[PATCH 12/39] testsuites/benchmarks/*: Change license to BSD-2
Fri Apr 8 14:45:40 UTC 2022
Updates #3053.
 testsuites/benchmarks/dhrystone/init.c | 25 ++++++++++++++++++++++---
 testsuites/benchmarks/linpack/init.c   | 25 ++++++++++++++++++++++---
 testsuites/benchmarks/whetstone/init.c | 25 ++++++++++++++++++++++---
 3 files changed, 66 insertions(+), 9 deletions(-)
diff --git a/testsuites/benchmarks/dhrystone/init.c b/testsuites/benchmarks/dhrystone/init.c
index 42d186181b..448369074e 100644
--- a/testsuites/benchmarks/dhrystone/init.c
+++ b/testsuites/benchmarks/dhrystone/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/benchmarks/linpack/init.c b/testsuites/benchmarks/linpack/init.c
index 621e0b9bfd..2899674bca 100644
--- a/testsuites/benchmarks/linpack/init.c
+++ b/testsuites/benchmarks/linpack/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/benchmarks/whetstone/init.c b/testsuites/benchmarks/whetstone/init.c
index dae957e03f..37adcb3e89 100644
--- a/testsuites/benchmarks/whetstone/init.c
+++ b/testsuites/benchmarks/whetstone/init.c
@@ -1,9 +1,28 @@
+ * are met:
2.24.4
