[PATCH 09/39] testsuites/ada/tmtests/tm2*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:37 UTC 2022
Updates #3053.
testsuites/ada/tmtests/tm20/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm20/tm20.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm20/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm20/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm21/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm21/tm21.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm21/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm21/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm22/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm22/tm22.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm22/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm22/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm23/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm23/tm23.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm23/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm23/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm24/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm24/tm24.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm24/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm24/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm25/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm25/tm25.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm25/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm25/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm28/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm28/tm28.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm28/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm28/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm29/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm29/tm29.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm29/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm29/tmtest.ads | 25 ++++++++++++++++++++++---
32 files changed, 704 insertions(+), 96 deletions(-)
diff --git a/testsuites/ada/tmtests/tm20/init.c b/testsuites/ada/tmtests/tm20/init.c
index 6c5481debb..5f252c2f34 100644
--- a/testsuites/ada/tmtests/tm20/init.c
+++ b/testsuites/ada/tmtests/tm20/init.c
@@ -1,3 +1,5 @@
/* config.h
* This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/testsuites/ada/tmtests/tm20/tm20.adb b/testsuites/ada/tmtests/tm20/tm20.adb
index 47ef899495..b366f8d8c1 100644
--- a/testsuites/ada/tmtests/tm20/tm20.adb
+++ b/testsuites/ada/tmtests/tm20/tm20.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- MAIN / BODY
@@ -12,9 +14,26 @@
-- COPYRIGHT (c) 1989-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm20/tmtest.adb b/testsuites/ada/tmtests/tm20/tmtest.adb
index a6ebafec40..8e139da1e1 100644
--- a/testsuites/ada/tmtests/tm20/tmtest.adb
+++ b/testsuites/ada/tmtests/tm20/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/tmtests/tm20/tmtest.ads b/testsuites/ada/tmtests/tm20/tmtest.ads
index 8afc25ac2c..c0801ae8fb 100644
--- a/testsuites/ada/tmtests/tm20/tmtest.ads
+++ b/testsuites/ada/tmtests/tm20/tmtest.ads
@@ -1,3 +1,5 @@
-- TMTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with TIME_TEST_SUPPORT;
diff --git a/testsuites/ada/tmtests/tm21/init.c b/testsuites/ada/tmtests/tm21/init.c
index 04e0bc9011..06abc7b7f6 100644
--- a/testsuites/ada/tmtests/tm21/init.c
+++ b/testsuites/ada/tmtests/tm21/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm21/tm21.adb b/testsuites/ada/tmtests/tm21/tm21.adb
index 45381ece6c..9aadfcde10 100644
--- a/testsuites/ada/tmtests/tm21/tm21.adb
+++ b/testsuites/ada/tmtests/tm21/tm21.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm21/tmtest.adb b/testsuites/ada/tmtests/tm21/tmtest.adb
index 9cf2d09e86..3c398c420d 100644
--- a/testsuites/ada/tmtests/tm21/tmtest.adb
+++ b/testsuites/ada/tmtests/tm21/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS_CALLING_OVERHEAD;
diff --git a/testsuites/ada/tmtests/tm21/tmtest.ads b/testsuites/ada/tmtests/tm21/tmtest.ads
index 538ffad4d0..d70322cd9f 100644
--- a/testsuites/ada/tmtests/tm21/tmtest.ads
+++ b/testsuites/ada/tmtests/tm21/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm22/init.c b/testsuites/ada/tmtests/tm22/init.c
index 368119d9a3..929bf75b53 100644
--- a/testsuites/ada/tmtests/tm22/init.c
+++ b/testsuites/ada/tmtests/tm22/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm22/tm22.adb b/testsuites/ada/tmtests/tm22/tm22.adb
index ce755dd517..b7d4970a13 100644
--- a/testsuites/ada/tmtests/tm22/tm22.adb
+++ b/testsuites/ada/tmtests/tm22/tm22.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm22/tmtest.adb b/testsuites/ada/tmtests/tm22/tmtest.adb
index 88588bd89d..36d02e9718 100644
--- a/testsuites/ada/tmtests/tm22/tmtest.adb
+++ b/testsuites/ada/tmtests/tm22/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm22/tmtest.ads b/testsuites/ada/tmtests/tm22/tmtest.ads
index f5dce6c3a0..cc6e02f56c 100644
--- a/testsuites/ada/tmtests/tm22/tmtest.ads
+++ b/testsuites/ada/tmtests/tm22/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm23/init.c b/testsuites/ada/tmtests/tm23/init.c
index 9ad2f691a0..951933f1f4 100644
--- a/testsuites/ada/tmtests/tm23/init.c
+++ b/testsuites/ada/tmtests/tm23/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm23/tm23.adb b/testsuites/ada/tmtests/tm23/tm23.adb
index 5e345c958a..6d013df606 100644
--- a/testsuites/ada/tmtests/tm23/tm23.adb
+++ b/testsuites/ada/tmtests/tm23/tm23.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm23/tmtest.adb b/testsuites/ada/tmtests/tm23/tmtest.adb
index 6115416f1b..8c60ecf6e5 100644
--- a/testsuites/ada/tmtests/tm23/tmtest.adb
+++ b/testsuites/ada/tmtests/tm23/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm23/tmtest.ads b/testsuites/ada/tmtests/tm23/tmtest.ads
index 6e567007ca..0ec796c91f 100644
--- a/testsuites/ada/tmtests/tm23/tmtest.ads
+++ b/testsuites/ada/tmtests/tm23/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm24/init.c b/testsuites/ada/tmtests/tm24/init.c
index da98a9ddbd..b90daf0738 100644
--- a/testsuites/ada/tmtests/tm24/init.c
+++ b/testsuites/ada/tmtests/tm24/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm24/tm24.adb b/testsuites/ada/tmtests/tm24/tm24.adb
index a5ca5d4f7f..119029dd56 100644
--- a/testsuites/ada/tmtests/tm24/tm24.adb
+++ b/testsuites/ada/tmtests/tm24/tm24.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm24/tmtest.adb b/testsuites/ada/tmtests/tm24/tmtest.adb
index b5830cef7b..5332f6f26b 100644
--- a/testsuites/ada/tmtests/tm24/tmtest.adb
+++ b/testsuites/ada/tmtests/tm24/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm24/tmtest.ads b/testsuites/ada/tmtests/tm24/tmtest.ads
index fb6203d5c1..294e65d424 100644
--- a/testsuites/ada/tmtests/tm24/tmtest.ads
+++ b/testsuites/ada/tmtests/tm24/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm25/init.c b/testsuites/ada/tmtests/tm25/init.c
index ddbde343b0..0ebf5a934b 100644
--- a/testsuites/ada/tmtests/tm25/init.c
+++ b/testsuites/ada/tmtests/tm25/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm25/tm25.adb b/testsuites/ada/tmtests/tm25/tm25.adb
index 44bda5893f..cd3894aa28 100644
--- a/testsuites/ada/tmtests/tm25/tm25.adb
+++ b/testsuites/ada/tmtests/tm25/tm25.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm25/tmtest.adb b/testsuites/ada/tmtests/tm25/tmtest.adb
index 63d68d4aa1..ab8f59f6d9 100644
--- a/testsuites/ada/tmtests/tm25/tmtest.adb
+++ b/testsuites/ada/tmtests/tm25/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm25/tmtest.ads b/testsuites/ada/tmtests/tm25/tmtest.ads
index 45a671af81..074a66639f 100644
--- a/testsuites/ada/tmtests/tm25/tmtest.ads
+++ b/testsuites/ada/tmtests/tm25/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm28/init.c b/testsuites/ada/tmtests/tm28/init.c
index 4451f86000..484756174c 100644
--- a/testsuites/ada/tmtests/tm28/init.c
+++ b/testsuites/ada/tmtests/tm28/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm28/tm28.adb b/testsuites/ada/tmtests/tm28/tm28.adb
index 93d0f3cf02..bfed1ed985 100644
--- a/testsuites/ada/tmtests/tm28/tm28.adb
+++ b/testsuites/ada/tmtests/tm28/tm28.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm28/tmtest.adb b/testsuites/ada/tmtests/tm28/tmtest.adb
index 71b6edc32f..0d7a4401ec 100644
--- a/testsuites/ada/tmtests/tm28/tmtest.adb
+++ b/testsuites/ada/tmtests/tm28/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm28/tmtest.ads b/testsuites/ada/tmtests/tm28/tmtest.ads
index 39ceeb0ad2..06aefefde7 100644
--- a/testsuites/ada/tmtests/tm28/tmtest.ads
+++ b/testsuites/ada/tmtests/tm28/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with SYSTEM;
diff --git a/testsuites/ada/tmtests/tm29/init.c b/testsuites/ada/tmtests/tm29/init.c
index 6789a328bc..3f12731be8 100644
--- a/testsuites/ada/tmtests/tm29/init.c
+++ b/testsuites/ada/tmtests/tm29/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm29/tm29.adb b/testsuites/ada/tmtests/tm29/tm29.adb
index 4853fbf2c7..1fbc45a92e 100644
--- a/testsuites/ada/tmtests/tm29/tm29.adb
+++ b/testsuites/ada/tmtests/tm29/tm29.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm29/tmtest.adb b/testsuites/ada/tmtests/tm29/tmtest.adb
index c77fbc0abd..14c563c6dd 100644
--- a/testsuites/ada/tmtests/tm29/tmtest.adb
+++ b/testsuites/ada/tmtests/tm29/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm29/tmtest.ads b/testsuites/ada/tmtests/tm29/tmtest.ads
index 8661fc28b6..e9280a6844 100644
--- a/testsuites/ada/tmtests/tm29/tmtest.ads
+++ b/testsuites/ada/tmtests/tm29/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
2.24.4
