[PATCH 14/39] testsuites/tmtests/tm[23]*: Change license to BSD-2
Fri Apr 8 14:45:42 UTC 2022
Updates #3053.
 testsuites/tmtests/tm20/tm20.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm21/tm21.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm22/tm22.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm23/tm23.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm24/tm24.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm25/tm25.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm26/tm26.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm27/tm27.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm28/tm28.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm29/tm29.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm30/tm30.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm31/tm31.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm32/tm32.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm33/tm33.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm34/tm34.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm35/tm35.doc | 25 ++++++++++++++++++++++---
 testsuites/tmtests/tm36/tm36.doc | 25 ++++++++++++++++++++++---
 17 files changed, 374 insertions(+), 51 deletions(-)
diff --git a/testsuites/tmtests/tm20/tm20.doc b/testsuites/tmtests/tm20/tm20.doc
index 970ea5b99a..7bf1bc4351 100644
--- a/testsuites/tmtests/tm20/tm20.doc
+++ b/testsuites/tmtests/tm20/tm20.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 1989-2014.
 #  On-Line Applications Research Corporation (OAR).
 #  Cynthia Rempel <cynthia at rtems.org>
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This test benchmarks the following operations:
diff --git a/testsuites/tmtests/tm21/tm21.doc b/testsuites/tmtests/tm21/tm21.doc
index 7182478e7d..b0273a6510 100644
--- a/testsuites/tmtests/tm21/tm21.doc
+++ b/testsuites/tmtests/tm21/tm21.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm22/tm22.doc b/testsuites/tmtests/tm22/tm22.doc
index 48cb96a105..b979e982b5 100644
--- a/testsuites/tmtests/tm22/tm22.doc
+++ b/testsuites/tmtests/tm22/tm22.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm23/tm23.doc b/testsuites/tmtests/tm23/tm23.doc
index 7cf0d25a6d..67f695c558 100644
--- a/testsuites/tmtests/tm23/tm23.doc
+++ b/testsuites/tmtests/tm23/tm23.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm24/tm24.doc b/testsuites/tmtests/tm24/tm24.doc
index 89bfccef5c..3416ecfec9 100644
--- a/testsuites/tmtests/tm24/tm24.doc
+++ b/testsuites/tmtests/tm24/tm24.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm25/tm25.doc b/testsuites/tmtests/tm25/tm25.doc
index f1d39700bd..0353949692 100644
--- a/testsuites/tmtests/tm25/tm25.doc
+++ b/testsuites/tmtests/tm25/tm25.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm26/tm26.doc b/testsuites/tmtests/tm26/tm26.doc
index 8b97adec25..a9fbc961e0 100644
--- a/testsuites/tmtests/tm26/tm26.doc
+++ b/testsuites/tmtests/tm26/tm26.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm27/tm27.doc b/testsuites/tmtests/tm27/tm27.doc
index 981286480f..f56c0e1f4e 100644
--- a/testsuites/tmtests/tm27/tm27.doc
+++ b/testsuites/tmtests/tm27/tm27.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-1999.
+# are met:
diff --git a/testsuites/tmtests/tm28/tm28.doc b/testsuites/tmtests/tm28/tm28.doc
index d5a683626c..c224e8a0e7 100644
--- a/testsuites/tmtests/tm28/tm28.doc
+++ b/testsuites/tmtests/tm28/tm28.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm29/tm29.doc b/testsuites/tmtests/tm29/tm29.doc
index 4861236517..8961ce23b5 100644
--- a/testsuites/tmtests/tm29/tm29.doc
+++ b/testsuites/tmtests/tm29/tm29.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm30/tm30.doc b/testsuites/tmtests/tm30/tm30.doc
index 2a6baae8d6..f2b6ac485d 100644
--- a/testsuites/tmtests/tm30/tm30.doc
+++ b/testsuites/tmtests/tm30/tm30.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/tmtests/tm31/tm31.doc b/testsuites/tmtests/tm31/tm31.doc
index 90de934e4c..53e4e4ed89 100644
--- a/testsuites/tmtests/tm31/tm31.doc
+++ b/testsuites/tmtests/tm31/tm31.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/tmtests/tm32/tm32.doc b/testsuites/tmtests/tm32/tm32.doc
index 2087d42a6b..dcb83c4162 100644
--- a/testsuites/tmtests/tm32/tm32.doc
+++ b/testsuites/tmtests/tm32/tm32.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/tmtests/tm33/tm33.doc b/testsuites/tmtests/tm33/tm33.doc
index f78a4dc96d..b6a36f8a74 100644
--- a/testsuites/tmtests/tm33/tm33.doc
+++ b/testsuites/tmtests/tm33/tm33.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/tmtests/tm34/tm34.doc b/testsuites/tmtests/tm34/tm34.doc
index 5affd68cfa..7678359158 100644
--- a/testsuites/tmtests/tm34/tm34.doc
+++ b/testsuites/tmtests/tm34/tm34.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/tmtests/tm35/tm35.doc b/testsuites/tmtests/tm35/tm35.doc
index e82e284ef0..f4d0add1bd 100644
--- a/testsuites/tmtests/tm35/tm35.doc
+++ b/testsuites/tmtests/tm35/tm35.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/tmtests/tm36/tm36.doc b/testsuites/tmtests/tm36/tm36.doc
index 0f20a9c130..2573f154a7 100644
--- a/testsuites/tmtests/tm36/tm36.doc
+++ b/testsuites/tmtests/tm36/tm36.doc
@@ -1,8 +1,27 @@
+# are met:
2.24.4
