[PATCH 20/39] testsuites/libtests/*/*.dts. stackchk02.doc: Change license to BSD-2
Fri Apr 8 14:45:48 UTC 2022
Updates #3053.
 testsuites/libtests/libfdt01/some.dts         | 25 ++++++++++++++++---
 testsuites/libtests/ofw01/some.dts            | 25 ++++++++++++++++---
 testsuites/libtests/stackchk02/stackchk02.doc | 25 ++++++++++++++++---
 3 files changed, 66 insertions(+), 9 deletions(-)
diff --git a/testsuites/libtests/libfdt01/some.dts b/testsuites/libtests/libfdt01/some.dts
index 92f0387215..c6e2fc84ad 100644
--- a/testsuites/libtests/libfdt01/some.dts
+++ b/testsuites/libtests/libfdt01/some.dts
@@ -1,9 +1,28 @@
  * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 /dts-v1/;
diff --git a/testsuites/libtests/ofw01/some.dts b/testsuites/libtests/ofw01/some.dts
index 5272cb1dfd..e828622d02 100644
--- a/testsuites/libtests/ofw01/some.dts
+++ b/testsuites/libtests/ofw01/some.dts
@@ -1,10 +1,29 @@
  * Copyright (c) 2020 Niteesh G S <niteesh.gs at gmail.com>.  All rights reserved.
+ * are met:
 /dts-v1/;
diff --git a/testsuites/libtests/stackchk02/stackchk02.doc b/testsuites/libtests/stackchk02/stackchk02.doc
index 7907f216a8..e2fca9d890 100644
--- a/testsuites/libtests/stackchk02/stackchk02.doc
+++ b/testsuites/libtests/stackchk02/stackchk02.doc
@@ -1,8 +1,27 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 2022.
 #  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This file describes the directives and concepts tested by this test set.
2.24.4
