[PATCH 03/39] testsuites/ada/sptests/sp0*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:31 UTC 2022
Updates #3053.
testsuites/ada/sptests/sp01/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp01/sp01.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp01/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp01/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp02/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp02/sp02.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp02/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp02/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp03/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp03/sp03.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp03/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp03/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp04/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp04/sp04.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp04/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp04/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp05/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp05/sp05.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp05/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp05/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp06/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp06/sp06.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp06/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp06/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp07/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp07/sp07.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp07/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp07/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp08/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp08/sp08.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp08/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp08/sptest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp09/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp09/sp09.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp09/sptest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/sptests/sp09/sptest.ads | 25 ++++++++++++++++++++++---
36 files changed, 792 insertions(+), 108 deletions(-)
diff --git a/testsuites/ada/sptests/sp01/init.c b/testsuites/ada/sptests/sp01/init.c
index dc5f4fc87c..42f8f4d5a6 100644
--- a/testsuites/ada/sptests/sp01/init.c
+++ b/testsuites/ada/sptests/sp01/init.c
@@ -1,3 +1,5 @@
/* config.h
* This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/testsuites/ada/sptests/sp01/sp01.adb b/testsuites/ada/sptests/sp01/sp01.adb
index 34dd39e8ca..e78abcc34b 100644
--- a/testsuites/ada/sptests/sp01/sp01.adb
+++ b/testsuites/ada/sptests/sp01/sp01.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- MAIN / BODY
@@ -12,9 +14,26 @@
-- COPYRIGHT (c) 1989-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with RTEMS;
diff --git a/testsuites/ada/sptests/sp01/sptest.adb b/testsuites/ada/sptests/sp01/sptest.adb
index 9ba4207205..2a5bdfa0f2 100644
--- a/testsuites/ada/sptests/sp01/sptest.adb
+++ b/testsuites/ada/sptests/sp01/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/sptests/sp01/sptest.ads b/testsuites/ada/sptests/sp01/sptest.ads
index 8753d3edad..637c475c20 100644
--- a/testsuites/ada/sptests/sp01/sptest.ads
+++ b/testsuites/ada/sptests/sp01/sptest.ads
@@ -1,3 +1,5 @@
-- SPTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp02/init.c b/testsuites/ada/sptests/sp02/init.c
index 51801f6c65..5ffe06ac9b 100644
--- a/testsuites/ada/sptests/sp02/init.c
+++ b/testsuites/ada/sptests/sp02/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/testsuites/ada/sptests/sp02/sp02.adb b/testsuites/ada/sptests/sp02/sp02.adb
index adbc97f66c..69398c7ef3 100644
--- a/testsuites/ada/sptests/sp02/sp02.adb
+++ b/testsuites/ada/sptests/sp02/sp02.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp02/sptest.adb b/testsuites/ada/sptests/sp02/sptest.adb
index 4534d28d2e..ecddd998de 100644
--- a/testsuites/ada/sptests/sp02/sptest.adb
+++ b/testsuites/ada/sptests/sp02/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp02/sptest.ads b/testsuites/ada/sptests/sp02/sptest.ads
index 20122e3cbd..f2718a554c 100644
--- a/testsuites/ada/sptests/sp02/sptest.ads
+++ b/testsuites/ada/sptests/sp02/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp03/init.c b/testsuites/ada/sptests/sp03/init.c
index 6da581ed00..6d6155e289 100644
--- a/testsuites/ada/sptests/sp03/init.c
+++ b/testsuites/ada/sptests/sp03/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp03/sp03.adb b/testsuites/ada/sptests/sp03/sp03.adb
index 5f081d4879..f0ce29709c 100644
--- a/testsuites/ada/sptests/sp03/sp03.adb
+++ b/testsuites/ada/sptests/sp03/sp03.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp03/sptest.adb b/testsuites/ada/sptests/sp03/sptest.adb
index 1a05b51721..8a25c554c7 100644
--- a/testsuites/ada/sptests/sp03/sptest.adb
+++ b/testsuites/ada/sptests/sp03/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp03/sptest.ads b/testsuites/ada/sptests/sp03/sptest.ads
index 60a2531ba1..b6c6c8eeb7 100644
--- a/testsuites/ada/sptests/sp03/sptest.ads
+++ b/testsuites/ada/sptests/sp03/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp04/init.c b/testsuites/ada/sptests/sp04/init.c
index c55a103b9a..125efaa8c1 100644
--- a/testsuites/ada/sptests/sp04/init.c
+++ b/testsuites/ada/sptests/sp04/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp04/sp04.adb b/testsuites/ada/sptests/sp04/sp04.adb
index 9d91593b36..48ca059ea4 100644
--- a/testsuites/ada/sptests/sp04/sp04.adb
+++ b/testsuites/ada/sptests/sp04/sp04.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp04/sptest.adb b/testsuites/ada/sptests/sp04/sptest.adb
index 3fcaad18b3..ad06d53cbc 100644
--- a/testsuites/ada/sptests/sp04/sptest.adb
+++ b/testsuites/ada/sptests/sp04/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp04/sptest.ads b/testsuites/ada/sptests/sp04/sptest.ads
index 7033eb5006..5cfffdfa28 100644
--- a/testsuites/ada/sptests/sp04/sptest.ads
+++ b/testsuites/ada/sptests/sp04/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp05/init.c b/testsuites/ada/sptests/sp05/init.c
index 048edae1e8..6b8af28cf9 100644
--- a/testsuites/ada/sptests/sp05/init.c
+++ b/testsuites/ada/sptests/sp05/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp05/sp05.adb b/testsuites/ada/sptests/sp05/sp05.adb
index 842657a699..ff362fb2c4 100644
--- a/testsuites/ada/sptests/sp05/sp05.adb
+++ b/testsuites/ada/sptests/sp05/sp05.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp05/sptest.adb b/testsuites/ada/sptests/sp05/sptest.adb
index 00e41e255d..0d9d667346 100644
--- a/testsuites/ada/sptests/sp05/sptest.adb
+++ b/testsuites/ada/sptests/sp05/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp05/sptest.ads b/testsuites/ada/sptests/sp05/sptest.ads
index 9fe136ec8b..09ebea933f 100644
--- a/testsuites/ada/sptests/sp05/sptest.ads
+++ b/testsuites/ada/sptests/sp05/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp06/init.c b/testsuites/ada/sptests/sp06/init.c
index b37a6a4084..a9d68e488d 100644
--- a/testsuites/ada/sptests/sp06/init.c
+++ b/testsuites/ada/sptests/sp06/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp06/sp06.adb b/testsuites/ada/sptests/sp06/sp06.adb
index 4caba9ae73..9e24819e1a 100644
--- a/testsuites/ada/sptests/sp06/sp06.adb
+++ b/testsuites/ada/sptests/sp06/sp06.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp06/sptest.adb b/testsuites/ada/sptests/sp06/sptest.adb
index b3acf7b006..ebd41d7ce0 100644
--- a/testsuites/ada/sptests/sp06/sptest.adb
+++ b/testsuites/ada/sptests/sp06/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp06/sptest.ads b/testsuites/ada/sptests/sp06/sptest.ads
index 29fa897210..b6dc28dca6 100644
--- a/testsuites/ada/sptests/sp06/sptest.ads
+++ b/testsuites/ada/sptests/sp06/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp07/init.c b/testsuites/ada/sptests/sp07/init.c
index c47213ef68..3c251d0250 100644
--- a/testsuites/ada/sptests/sp07/init.c
+++ b/testsuites/ada/sptests/sp07/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp07/sp07.adb b/testsuites/ada/sptests/sp07/sp07.adb
index 177de946b8..d287ea20f4 100644
--- a/testsuites/ada/sptests/sp07/sp07.adb
+++ b/testsuites/ada/sptests/sp07/sp07.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp07/sptest.adb b/testsuites/ada/sptests/sp07/sptest.adb
index 2ab9cf641b..3cf46542bf 100644
--- a/testsuites/ada/sptests/sp07/sptest.adb
+++ b/testsuites/ada/sptests/sp07/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp07/sptest.ads b/testsuites/ada/sptests/sp07/sptest.ads
index c04b450444..ec2070194d 100644
--- a/testsuites/ada/sptests/sp07/sptest.ads
+++ b/testsuites/ada/sptests/sp07/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp08/init.c b/testsuites/ada/sptests/sp08/init.c
index 328e3eef78..26962dddca 100644
--- a/testsuites/ada/sptests/sp08/init.c
+++ b/testsuites/ada/sptests/sp08/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp08/sp08.adb b/testsuites/ada/sptests/sp08/sp08.adb
index f881ad4e71..4217b1b75e 100644
--- a/testsuites/ada/sptests/sp08/sp08.adb
+++ b/testsuites/ada/sptests/sp08/sp08.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp08/sptest.adb b/testsuites/ada/sptests/sp08/sptest.adb
index 2a2e994e73..2bc0fe8654 100644
--- a/testsuites/ada/sptests/sp08/sptest.adb
+++ b/testsuites/ada/sptests/sp08/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp08/sptest.ads b/testsuites/ada/sptests/sp08/sptest.ads
index 09e9f8383f..ffe8387b21 100644
--- a/testsuites/ada/sptests/sp08/sptest.ads
+++ b/testsuites/ada/sptests/sp08/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp09/init.c b/testsuites/ada/sptests/sp09/init.c
index 534dccd25a..ba5449ce5b 100644
--- a/testsuites/ada/sptests/sp09/init.c
+++ b/testsuites/ada/sptests/sp09/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp09/sp09.adb b/testsuites/ada/sptests/sp09/sp09.adb
index de3a8a91a0..315b36299d 100644
--- a/testsuites/ada/sptests/sp09/sp09.adb
+++ b/testsuites/ada/sptests/sp09/sp09.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/sptests/sp09/sptest.adb b/testsuites/ada/sptests/sp09/sptest.adb
index 7ebb67b54e..946829a2c1 100644
--- a/testsuites/ada/sptests/sp09/sptest.adb
+++ b/testsuites/ada/sptests/sp09/sptest.adb
@@ -1,3 +1,5 @@
-- SPTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/sptests/sp09/sptest.ads b/testsuites/ada/sptests/sp09/sptest.ads
index 7191dd59ce..371a33b3d5 100644
--- a/testsuites/ada/sptests/sp09/sptest.ads
+++ b/testsuites/ada/sptests/sp09/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
2.24.4
