[PATCH 19/39] testsuites/libtests/[m-z]*: Change license to BSD-2
Fri Apr 8 14:45:47 UTC 2022
Updates #3053.
 testsuites/libtests/malloc02/malloc02.doc     | 25 ++++++++++++++++---
 testsuites/libtests/malloc03/malloc03.doc     | 25 ++++++++++++++++---
 testsuites/libtests/malloc04/malloc04.doc     | 25 ++++++++++++++++---
 testsuites/libtests/monitor/monitor.doc       | 25 ++++++++++++++++---
 testsuites/libtests/monitor02/monitor02.doc   | 25 ++++++++++++++++---
 testsuites/libtests/mouse01/mouse01.doc       | 25 ++++++++++++++++---
 testsuites/libtests/putenvtest/putenvtest.doc | 25 ++++++++++++++++---
 testsuites/libtests/rbheap01/rbheap.doc       | 25 ++++++++++++++++---
 testsuites/libtests/stackchk/stackchk.doc     | 25 ++++++++++++++++---
 testsuites/libtests/stackchk01/stackchk01.doc | 25 ++++++++++++++++---
 testsuites/libtests/stringto01/stringto01.doc | 25 ++++++++++++++++---
 testsuites/libtests/tar01/tar01.doc           | 25 ++++++++++++++++---
 testsuites/libtests/tar02/tar02.doc           | 25 ++++++++++++++++---
 testsuites/libtests/tar03/tar03.doc           | 25 ++++++++++++++++---
 testsuites/libtests/termios01/termios01.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios02/termios02.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios03/termios03.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios04/termios04.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios05/termios05.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios06/termios06.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios07/termios07.doc   | 25 ++++++++++++++++---
 testsuites/libtests/termios08/termios08.doc   | 25 ++++++++++++++++---
 testsuites/libtests/uid01/init.c              | 25 ++++++++++++++++---
 testsuites/libtests/uid01/msmouse.c           | 25 ++++++++++++++++---
 .../libtests/uid01/serial_mouse_config.c      | 25 ++++++++++++++++---
 testsuites/libtests/uid01/uid01.doc           | 25 ++++++++++++++++---
 testsuites/libtests/utf8proc01/utf8proc01.doc | 25 ++++++++++++++++---
 27 files changed, 594 insertions(+), 81 deletions(-)
diff --git a/testsuites/libtests/malloc02/malloc02.doc b/testsuites/libtests/malloc02/malloc02.doc
index 2c44a2b2eb..6296ff2c73 100644
--- a/testsuites/libtests/malloc02/malloc02.doc
+++ b/testsuites/libtests/malloc02/malloc02.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 1989-2010.
 #  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/libtests/malloc03/malloc03.doc b/testsuites/libtests/malloc03/malloc03.doc
index 2ad50c7e52..83c7dd1453 100644
--- a/testsuites/libtests/malloc03/malloc03.doc
+++ b/testsuites/libtests/malloc03/malloc03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/malloc04/malloc04.doc b/testsuites/libtests/malloc04/malloc04.doc
index 6199e85cc3..9936e505d6 100644
--- a/testsuites/libtests/malloc04/malloc04.doc
+++ b/testsuites/libtests/malloc04/malloc04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/monitor/monitor.doc b/testsuites/libtests/monitor/monitor.doc
index 3a698fa48f..c3cd6e3034 100644
--- a/testsuites/libtests/monitor/monitor.doc
+++ b/testsuites/libtests/monitor/monitor.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 2014.
 #  Cynthia Rempel <cynthia at rtems.org>
+# are met:
diff --git a/testsuites/libtests/monitor02/monitor02.doc b/testsuites/libtests/monitor02/monitor02.doc
index df696b48a5..440cdfd5b1 100644
--- a/testsuites/libtests/monitor02/monitor02.doc
+++ b/testsuites/libtests/monitor02/monitor02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/mouse01/mouse01.doc b/testsuites/libtests/mouse01/mouse01.doc
index a38e8d24c4..ebbd9e085f 100644
--- a/testsuites/libtests/mouse01/mouse01.doc
+++ b/testsuites/libtests/mouse01/mouse01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 2011.
+# are met:
diff --git a/testsuites/libtests/putenvtest/putenvtest.doc b/testsuites/libtests/putenvtest/putenvtest.doc
index 273027956d..ec47d4d21c 100644
--- a/testsuites/libtests/putenvtest/putenvtest.doc
+++ b/testsuites/libtests/putenvtest/putenvtest.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/rbheap01/rbheap.doc b/testsuites/libtests/rbheap01/rbheap.doc
index b86cc692a6..bc64fb2679 100644
--- a/testsuites/libtests/rbheap01/rbheap.doc
+++ b/testsuites/libtests/rbheap01/rbheap.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/stackchk/stackchk.doc b/testsuites/libtests/stackchk/stackchk.doc
index febe9e3ac6..ebc01d4f96 100644
--- a/testsuites/libtests/stackchk/stackchk.doc
+++ b/testsuites/libtests/stackchk/stackchk.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/stackchk01/stackchk01.doc b/testsuites/libtests/stackchk01/stackchk01.doc
index c4dea4d9b6..5b3d9c894b 100644
--- a/testsuites/libtests/stackchk01/stackchk01.doc
+++ b/testsuites/libtests/stackchk01/stackchk01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-1999.
+# are met:
diff --git a/testsuites/libtests/stringto01/stringto01.doc b/testsuites/libtests/stringto01/stringto01.doc
index 88e0b8b7eb..590d4b8634 100644
--- a/testsuites/libtests/stringto01/stringto01.doc
+++ b/testsuites/libtests/stringto01/stringto01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2009.
+# are met:
diff --git a/testsuites/libtests/tar01/tar01.doc b/testsuites/libtests/tar01/tar01.doc
index adffdca291..1530321f49 100644
--- a/testsuites/libtests/tar01/tar01.doc
+++ b/testsuites/libtests/tar01/tar01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/tar02/tar02.doc b/testsuites/libtests/tar02/tar02.doc
index f2d4c343f0..7e2a4dde16 100644
--- a/testsuites/libtests/tar02/tar02.doc
+++ b/testsuites/libtests/tar02/tar02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/tar03/tar03.doc b/testsuites/libtests/tar03/tar03.doc
index f09612f1e6..4a979e4ec3 100644
--- a/testsuites/libtests/tar03/tar03.doc
+++ b/testsuites/libtests/tar03/tar03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios01/termios01.doc b/testsuites/libtests/termios01/termios01.doc
index ebc9c7aef2..2ba39696c9 100644
--- a/testsuites/libtests/termios01/termios01.doc
+++ b/testsuites/libtests/termios01/termios01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios02/termios02.doc b/testsuites/libtests/termios02/termios02.doc
index 4e0c03555c..5816810cec 100644
--- a/testsuites/libtests/termios02/termios02.doc
+++ b/testsuites/libtests/termios02/termios02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios03/termios03.doc b/testsuites/libtests/termios03/termios03.doc
index 5905f8cd6c..0e30571dc4 100644
--- a/testsuites/libtests/termios03/termios03.doc
+++ b/testsuites/libtests/termios03/termios03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios04/termios04.doc b/testsuites/libtests/termios04/termios04.doc
index 3ad36a49d7..823c0d816e 100644
--- a/testsuites/libtests/termios04/termios04.doc
+++ b/testsuites/libtests/termios04/termios04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios05/termios05.doc b/testsuites/libtests/termios05/termios05.doc
index 009a288664..08ae1d5ee1 100644
--- a/testsuites/libtests/termios05/termios05.doc
+++ b/testsuites/libtests/termios05/termios05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios06/termios06.doc b/testsuites/libtests/termios06/termios06.doc
index 9bedda7a0b..beaf0ea64c 100644
--- a/testsuites/libtests/termios06/termios06.doc
+++ b/testsuites/libtests/termios06/termios06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios07/termios07.doc b/testsuites/libtests/termios07/termios07.doc
index 938a12636f..05550e0209 100644
--- a/testsuites/libtests/termios07/termios07.doc
+++ b/testsuites/libtests/termios07/termios07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/termios08/termios08.doc b/testsuites/libtests/termios08/termios08.doc
index 2a7eb09594..9fd2e1c340 100644
--- a/testsuites/libtests/termios08/termios08.doc
+++ b/testsuites/libtests/termios08/termios08.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/libtests/uid01/init.c b/testsuites/libtests/uid01/init.c
index fcc3071345..be6b026f00 100644
--- a/testsuites/libtests/uid01/init.c
+++ b/testsuites/libtests/uid01/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013 Daniel Ramirez <javamonn at gmail.com>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/libtests/uid01/msmouse.c b/testsuites/libtests/uid01/msmouse.c
index 35cbc2452e..18732ee534 100644
--- a/testsuites/libtests/uid01/msmouse.c
+++ b/testsuites/libtests/uid01/msmouse.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/uid01/serial_mouse_config.c b/testsuites/libtests/uid01/serial_mouse_config.c
index 78c8602257..b05d303ade 100644
--- a/testsuites/libtests/uid01/serial_mouse_config.c
+++ b/testsuites/libtests/uid01/serial_mouse_config.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/libtests/uid01/uid01.doc b/testsuites/libtests/uid01/uid01.doc
index a86a00a8f0..7c266dc406 100644
--- a/testsuites/libtests/uid01/uid01.doc
+++ b/testsuites/libtests/uid01/uid01.doc
@@ -1,8 +1,27 @@
 # Copyright (c) 2013 Daniel Ramirez <javamonn at gmail.com>
+# are met:
diff --git a/testsuites/libtests/utf8proc01/utf8proc01.doc b/testsuites/libtests/utf8proc01/utf8proc01.doc
index 099c98905d..ac573f49a1 100644
--- a/testsuites/libtests/utf8proc01/utf8proc01.doc
+++ b/testsuites/libtests/utf8proc01/utf8proc01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2013.
+# are met:
2.24.4
