[PATCH 21/39] testsuites/fstests/*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:49 UTC 2022
Updates #3053.
testsuites/fstests/fsbdpart01/fsbdpart01.doc | 25 ++++++++++++++++---
.../fsdosfsformat01/fsdosfsformat01.doc | 25 ++++++++++++++++---
testsuites/fstests/fsdosfsformat01/init.c | 23 ++++++++++++++---
.../fstests/fsdosfsname01/create_files.cs | 25 ++++++++++++++++---
.../fstests/fsdosfssync01/fsdosfssync01.doc | 25 ++++++++++++++++---
testsuites/fstests/fserror/fserror.doc | 25 ++++++++++++++++---
.../fstests/fsfpathconf/fsfpathconf.doc | 25 ++++++++++++++++---
testsuites/fstests/fsfpathconf/test.c | 25 ++++++++++++++++---
testsuites/fstests/fslink/fslink.doc | 25 ++++++++++++++++---
testsuites/fstests/fsnofs01/fsnofs01.doc | 25 ++++++++++++++++---
testsuites/fstests/fspatheval/patheval.doc | 25 ++++++++++++++++---
.../fstests/fspermission/fspermission.doc | 25 ++++++++++++++++---
testsuites/fstests/fsrdwr/fsrdwr.doc | 25 ++++++++++++++++---
testsuites/fstests/fsrename/fsrename.doc | 25 ++++++++++++++++---
testsuites/fstests/fsrename/test.c | 25 ++++++++++++++++---
.../fstests/fsrfsbitmap01/fsrfsbitmap01.doc | 25 ++++++++++++++++---
testsuites/fstests/fsstatvfs/fsstatvfs.doc | 25 ++++++++++++++++---
testsuites/fstests/fsstatvfs/test.c | 25 ++++++++++++++++---
testsuites/fstests/fssymlink/fssymlink.doc | 25 ++++++++++++++++---
testsuites/fstests/fstime/fstime.doc | 25 ++++++++++++++++---
20 files changed, 438 insertions(+), 60 deletions(-)
diff --git a/testsuites/fstests/fsbdpart01/fsbdpart01.doc b/testsuites/fstests/fsbdpart01/fsbdpart01.doc
index a99b5a2bb4..5c4d20ebc9 100644
--- a/testsuites/fstests/fsbdpart01/fsbdpart01.doc
+++ b/testsuites/fstests/fsbdpart01/fsbdpart01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
# COPYRIGHT (c) 2014.
# On-Line Applications Research Corporation (OAR).
# Cynthia Rempel <cynthia at rtems.org>
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
diff --git a/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc b/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc
index c24c138ae8..016482e393 100644
--- a/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc
+++ b/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc
@@ -1,9 +1,28 @@
+# are met:
This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index 8f62960976..1fe39d1d06 100644
--- a/testsuites/fstests/fsdosfsformat01/init.c
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -3,9 +3,26 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
- * The license and distribution terms for this file_name may be
- * found in the file_name LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/fstests/fsdosfsname01/create_files.cs b/testsuites/fstests/fsdosfsname01/create_files.cs
index 12bc84209d..3f16aefc04 100644
--- a/testsuites/fstests/fsdosfsname01/create_files.cs
+++ b/testsuites/fstests/fsdosfsname01/create_files.cs
@@ -1,3 +1,5 @@
* @file Create_Files.cs
@@ -14,9 +16,26 @@
* Copyright (c) 2013 embedded brains GmbH. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
+ * are met:
using System;
using System.Collections.Generic;
diff --git a/testsuites/fstests/fsdosfssync01/fsdosfssync01.doc b/testsuites/fstests/fsdosfssync01/fsdosfssync01.doc
index 603409601f..bbecc00b86 100644
--- a/testsuites/fstests/fsdosfssync01/fsdosfssync01.doc
+++ b/testsuites/fstests/fsdosfssync01/fsdosfssync01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fserror/fserror.doc b/testsuites/fstests/fserror/fserror.doc
index 4ff12ddad9..9324b2d354 100644
--- a/testsuites/fstests/fserror/fserror.doc
+++ b/testsuites/fstests/fserror/fserror.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2009.
+# are met:
diff --git a/testsuites/fstests/fsfpathconf/fsfpathconf.doc b/testsuites/fstests/fsfpathconf/fsfpathconf.doc
index 3b488b47a6..4aeb642d52 100644
--- a/testsuites/fstests/fsfpathconf/fsfpathconf.doc
+++ b/testsuites/fstests/fsfpathconf/fsfpathconf.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 2012.
# Krzysztof Miesowicz <krzysztof.miesowicz at gmail.com>
+# are met:
diff --git a/testsuites/fstests/fsfpathconf/test.c b/testsuites/fstests/fsfpathconf/test.c
index 8201779cdd..a3a1b22132 100644
--- a/testsuites/fstests/fsfpathconf/test.c
+++ b/testsuites/fstests/fsfpathconf/test.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2012 - .
* Krzysztof Miesowicz <krzysztof.miesowicz at gmail.com>
+ * are met:
diff --git a/testsuites/fstests/fslink/fslink.doc b/testsuites/fstests/fslink/fslink.doc
index 291902f56b..008330af70 100644
--- a/testsuites/fstests/fslink/fslink.doc
+++ b/testsuites/fstests/fslink/fslink.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fsnofs01/fsnofs01.doc b/testsuites/fstests/fsnofs01/fsnofs01.doc
index 3a47c46a22..bae48d8231 100644
--- a/testsuites/fstests/fsnofs01/fsnofs01.doc
+++ b/testsuites/fstests/fsnofs01/fsnofs01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fspatheval/patheval.doc b/testsuites/fstests/fspatheval/patheval.doc
index 1443e00aa8..04a2b3112f 100644
--- a/testsuites/fstests/fspatheval/patheval.doc
+++ b/testsuites/fstests/fspatheval/patheval.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fspermission/fspermission.doc b/testsuites/fstests/fspermission/fspermission.doc
index 46cbc8c623..848b6ed9df 100644
--- a/testsuites/fstests/fspermission/fspermission.doc
+++ b/testsuites/fstests/fspermission/fspermission.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fsrdwr/fsrdwr.doc b/testsuites/fstests/fsrdwr/fsrdwr.doc
index 5bf6bec18e..ab03dd8bba 100644
--- a/testsuites/fstests/fsrdwr/fsrdwr.doc
+++ b/testsuites/fstests/fsrdwr/fsrdwr.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2011.
+# are met:
diff --git a/testsuites/fstests/fsrename/fsrename.doc b/testsuites/fstests/fsrename/fsrename.doc
index 8d3a4df48e..373f62278c 100644
--- a/testsuites/fstests/fsrename/fsrename.doc
+++ b/testsuites/fstests/fsrename/fsrename.doc
@@ -1,9 +1,28 @@
# Andre Marques <andre.lousa.marques at gmail.com>
+# are met:
diff --git a/testsuites/fstests/fsrename/test.c b/testsuites/fstests/fsrename/test.c
index ceeb242ce4..bdb3a7a3de 100644
--- a/testsuites/fstests/fsrename/test.c
+++ b/testsuites/fstests/fsrename/test.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2014
* Andre Marques <andre.lousa.marques at gmail.com>
+ * are met:
diff --git a/testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc b/testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc
index 90810ba921..3f03a3f62b 100644
--- a/testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc
+++ b/testsuites/fstests/fsrfsbitmap01/fsrfsbitmap01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fsstatvfs/fsstatvfs.doc b/testsuites/fstests/fsstatvfs/fsstatvfs.doc
index 492edae1d9..c99bc8eb7d 100644
--- a/testsuites/fstests/fsstatvfs/fsstatvfs.doc
+++ b/testsuites/fstests/fsstatvfs/fsstatvfs.doc
@@ -1,8 +1,27 @@
# COPYRIGHT (c) 2013 Andrey Mozzhuhin
+# are met:
diff --git a/testsuites/fstests/fsstatvfs/test.c b/testsuites/fstests/fsstatvfs/test.c
index 2dc7998884..e5c4b94a26 100644
--- a/testsuites/fstests/fsstatvfs/test.c
+++ b/testsuites/fstests/fsstatvfs/test.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2013 Andrey Mozzhuhin
+ * are met:
diff --git a/testsuites/fstests/fssymlink/fssymlink.doc b/testsuites/fstests/fssymlink/fssymlink.doc
index ea022d1b61..f139dadc01 100644
--- a/testsuites/fstests/fssymlink/fssymlink.doc
+++ b/testsuites/fstests/fssymlink/fssymlink.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/fstests/fstime/fstime.doc b/testsuites/fstests/fstime/fstime.doc
index d4c34022e9..6b0732bd11 100644
--- a/testsuites/fstests/fstime/fstime.doc
+++ b/testsuites/fstests/fstime/fstime.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
