[PATCH 23/39] testsuites/psxtests/psx[01]*: Change license to BSD-2
    Joel Sherrill
    joel at rtems.org
    Fri Apr  8 14:45:51 UTC 2022
Updates #3053.
 testsuites/psxtests/psx01/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx01/psx01.doc | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx01/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx01/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx02/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx02/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx02/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx03/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx03/psx03.doc |  2 ++
 testsuites/psxtests/psx03/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx03/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx04/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx04/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx04/task1.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx04/task2.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx04/task3.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx05/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx05/psx05.doc | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx05/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx05/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx05/task2.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx05/task3.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx06/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx06/psx06.doc |  2 ++
 testsuites/psxtests/psx06/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx06/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx06/task2.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx07/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx07/psx07.doc | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx07/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx07/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx08/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx08/psx08.doc |  2 ++
 testsuites/psxtests/psx08/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx08/task1.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx08/task2.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx08/task3.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx09/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx09/psx09.doc |  2 ++
 testsuites/psxtests/psx09/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx10/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx10/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx10/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx10/task2.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx10/task3.c   | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx11/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx11/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx11/task.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx12/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx14/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx14/psx14.doc | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx14/system.h  | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx15/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx16/init.c    | 25 ++++++++++++++++++++++---
 testsuites/psxtests/psx16/psx16.doc | 25 ++++++++++++++++++++++---
 55 files changed, 1130 insertions(+), 153 deletions(-)
diff --git a/testsuites/psxtests/psx01/init.c b/testsuites/psxtests/psx01/init.c
index 2b2fafd0cd..9aaa1c567d 100644
--- a/testsuites/psxtests/psx01/init.c
+++ b/testsuites/psxtests/psx01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psx01/psx01.doc b/testsuites/psxtests/psx01/psx01.doc
index 8f764aadd2..cea29799c7 100644
--- a/testsuites/psxtests/psx01/psx01.doc
+++ b/testsuites/psxtests/psx01/psx01.doc
@@ -1,11 +1,30 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  testsuites/psxtests/psx01/psx01.doc
 #  COPYRIGHT (c) 1989-2009.
 #  On-Line Applications Research Corporation (OAR).
 #  Copyright (c) 2013 Annelies Odermann <annelies.odermann at gmail.com>
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/psxtests/psx01/system.h b/testsuites/psxtests/psx01/system.h
index d0507dfac4..7b81946357 100644
--- a/testsuites/psxtests/psx01/system.h
+++ b/testsuites/psxtests/psx01/system.h
@@ -1,3 +1,5 @@
 /*  system.h
  *  This include file contains information that is included in every
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx01/task.c b/testsuites/psxtests/psx01/task.c
index 3aa88fe882..4e0cd46983 100644
--- a/testsuites/psxtests/psx01/task.c
+++ b/testsuites/psxtests/psx01/task.c
@@ -1,3 +1,5 @@
 /*  Task_1_through_3
  *  This routine serves as a test task.  It verifies the basic task
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx02/init.c b/testsuites/psxtests/psx02/init.c
index 0d2ab06c7e..c2df2baefa 100644
--- a/testsuites/psxtests/psx02/init.c
+++ b/testsuites/psxtests/psx02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx02/system.h b/testsuites/psxtests/psx02/system.h
index 22365ba76f..22165a2056 100644
--- a/testsuites/psxtests/psx02/system.h
+++ b/testsuites/psxtests/psx02/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx02/task.c b/testsuites/psxtests/psx02/task.c
index e62c338478..5652bc4904 100644
--- a/testsuites/psxtests/psx02/task.c
+++ b/testsuites/psxtests/psx02/task.c
@@ -1,3 +1,5 @@
 /*  Task_1_through_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx03/init.c b/testsuites/psxtests/psx03/init.c
index 5c5383ccfc..482c2b1d18 100644
--- a/testsuites/psxtests/psx03/init.c
+++ b/testsuites/psxtests/psx03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx03/psx03.doc b/testsuites/psxtests/psx03/psx03.doc
index a77efb2559..b23b1855c7 100644
--- a/testsuites/psxtests/psx03/psx03.doc
+++ b/testsuites/psxtests/psx03/psx03.doc
@@ -1,3 +1,5 @@
 #  /testsuites/psxtests/psx03/psx03.scn
 #  Copyright (c) 2013 Rishi Sharma <rishisharma7361 at gmail.com>.
diff --git a/testsuites/psxtests/psx03/system.h b/testsuites/psxtests/psx03/system.h
index 7949d4c3c0..271b488fcb 100644
--- a/testsuites/psxtests/psx03/system.h
+++ b/testsuites/psxtests/psx03/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx03/task.c b/testsuites/psxtests/psx03/task.c
index 94f345b338..b6bdae640f 100644
--- a/testsuites/psxtests/psx03/task.c
+++ b/testsuites/psxtests/psx03/task.c
@@ -1,3 +1,5 @@
 /*  Task_1_through_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx04/init.c b/testsuites/psxtests/psx04/init.c
index 76c76af55b..7f196ef716 100644
--- a/testsuites/psxtests/psx04/init.c
+++ b/testsuites/psxtests/psx04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx04/system.h b/testsuites/psxtests/psx04/system.h
index 630ac9178d..afaa8fc283 100644
--- a/testsuites/psxtests/psx04/system.h
+++ b/testsuites/psxtests/psx04/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx04/task1.c b/testsuites/psxtests/psx04/task1.c
index 92eb9fe1b0..565c19701e 100644
--- a/testsuites/psxtests/psx04/task1.c
+++ b/testsuites/psxtests/psx04/task1.c
@@ -1,3 +1,5 @@
 /*  Task_1
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx04/task2.c b/testsuites/psxtests/psx04/task2.c
index 3e6ef83576..da240177fa 100644
--- a/testsuites/psxtests/psx04/task2.c
+++ b/testsuites/psxtests/psx04/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx04/task3.c b/testsuites/psxtests/psx04/task3.c
index 5d4172cb2e..df207460f4 100644
--- a/testsuites/psxtests/psx04/task3.c
+++ b/testsuites/psxtests/psx04/task3.c
@@ -1,3 +1,5 @@
 /*  Task_3
@@ -10,9 +12,26 @@
  *  COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/testsuites/psxtests/psx05/init.c b/testsuites/psxtests/psx05/init.c
index 4c1603daf3..96a7b2740b 100644
--- a/testsuites/psxtests/psx05/init.c
+++ b/testsuites/psxtests/psx05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx05/psx05.doc b/testsuites/psxtests/psx05/psx05.doc
index 3f908d74fc..e5016ec318 100644
--- a/testsuites/psxtests/psx05/psx05.doc
+++ b/testsuites/psxtests/psx05/psx05.doc
@@ -1,11 +1,30 @@
 #  testsuites/psxtests/psx05/psx05.doc
 #  Copyright (c) 2013 Chirayu Desai <chirayudesai1 at gmail.com>.
+# are met:
diff --git a/testsuites/psxtests/psx05/system.h b/testsuites/psxtests/psx05/system.h
index 58265150c3..91787096c3 100644
--- a/testsuites/psxtests/psx05/system.h
+++ b/testsuites/psxtests/psx05/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx05/task.c b/testsuites/psxtests/psx05/task.c
index 09df524297..48a36a3dbc 100644
--- a/testsuites/psxtests/psx05/task.c
+++ b/testsuites/psxtests/psx05/task.c
@@ -1,3 +1,5 @@
 /*  Task_1
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx05/task2.c b/testsuites/psxtests/psx05/task2.c
index 1ab2c49b41..0dd7211ae5 100644
--- a/testsuites/psxtests/psx05/task2.c
+++ b/testsuites/psxtests/psx05/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx05/task3.c b/testsuites/psxtests/psx05/task3.c
index c505872a26..ee0d0e553a 100644
--- a/testsuites/psxtests/psx05/task3.c
+++ b/testsuites/psxtests/psx05/task3.c
@@ -1,3 +1,5 @@
 /*  Task_3
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx06/init.c b/testsuites/psxtests/psx06/init.c
index e077a28597..2ec5983e9b 100644
--- a/testsuites/psxtests/psx06/init.c
+++ b/testsuites/psxtests/psx06/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx06/psx06.doc b/testsuites/psxtests/psx06/psx06.doc
index 71148d152b..f3e6ec1644 100644
--- a/testsuites/psxtests/psx06/psx06.doc
+++ b/testsuites/psxtests/psx06/psx06.doc
@@ -1,3 +1,5 @@
 #  testsuites/psxtests/psx06/psx06.doc
diff --git a/testsuites/psxtests/psx06/system.h b/testsuites/psxtests/psx06/system.h
index 8bcaff7d38..6740815347 100644
--- a/testsuites/psxtests/psx06/system.h
+++ b/testsuites/psxtests/psx06/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx06/task.c b/testsuites/psxtests/psx06/task.c
index d4eb255fcb..9c02dfaa09 100644
--- a/testsuites/psxtests/psx06/task.c
+++ b/testsuites/psxtests/psx06/task.c
@@ -1,3 +1,5 @@
 /*  Task_1
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx06/task2.c b/testsuites/psxtests/psx06/task2.c
index c0b14d4fc0..213f21d4ac 100644
--- a/testsuites/psxtests/psx06/task2.c
+++ b/testsuites/psxtests/psx06/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx07/init.c b/testsuites/psxtests/psx07/init.c
index 16d1fa260c..22f74ecac8 100644
--- a/testsuites/psxtests/psx07/init.c
+++ b/testsuites/psxtests/psx07/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx07/psx07.doc b/testsuites/psxtests/psx07/psx07.doc
index a1462fadc0..fd699af531 100644
--- a/testsuites/psxtests/psx07/psx07.doc
+++ b/testsuites/psxtests/psx07/psx07.doc
@@ -1,10 +1,29 @@
 #  Copyright (c) 2013 Annelies Odermann <annelies.odermann at gmail.com>.
+# are met:
diff --git a/testsuites/psxtests/psx07/system.h b/testsuites/psxtests/psx07/system.h
index ee297e019d..06b519b366 100644
--- a/testsuites/psxtests/psx07/system.h
+++ b/testsuites/psxtests/psx07/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx07/task.c b/testsuites/psxtests/psx07/task.c
index 41e215f495..b4735edb9c 100644
--- a/testsuites/psxtests/psx07/task.c
+++ b/testsuites/psxtests/psx07/task.c
@@ -1,3 +1,5 @@
 /*  Task_1
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx08/init.c b/testsuites/psxtests/psx08/init.c
index 781ac1ed30..b4b22a5338 100644
--- a/testsuites/psxtests/psx08/init.c
+++ b/testsuites/psxtests/psx08/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx08/psx08.doc b/testsuites/psxtests/psx08/psx08.doc
index 52fada3ed1..121ea1bfa1 100644
--- a/testsuites/psxtests/psx08/psx08.doc
+++ b/testsuites/psxtests/psx08/psx08.doc
@@ -1,3 +1,5 @@
 #  testsuites/psxtests/psx08/psx08.doc
diff --git a/testsuites/psxtests/psx08/system.h b/testsuites/psxtests/psx08/system.h
index 127febe449..72a77f0dc5 100644
--- a/testsuites/psxtests/psx08/system.h
+++ b/testsuites/psxtests/psx08/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx08/task1.c b/testsuites/psxtests/psx08/task1.c
index eb6c9c654b..e958403f01 100644
--- a/testsuites/psxtests/psx08/task1.c
+++ b/testsuites/psxtests/psx08/task1.c
@@ -1,3 +1,5 @@
 /*  Task_1
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx08/task2.c b/testsuites/psxtests/psx08/task2.c
index 37fe5f29fe..6123fbccc1 100644
--- a/testsuites/psxtests/psx08/task2.c
+++ b/testsuites/psxtests/psx08/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx08/task3.c b/testsuites/psxtests/psx08/task3.c
index acbdb9951f..682285cd30 100644
--- a/testsuites/psxtests/psx08/task3.c
+++ b/testsuites/psxtests/psx08/task3.c
@@ -1,3 +1,5 @@
 /*  Task_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx09/init.c b/testsuites/psxtests/psx09/init.c
index d9226c9abb..cd49ba27d4 100644
--- a/testsuites/psxtests/psx09/init.c
+++ b/testsuites/psxtests/psx09/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx09/psx09.doc b/testsuites/psxtests/psx09/psx09.doc
index b90367b669..1d20c18694 100644
--- a/testsuites/psxtests/psx09/psx09.doc
+++ b/testsuites/psxtests/psx09/psx09.doc
@@ -1,3 +1,5 @@
diff --git a/testsuites/psxtests/psx09/system.h b/testsuites/psxtests/psx09/system.h
index aa03a1822d..ebe78ae557 100644
--- a/testsuites/psxtests/psx09/system.h
+++ b/testsuites/psxtests/psx09/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx10/init.c b/testsuites/psxtests/psx10/init.c
index ad4e60e385..90ed097133 100644
--- a/testsuites/psxtests/psx10/init.c
+++ b/testsuites/psxtests/psx10/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx10/system.h b/testsuites/psxtests/psx10/system.h
index da720f1dd2..e3db02421f 100644
--- a/testsuites/psxtests/psx10/system.h
+++ b/testsuites/psxtests/psx10/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx10/task.c b/testsuites/psxtests/psx10/task.c
index 1df57e590e..1d1775ea24 100644
--- a/testsuites/psxtests/psx10/task.c
+++ b/testsuites/psxtests/psx10/task.c
@@ -1,3 +1,5 @@
 /*  Task_1
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx10/task2.c b/testsuites/psxtests/psx10/task2.c
index ddcb23677c..88091df4c1 100644
--- a/testsuites/psxtests/psx10/task2.c
+++ b/testsuites/psxtests/psx10/task2.c
@@ -1,3 +1,5 @@
 /*  Task_2
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx10/task3.c b/testsuites/psxtests/psx10/task3.c
index 7f1851166f..2f7488503f 100644
--- a/testsuites/psxtests/psx10/task3.c
+++ b/testsuites/psxtests/psx10/task3.c
@@ -1,3 +1,5 @@
 /*  Task_3
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psx11/init.c b/testsuites/psxtests/psx11/init.c
index 9adde6e25b..fd5b0185cf 100644
--- a/testsuites/psxtests/psx11/init.c
+++ b/testsuites/psxtests/psx11/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx11/system.h b/testsuites/psxtests/psx11/system.h
index f1995a989f..83f5e9e356 100644
--- a/testsuites/psxtests/psx11/system.h
+++ b/testsuites/psxtests/psx11/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx11/task.c b/testsuites/psxtests/psx11/task.c
index 07577a5d24..bf0412afc9 100644
--- a/testsuites/psxtests/psx11/task.c
+++ b/testsuites/psxtests/psx11/task.c
@@ -1,3 +1,5 @@
  *  @file
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/psxtests/psx12/init.c b/testsuites/psxtests/psx12/init.c
index be0b8d6412..76737b0c3b 100644
--- a/testsuites/psxtests/psx12/init.c
+++ b/testsuites/psxtests/psx12/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx14/init.c b/testsuites/psxtests/psx14/init.c
index 070501f065..7e387f64aa 100644
--- a/testsuites/psxtests/psx14/init.c
+++ b/testsuites/psxtests/psx14/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/testsuites/psxtests/psx14/psx14.doc b/testsuites/psxtests/psx14/psx14.doc
index 612ca2c210..ab20790532 100644
--- a/testsuites/psxtests/psx14/psx14.doc
+++ b/testsuites/psxtests/psx14/psx14.doc
@@ -1,10 +1,29 @@
 #  testsuites/psxtests/psx14/psx14.doc
 #  Copyright (c) 2013 Mandar Juvekar <mjuvekar0 at gmail.com>.
+# are met:
diff --git a/testsuites/psxtests/psx14/system.h b/testsuites/psxtests/psx14/system.h
index f44b630c30..c919cde13e 100644
--- a/testsuites/psxtests/psx14/system.h
+++ b/testsuites/psxtests/psx14/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psx15/init.c b/testsuites/psxtests/psx15/init.c
index 10611f18b2..e6ade823f7 100644
--- a/testsuites/psxtests/psx15/init.c
+++ b/testsuites/psxtests/psx15/init.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/psxtests/psx16/init.c b/testsuites/psxtests/psx16/init.c
index 8e20e6d376..1914186dee 100644
--- a/testsuites/psxtests/psx16/init.c
+++ b/testsuites/psxtests/psx16/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psx16/psx16.doc b/testsuites/psxtests/psx16/psx16.doc
index cb23efee10..73efd1b66d 100644
--- a/testsuites/psxtests/psx16/psx16.doc
+++ b/testsuites/psxtests/psx16/psx16.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2011.
+# are met:
2.24.4
