[PATCH 10/39] testsuites/ada/tmtests/tmck: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:38 UTC 2022
Updates #3053.
testsuites/ada/tmtests/tmck/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tmck/tmck.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tmck/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tmck/tmtest.ads | 25 ++++++++++++++++++++++---
4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/testsuites/ada/tmtests/tmck/init.c b/testsuites/ada/tmtests/tmck/init.c
index 0bce9d48f3..ae32bcc9e7 100644
--- a/testsuites/ada/tmtests/tmck/init.c
+++ b/testsuites/ada/tmtests/tmck/init.c
@@ -1,3 +1,5 @@
/* config.h
* This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/testsuites/ada/tmtests/tmck/tmck.adb b/testsuites/ada/tmtests/tmck/tmck.adb
index c35d786517..2e8d99b5a7 100644
--- a/testsuites/ada/tmtests/tmck/tmck.adb
+++ b/testsuites/ada/tmtests/tmck/tmck.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- MAIN / BODY
@@ -12,9 +14,26 @@
-- COPYRIGHT (c) 1989-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with RTEMS;
diff --git a/testsuites/ada/tmtests/tmck/tmtest.adb b/testsuites/ada/tmtests/tmck/tmtest.adb
index d1d7659988..7861fcaf90 100644
--- a/testsuites/ada/tmtests/tmck/tmtest.adb
+++ b/testsuites/ada/tmtests/tmck/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with TIMER_DRIVER;
diff --git a/testsuites/ada/tmtests/tmck/tmtest.ads b/testsuites/ada/tmtests/tmck/tmtest.ads
index 6eef577910..081c49fa4f 100644
--- a/testsuites/ada/tmtests/tmck/tmtest.ads
+++ b/testsuites/ada/tmtests/tmck/tmtest.ads
@@ -1,3 +1,5 @@
-- TMTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
2.24.4
