[PATCH 05/39] testsuites/ada/sptests/sp2*: Change license to BSD-2
Fri Apr 8 14:45:33 UTC 2022
Updates #3053.
 testsuites/ada/sptests/sp20/init.c     | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp20/sp20.adb   | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp20/sptest.adb | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp20/sptest.ads | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp22/init.c     | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp22/sp22.adb   | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp22/sptest.adb | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp22/sptest.ads | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp23/init.c     | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp23/sp23.adb   | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp23/sptest.adb | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp23/sptest.ads | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp24/init.c     | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp24/sp24.adb   | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp24/sptest.adb | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp24/sptest.ads | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp25/init.c     | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp25/sp25.adb   | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp25/sptest.adb | 25 ++++++++++++++++++++++---
 testsuites/ada/sptests/sp25/sptest.ads | 25 ++++++++++++++++++++++---
 20 files changed, 440 insertions(+), 60 deletions(-)
diff --git a/testsuites/ada/sptests/sp20/init.c b/testsuites/ada/sptests/sp20/init.c
index 7146c3f3da..7efcfad7e6 100644
--- a/testsuites/ada/sptests/sp20/init.c
+++ b/testsuites/ada/sptests/sp20/init.c
@@ -1,3 +1,5 @@
 /*  config.h
  *  This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-2007.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
diff --git a/testsuites/ada/sptests/sp20/sp20.adb b/testsuites/ada/sptests/sp20/sp20.adb
index 898b96c119..3e6b64b2d3 100644
--- a/testsuites/ada/sptests/sp20/sp20.adb
+++ b/testsuites/ada/sptests/sp20/sp20.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
 --  MAIN / BODY
@@ -12,9 +14,26 @@
 --  COPYRIGHT (c) 1989-2011.
 --  On-Line Applications Research Corporation (OAR).
---  The license and distribution terms for this file may in
---  the file LICENSE in this distribution or at
---  http://www.rtems.org/license/LICENSE.
+--  Redistribution and use in source and binary forms, with or without
+--  modification, are permitted provided that the following conditions
+--  are met:
+--  1. Redistributions of source code must retain the above copyright
+--     notice, this list of conditions and the following disclaimer.
+--  2. Redistributions in binary form must reproduce the above copyright
+--     notice, this list of conditions and the following disclaimer in the
+--     documentation and/or other materials provided with the distribution.
+--  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+--  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+--  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+--  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+--  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+--  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+--  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+--  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+--  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+--  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+--  POSSIBILITY OF SUCH DAMAGE.
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp20/sptest.adb b/testsuites/ada/sptests/sp20/sptest.adb
index e5ad87295c..4efdc56ac0 100644
--- a/testsuites/ada/sptests/sp20/sptest.adb
+++ b/testsuites/ada/sptests/sp20/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/sptests/sp20/sptest.ads b/testsuites/ada/sptests/sp20/sptest.ads
index 384cc1dac5..cc3e844f27 100644
--- a/testsuites/ada/sptests/sp20/sptest.ads
+++ b/testsuites/ada/sptests/sp20/sptest.ads
@@ -1,3 +1,5 @@
 --  SPTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp22/init.c b/testsuites/ada/sptests/sp22/init.c
index 6ebc1b99c3..a351fa166b 100644
--- a/testsuites/ada/sptests/sp22/init.c
+++ b/testsuites/ada/sptests/sp22/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp22/sp22.adb b/testsuites/ada/sptests/sp22/sp22.adb
index 842bc7338e..b911049ea6 100644
--- a/testsuites/ada/sptests/sp22/sp22.adb
+++ b/testsuites/ada/sptests/sp22/sp22.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp22/sptest.adb b/testsuites/ada/sptests/sp22/sptest.adb
index 3cf4baa2bd..3e5a08d4dc 100644
--- a/testsuites/ada/sptests/sp22/sptest.adb
+++ b/testsuites/ada/sptests/sp22/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
diff --git a/testsuites/ada/sptests/sp22/sptest.ads b/testsuites/ada/sptests/sp22/sptest.ads
index af312fafb8..07051cf55f 100644
--- a/testsuites/ada/sptests/sp22/sptest.ads
+++ b/testsuites/ada/sptests/sp22/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp23/init.c b/testsuites/ada/sptests/sp23/init.c
index 76e5f7b883..875266c605 100644
--- a/testsuites/ada/sptests/sp23/init.c
+++ b/testsuites/ada/sptests/sp23/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp23/sp23.adb b/testsuites/ada/sptests/sp23/sp23.adb
index 5a6a728e1d..23583a1148 100644
--- a/testsuites/ada/sptests/sp23/sp23.adb
+++ b/testsuites/ada/sptests/sp23/sp23.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp23/sptest.adb b/testsuites/ada/sptests/sp23/sptest.adb
index 4e88421ec7..50ca707b20 100644
--- a/testsuites/ada/sptests/sp23/sptest.adb
+++ b/testsuites/ada/sptests/sp23/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with ADDRESS_IO;
diff --git a/testsuites/ada/sptests/sp23/sptest.ads b/testsuites/ada/sptests/sp23/sptest.ads
index b5faf7b87a..4af4737b42 100644
--- a/testsuites/ada/sptests/sp23/sptest.ads
+++ b/testsuites/ada/sptests/sp23/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp24/init.c b/testsuites/ada/sptests/sp24/init.c
index 3989b42113..c93d2e3a77 100644
--- a/testsuites/ada/sptests/sp24/init.c
+++ b/testsuites/ada/sptests/sp24/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp24/sp24.adb b/testsuites/ada/sptests/sp24/sp24.adb
index e56802640b..58fcddbd62 100644
--- a/testsuites/ada/sptests/sp24/sp24.adb
+++ b/testsuites/ada/sptests/sp24/sp24.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp24/sptest.adb b/testsuites/ada/sptests/sp24/sptest.adb
index af255e4d73..803fc46039 100644
--- a/testsuites/ada/sptests/sp24/sptest.adb
+++ b/testsuites/ada/sptests/sp24/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
diff --git a/testsuites/ada/sptests/sp24/sptest.ads b/testsuites/ada/sptests/sp24/sptest.ads
index 166ee812b3..1a31c139a0 100644
--- a/testsuites/ada/sptests/sp24/sptest.ads
+++ b/testsuites/ada/sptests/sp24/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp25/init.c b/testsuites/ada/sptests/sp25/init.c
index 8004204cfd..bc8c3c1150 100644
--- a/testsuites/ada/sptests/sp25/init.c
+++ b/testsuites/ada/sptests/sp25/init.c
@@ -1,3 +1,5 @@
 /*  config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/sptests/sp25/sp25.adb b/testsuites/ada/sptests/sp25/sp25.adb
index 00db138fa9..623bcb7f47 100644
--- a/testsuites/ada/sptests/sp25/sp25.adb
+++ b/testsuites/ada/sptests/sp25/sp25.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/sp25/sptest.adb b/testsuites/ada/sptests/sp25/sptest.adb
index 1fff4c0cdb..d3d13ee7e0 100644
--- a/testsuites/ada/sptests/sp25/sptest.adb
+++ b/testsuites/ada/sptests/sp25/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with TEST_SUPPORT;
diff --git a/testsuites/ada/sptests/sp25/sptest.ads b/testsuites/ada/sptests/sp25/sptest.ads
index 21c27a38db..d54d03d8e4 100644
--- a/testsuites/ada/sptests/sp25/sptest.ads
+++ b/testsuites/ada/sptests/sp25/sptest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
2.24.4
