticker/init.c b/testsuites/ada/samples/ticker/init.c
index e6f82f2601..6019432df1 100644
--- a/testsuites/ada/samples/ticker/init.c
+++ b/testsuites/ada/samples/ticker/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/samples/ticker/sptest.adb b/testsuites/ada/samples/ticker/sptest.adb
index 03f2b1b390..48b0296f9c 100644
--- a/testsuites/ada/samples/ticker/sptest.adb
+++ b/testsuites/ada/samples/ticker/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/samples/ticker/sptest.ads b/testsuites/ada/samples/ticker/sptest.ads
index 8753d3edad..637c475c20 100644
--- a/testsuites/ada/samples/ticker/sptest.ads
+++ b/testsuites/ada/samples/ticker/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/samples/ticker/ticker.adb b/testsuites/ada/samples/ticker/ticker.adb
index 08a1fb9e31..8cd218f5ac 100644
--- a/testsuites/ada/samples/ticker/ticker.adb
+++ b/testsuites/ada/samples/ticker/ticker.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
2.24.4
