[PATCH 16/39] testsuites/tmtests/*/*.py: Change license to BSD-2
Fri Apr 8 14:45:44 UTC 2022
Updates #3053.
 testsuites/tmtests/tmcontext01/plot.py  | 23 ++++++++++++++++++++---
 testsuites/tmtests/tmfine01/tmfine01.py | 23 ++++++++++++++++++++---
 testsuites/tmtests/tmtimer01/plot.py    | 23 ++++++++++++++++++++---
 3 files changed, 60 insertions(+), 9 deletions(-)
diff --git a/testsuites/tmtests/tmcontext01/plot.py b/testsuites/tmtests/tmcontext01/plot.py
index c65af96d1e..56d46c654d 100644
--- a/testsuites/tmtests/tmcontext01/plot.py
+++ b/testsuites/tmtests/tmcontext01/plot.py
@@ -3,9 +3,26 @@
 # Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 import libxml2
diff --git a/testsuites/tmtests/tmfine01/tmfine01.py b/testsuites/tmtests/tmfine01/tmfine01.py
index d63485f828..9345e245c5 100644
--- a/testsuites/tmtests/tmfine01/tmfine01.py
+++ b/testsuites/tmtests/tmfine01/tmfine01.py
@@ -5,9 +5,26 @@
 # Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+# are met:
 import re
diff --git a/testsuites/tmtests/tmtimer01/plot.py b/testsuites/tmtests/tmtimer01/plot.py
index 136d470293..c0738ef70d 100644
--- a/testsuites/tmtests/tmtimer01/plot.py
+++ b/testsuites/tmtests/tmtimer01/plot.py
@@ -3,9 +3,26 @@
+# are met:
 import libxml2
2.24.4
