[PATCH 17/39] testsuites/support/*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:45 UTC 2022
Updates #3053.
testsuites/support/include/test_support.h | 25 ++++++++++++++++---
testsuites/support/include/tmacros.h | 25 ++++++++++++++++---
.../support/include/tmtests_empty_function.h | 2 +-
testsuites/support/src/locked_print.c | 25 ++++++++++++++++---
testsuites/support/src/spin.c | 25 ++++++++++++++++---
testsuites/support/src/test_support.c | 25 ++++++++++++++++---
.../support/src/tmtests_empty_function.c | 25 ++++++++++++++++---
testsuites/support/src/tmtests_support.c | 25 ++++++++++++++++---
8 files changed, 155 insertions(+), 22 deletions(-)
diff --git a/testsuites/support/include/test_support.h b/testsuites/support/include/test_support.h
index 9c30b3967e..4ddfe38896 100644
--- a/testsuites/support/include/test_support.h
+++ b/testsuites/support/include/test_support.h
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifndef __TEST_SUPPORT_h
diff --git a/testsuites/support/include/tmacros.h b/testsuites/support/include/tmacros.h
index fe17bc01e7..0dc35ea21d 100644
--- a/testsuites/support/include/tmacros.h
+++ b/testsuites/support/include/tmacros.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
#ifndef __TMACROS_h
diff --git a/testsuites/support/include/tmtests_empty_function.h b/testsuites/support/include/tmtests_empty_function.h
index a47df619c6..6c89316676 100644
--- a/testsuites/support/include/tmtests_empty_function.h
+++ b/testsuites/support/include/tmtests_empty_function.h
@@ -2,7 +2,7 @@
* Prototypes for RTEMS tmtests_empty_function.c.
* COPYRIGHT (c) 2011, Ralf Corsépius, Ulm/Germany.
diff --git a/testsuites/support/src/locked_print.c b/testsuites/support/src/locked_print.c
index f80f74f9d8..c85f7ce328 100644
--- a/testsuites/support/src/locked_print.c
+++ b/testsuites/support/src/locked_print.c
@@ -1,10 +1,29 @@
+ * are met:
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/support/src/spin.c b/testsuites/support/src/spin.c
index 57c4e323d5..58cc0f728f 100644
--- a/testsuites/support/src/spin.c
+++ b/testsuites/support/src/spin.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/support/src/test_support.c b/testsuites/support/src/test_support.c
index 95a46b6d90..1e5ee0eee4 100644
--- a/testsuites/support/src/test_support.c
+++ b/testsuites/support/src/test_support.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/testsuites/support/src/tmtests_empty_function.c b/testsuites/support/src/tmtests_empty_function.c
index 2586c7ebe6..e1834d2468 100644
--- a/testsuites/support/src/tmtests_empty_function.c
+++ b/testsuites/support/src/tmtests_empty_function.c
@@ -1,3 +1,5 @@
* This file implements an empty function used by the RTEMS Timing Tests
* to set a baseline for loop overhead.
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/support/src/tmtests_support.c b/testsuites/support/src/tmtests_support.c
index a6230ab13c..9fb0c89ce7 100644
--- a/testsuites/support/src/tmtests_support.c
+++ b/testsuites/support/src/tmtests_support.c
@@ -1,10 +1,29 @@
+ * are met:
2.24.4
