[PATCH 06/39] testsuites/ada/sptests/spatcb01, spname01: Change license to BSD-2
Fri Apr 8 14:45:34 UTC 2022
Updates #3053.
 testsuites/ada/sptests/spatcb01/init.c       | 25 +++++++++++++++++---
 testsuites/ada/sptests/spatcb01/spatcb01.adb | 25 +++++++++++++++++---
 testsuites/ada/sptests/spname01/init.c       | 25 +++++++++++++++++---
 testsuites/ada/sptests/spname01/spname01.adb | 25 +++++++++++++++++---
 testsuites/ada/sptests/spname01/sptest.adb   | 25 +++++++++++++++++---
 testsuites/ada/sptests/spname01/sptest.ads   | 25 +++++++++++++++++---
 6 files changed, 132 insertions(+), 18 deletions(-)
diff --git a/testsuites/ada/sptests/spatcb01/init.c b/testsuites/ada/sptests/spatcb01/init.c
index 38c5fc519a..7db4b111b8 100644
--- a/testsuites/ada/sptests/spatcb01/init.c
+++ b/testsuites/ada/sptests/spatcb01/init.c
@@ -1,9 +1,28 @@
  *  Copyright (c) 2017 embedded brains GmbH
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
diff --git a/testsuites/ada/sptests/spatcb01/spatcb01.adb b/testsuites/ada/sptests/spatcb01/spatcb01.adb
index 810446f871..db74cbb737 100644
--- a/testsuites/ada/sptests/spatcb01/spatcb01.adb
+++ b/testsuites/ada/sptests/spatcb01/spatcb01.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
 --  MAIN / BODY
@@ -8,9 +10,26 @@
 --  Copyright (c) 2017 embedded brains GmbH
---  The license and distribution terms for this file may in
---  the file LICENSE in this distribution or at
---  http://www.rtems.org/license/LICENSE.
+--  Redistribution and use in source and binary forms, with or without
+--  modification, are permitted provided that the following conditions
+--  are met:
+--  1. Redistributions of source code must retain the above copyright
+--     notice, this list of conditions and the following disclaimer.
+--  2. Redistributions in binary form must reproduce the above copyright
+--     notice, this list of conditions and the following disclaimer in the
+--     documentation and/or other materials provided with the distribution.
+--  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+--  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+--  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+--  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+--  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+--  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+--  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+--  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+--  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+--  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+--  POSSIBILITY OF SUCH DAMAGE.
 with TEXT_IO;
diff --git a/testsuites/ada/sptests/spname01/init.c b/testsuites/ada/sptests/spname01/init.c
index 334b6ca2f6..d07040c2d0 100644
--- a/testsuites/ada/sptests/spname01/init.c
+++ b/testsuites/ada/sptests/spname01/init.c
@@ -1,3 +1,5 @@
 /*  config.h
  *  This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-2008.
  *  On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/testsuites/ada/sptests/spname01/spname01.adb b/testsuites/ada/sptests/spname01/spname01.adb
index 6c39c329de..53862ea260 100644
--- a/testsuites/ada/sptests/spname01/spname01.adb
+++ b/testsuites/ada/sptests/spname01/spname01.adb
@@ -1,3 +1,5 @@
 --  MAIN / BODY
@@ -12,9 +14,26 @@
 --  COPYRIGHT (c) 1989-2009.
 --  On-Line Applications Research Corporation (OAR).
+--  are met:
 with SPTEST;
diff --git a/testsuites/ada/sptests/spname01/sptest.adb b/testsuites/ada/sptests/spname01/sptest.adb
index 5d99ed92e5..6c89da1625 100644
--- a/testsuites/ada/sptests/spname01/sptest.adb
+++ b/testsuites/ada/sptests/spname01/sptest.adb
@@ -1,3 +1,5 @@
 --  SPTEST / BODY
@@ -13,9 +15,26 @@
+--  are met:
 with RTEMS;
diff --git a/testsuites/ada/sptests/spname01/sptest.ads b/testsuites/ada/sptests/spname01/sptest.ads
index 179517d98c..668f68bf49 100644
--- a/testsuites/ada/sptests/spname01/sptest.ads
+++ b/testsuites/ada/sptests/spname01/sptest.ads
@@ -1,3 +1,5 @@
 --  SPTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+--  are met:
 package SPTEST is
2.24.4
