[PATCH 13/39] testsuites/rmtests/tm[01]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:41 UTC 2022
Updates #3053.
testsuites/tmtests/tm01/tm01.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm02/tm02.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm03/tm03.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm04/tm04.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm05/tm05.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm06/tm06.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm07/tm07.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm08/tm08.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm09/tm09.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm10/tm10.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm11/tm11.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm12/tm12.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm13/tm13.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm14/tm14.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm15/tm15.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm16/tm16.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm17/tm17.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm18/tm18.doc | 25 ++++++++++++++++++++++---
testsuites/tmtests/tm19/tm19.doc | 25 ++++++++++++++++++++++---
19 files changed, 418 insertions(+), 57 deletions(-)
diff --git a/testsuites/tmtests/tm01/tm01.doc b/testsuites/tmtests/tm01/tm01.doc
index 9ca4465644..cc1da565ab 100644
--- a/testsuites/tmtests/tm01/tm01.doc
+++ b/testsuites/tmtests/tm01/tm01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
# COPYRIGHT (c) 1989-2014.
# On-Line Applications Research Corporation (OAR).
# Cynthia Rempel <cynthia at rtems.org>
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This test benchmarks the following operations:
diff --git a/testsuites/tmtests/tm02/tm02.doc b/testsuites/tmtests/tm02/tm02.doc
index ed9aac09ac..eb3c4d9c9a 100644
--- a/testsuites/tmtests/tm02/tm02.doc
+++ b/testsuites/tmtests/tm02/tm02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm03/tm03.doc b/testsuites/tmtests/tm03/tm03.doc
index 3d1ea9d4ef..79457a49dc 100644
--- a/testsuites/tmtests/tm03/tm03.doc
+++ b/testsuites/tmtests/tm03/tm03.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/tmtests/tm04/tm04.doc b/testsuites/tmtests/tm04/tm04.doc
index d77b7bbe1e..c120f5061d 100644
--- a/testsuites/tmtests/tm04/tm04.doc
+++ b/testsuites/tmtests/tm04/tm04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm05/tm05.doc b/testsuites/tmtests/tm05/tm05.doc
index 5e0bf1b6f1..20842f3156 100644
--- a/testsuites/tmtests/tm05/tm05.doc
+++ b/testsuites/tmtests/tm05/tm05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm06/tm06.doc b/testsuites/tmtests/tm06/tm06.doc
index 7263a33695..81949d09a9 100644
--- a/testsuites/tmtests/tm06/tm06.doc
+++ b/testsuites/tmtests/tm06/tm06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm07/tm07.doc b/testsuites/tmtests/tm07/tm07.doc
index efbcfd2c21..5553f6b0ba 100644
--- a/testsuites/tmtests/tm07/tm07.doc
+++ b/testsuites/tmtests/tm07/tm07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm08/tm08.doc b/testsuites/tmtests/tm08/tm08.doc
index e364a58dc3..5b4a119b64 100644
--- a/testsuites/tmtests/tm08/tm08.doc
+++ b/testsuites/tmtests/tm08/tm08.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm09/tm09.doc b/testsuites/tmtests/tm09/tm09.doc
index 3a44e10eff..4546c85d95 100644
--- a/testsuites/tmtests/tm09/tm09.doc
+++ b/testsuites/tmtests/tm09/tm09.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm10/tm10.doc b/testsuites/tmtests/tm10/tm10.doc
index 863032a955..e5eba8acb6 100644
--- a/testsuites/tmtests/tm10/tm10.doc
+++ b/testsuites/tmtests/tm10/tm10.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm11/tm11.doc b/testsuites/tmtests/tm11/tm11.doc
index b8da594f01..6506b23518 100644
--- a/testsuites/tmtests/tm11/tm11.doc
+++ b/testsuites/tmtests/tm11/tm11.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm12/tm12.doc b/testsuites/tmtests/tm12/tm12.doc
--- a/testsuites/tmtests/tm12/tm12.doc
+++ b/testsuites/tmtests/tm12/tm12.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm13/tm13.doc b/testsuites/tmtests/tm13/tm13.doc
index 7eaba730e1..6f8d196c21 100644
--- a/testsuites/tmtests/tm13/tm13.doc
+++ b/testsuites/tmtests/tm13/tm13.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm14/tm14.doc b/testsuites/tmtests/tm14/tm14.doc
--- a/testsuites/tmtests/tm14/tm14.doc
+++ b/testsuites/tmtests/tm14/tm14.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm15/tm15.doc b/testsuites/tmtests/tm15/tm15.doc
index 57ad86f91f..f05756a5a9 100644
--- a/testsuites/tmtests/tm15/tm15.doc
+++ b/testsuites/tmtests/tm15/tm15.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm16/tm16.doc b/testsuites/tmtests/tm16/tm16.doc
index b3e355c6a3..b3e407a04f 100644
--- a/testsuites/tmtests/tm16/tm16.doc
+++ b/testsuites/tmtests/tm16/tm16.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm17/tm17.doc b/testsuites/tmtests/tm17/tm17.doc
index c05b755588..b8f72c681b 100644
--- a/testsuites/tmtests/tm17/tm17.doc
+++ b/testsuites/tmtests/tm17/tm17.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm18/tm18.doc b/testsuites/tmtests/tm18/tm18.doc
index af214ad757..a418f3903e 100644
--- a/testsuites/tmtests/tm18/tm18.doc
+++ b/testsuites/tmtests/tm18/tm18.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm19/tm19.doc b/testsuites/tmtests/tm19/tm19.doc
index 93d6792d62..1b98f9228b 100644
--- a/testsuites/tmtests/tm19/tm19.doc
+++ b/testsuites/tmtests/tm19/tm19.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
