[PATCH 24/39] testsuites/psxtests/psx[a-f]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:52 UTC 2022
Updates #3053.
testsuites/psxtests/psxaio01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxaio01/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxaio02/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxaio02/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxaio03/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxaio03/system.h | 2 ++
testsuites/psxtests/psxalarm01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxalarm01/psxalarm01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxautoinit01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxautoinit02/init.c | 25 ++++++++++++++++---
.../psxtests/psxautoinit02/psxautoinit02.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxbarrier01/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxbarrier01/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxcancel/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxcancel/psxcancel.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxcancel01/init.c | 25 ++++++++++++++++---
.../psxtests/psxcancel01/psxcancel01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxchroot01/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxclassic01/init.c | 25 ++++++++++++++++---
.../psxtests/psxclassic01/psxclassic01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxcleanup/psxcleanup.c | 25 ++++++++++++++++---
testsuites/psxtests/psxcleanup/psxcleanup.doc | 2 ++
testsuites/psxtests/psxcleanup/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxcleanup01/init.c | 25 ++++++++++++++++---
.../psxtests/psxcleanup01/psxcleanup01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxclock/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxclock/psxclock.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxclock01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxconcurrency01/init.c | 25 ++++++++++++++++---
.../psxconcurrency01/psxconcurrency01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxcond01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxcond01/psxcond01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxcond02/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxcond02/psxcond02.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxconfig01/init.c | 25 ++++++++++++++++---
.../psxtests/psxconfig01/psxconfig01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxdevctl01/main.c | 25 ++++++++++++++++---
.../psxtests/psxdevctl01/psxdevctl01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxdevctl01/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxeintr_join/init.c | 25 ++++++++++++++++---
.../psxtests/psxeintr_join/psxeintr_join.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxenosys/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxenosys/psxenosys.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxenosys/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxfatal01/psxfatal01.doc | 25 ++++++++++++++++---
.../psxtests/psxfatal_support/psxfatal.h | 25 ++++++++++++++++---
.../psxtests/psxfatal_support/psxfatalimpl.h | 25 ++++++++++++++++---
testsuites/psxtests/psxfchx01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfchx01/psxfchx01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxfile01/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfile01/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfile01/test_cat.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfile01/test_extend.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfile01/test_write.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfile02/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxfile02/psxfile02.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxfilelock01/init.c | 25 ++++++++++++++++---
.../psxtests/psxfilelock01/psxfilelock01.doc | 25 ++++++++++++++++---
58 files changed, 1236 insertions(+), 168 deletions(-)
diff --git a/testsuites/psxtests/psxaio01/init.c b/testsuites/psxtests/psxaio01/init.c
index 283507f9cd..d9b5c8d54f 100644
--- a/testsuites/psxtests/psxaio01/init.c
+++ b/testsuites/psxtests/psxaio01/init.c
@@ -1,9 +1,28 @@
* Copyright 2010, Alin Rus <alin.codejunkie at gmail.com>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxaio01/system.h b/testsuites/psxtests/psxaio01/system.h
index 2197339a7c..70224470e9 100644
--- a/testsuites/psxtests/psxaio01/system.h
+++ b/testsuites/psxtests/psxaio01/system.h
@@ -1,9 +1,28 @@
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxaio02/init.c b/testsuites/psxtests/psxaio02/init.c
index 3c75a365b5..0b416221c8 100644
--- a/testsuites/psxtests/psxaio02/init.c
+++ b/testsuites/psxtests/psxaio02/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxaio02/system.h b/testsuites/psxtests/psxaio02/system.h
--- a/testsuites/psxtests/psxaio02/system.h
+++ b/testsuites/psxtests/psxaio02/system.h
@@ -1,9 +1,28 @@
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxaio03/init.c b/testsuites/psxtests/psxaio03/init.c
index 0893696962..082937ea4a 100644
--- a/testsuites/psxtests/psxaio03/init.c
+++ b/testsuites/psxtests/psxaio03/init.c
@@ -1,9 +1,28 @@
* Copyright 2011, Alin Rus <alin.codejunkie at gmail.com>
+ * are met:
diff --git a/testsuites/psxtests/psxaio03/system.h b/testsuites/psxtests/psxaio03/system.h
index 17baaf7f66..63f662eaf0 100644
--- a/testsuites/psxtests/psxaio03/system.h
+++ b/testsuites/psxtests/psxaio03/system.h
@@ -1,3 +1,5 @@
diff --git a/testsuites/psxtests/psxalarm01/init.c b/testsuites/psxtests/psxalarm01/init.c
index f9556faf07..4c5b344d97 100644
--- a/testsuites/psxtests/psxalarm01/init.c
+++ b/testsuites/psxtests/psxalarm01/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/testsuites/psxtests/psxalarm01/psxalarm01.doc b/testsuites/psxtests/psxalarm01/psxalarm01.doc
index 5db717cf77..2a5c91a4d8 100644
--- a/testsuites/psxtests/psxalarm01/psxalarm01.doc
+++ b/testsuites/psxtests/psxalarm01/psxalarm01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
# COPYRIGHT (c) 1989-2009.
# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/psxtests/psxautoinit01/init.c b/testsuites/psxtests/psxautoinit01/init.c
index f94879e60f..0e636b9e08 100644
--- a/testsuites/psxtests/psxautoinit01/init.c
+++ b/testsuites/psxtests/psxautoinit01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxautoinit02/init.c b/testsuites/psxtests/psxautoinit02/init.c
index d1a4d3a400..4f510c0408 100644
--- a/testsuites/psxtests/psxautoinit02/init.c
+++ b/testsuites/psxtests/psxautoinit02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxautoinit02/psxautoinit02.doc b/testsuites/psxtests/psxautoinit02/psxautoinit02.doc
index b1225fe819..ce5baf145b 100644
--- a/testsuites/psxtests/psxautoinit02/psxautoinit02.doc
+++ b/testsuites/psxtests/psxautoinit02/psxautoinit02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxbarrier01/main.c b/testsuites/psxtests/psxbarrier01/main.c
index 45d56d025b..d2cc3a01cf 100644
--- a/testsuites/psxtests/psxbarrier01/main.c
+++ b/testsuites/psxtests/psxbarrier01/main.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxbarrier01/test.c b/testsuites/psxtests/psxbarrier01/test.c
index 4253b21057..3bea278aac 100644
--- a/testsuites/psxtests/psxbarrier01/test.c
+++ b/testsuites/psxtests/psxbarrier01/test.c
@@ -1,3 +1,5 @@
* This test exercises the POSIX Barrier manager.
@@ -6,9 +8,26 @@
* Copyright (c) 2017 embedded brains GmbH
+ * are met:
diff --git a/testsuites/psxtests/psxcancel/init.c b/testsuites/psxtests/psxcancel/init.c
index afef141001..9ce17dbd2a 100644
--- a/testsuites/psxtests/psxcancel/init.c
+++ b/testsuites/psxtests/psxcancel/init.c
@@ -1,7 +1,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxcancel/psxcancel.doc b/testsuites/psxtests/psxcancel/psxcancel.doc
index af56bd9ff0..63ff11792a 100644
--- a/testsuites/psxtests/psxcancel/psxcancel.doc
+++ b/testsuites/psxtests/psxcancel/psxcancel.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxcancel01/init.c b/testsuites/psxtests/psxcancel01/init.c
index 83c4d5e1a5..258d20b1c2 100644
--- a/testsuites/psxtests/psxcancel01/init.c
+++ b/testsuites/psxtests/psxcancel01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxcancel01/psxcancel01.doc b/testsuites/psxtests/psxcancel01/psxcancel01.doc
index 701d003526..6c658cded4 100644
--- a/testsuites/psxtests/psxcancel01/psxcancel01.doc
+++ b/testsuites/psxtests/psxcancel01/psxcancel01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxchroot01/test.c b/testsuites/psxtests/psxchroot01/test.c
index e7c8bbe1cf..8270bf5b58 100644
--- a/testsuites/psxtests/psxchroot01/test.c
+++ b/testsuites/psxtests/psxchroot01/test.c
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
* Modifications to support reference counting in the file system are
* Copyright (c) 2012 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/psxtests/psxclassic01/init.c b/testsuites/psxtests/psxclassic01/init.c
index 04a77b1c30..1324146a6e 100644
--- a/testsuites/psxtests/psxclassic01/init.c
+++ b/testsuites/psxtests/psxclassic01/init.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#define _GNU_SOURCE
diff --git a/testsuites/psxtests/psxclassic01/psxclassic01.doc b/testsuites/psxtests/psxclassic01/psxclassic01.doc
index dd08967493..ef88e93d60 100644
--- a/testsuites/psxtests/psxclassic01/psxclassic01.doc
+++ b/testsuites/psxtests/psxclassic01/psxclassic01.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2011.
+# are met:
diff --git a/testsuites/psxtests/psxcleanup/psxcleanup.c b/testsuites/psxtests/psxcleanup/psxcleanup.c
index 2af4aaf78d..e52a02d77d 100644
--- a/testsuites/psxtests/psxcleanup/psxcleanup.c
+++ b/testsuites/psxtests/psxcleanup/psxcleanup.c
@@ -1,12 +1,31 @@
* This is a simple real-time applications XXX.
* Other POSIX facilities such as XXX, condition, .. is also used
+ * are met:
diff --git a/testsuites/psxtests/psxcleanup/psxcleanup.doc b/testsuites/psxtests/psxcleanup/psxcleanup.doc
index 92c43576fe..c63576f632 100644
--- a/testsuites/psxtests/psxcleanup/psxcleanup.doc
+++ b/testsuites/psxtests/psxcleanup/psxcleanup.doc
@@ -1,3 +1,5 @@
# testsuites/psxtests/psxcleanup/psxcleanup.doc
# Copyright (c) 2013 Anukul Sangwan <email.anukul at gmail.com>.
diff --git a/testsuites/psxtests/psxcleanup/system.h b/testsuites/psxtests/psxcleanup/system.h
index 19dde2f0be..c6d37e0c56 100644
--- a/testsuites/psxtests/psxcleanup/system.h
+++ b/testsuites/psxtests/psxcleanup/system.h
@@ -1,11 +1,30 @@
/* system.h
* This include file contains information that is included in every
* function in the test set.
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxcleanup01/init.c b/testsuites/psxtests/psxcleanup01/init.c
index b5e833b911..a6daa1fe3b 100644
--- a/testsuites/psxtests/psxcleanup01/init.c
+++ b/testsuites/psxtests/psxcleanup01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxcleanup01/psxcleanup01.doc b/testsuites/psxtests/psxcleanup01/psxcleanup01.doc
index 78aa310def..5ff73a638c 100644
--- a/testsuites/psxtests/psxcleanup01/psxcleanup01.doc
+++ b/testsuites/psxtests/psxcleanup01/psxcleanup01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxclock/init.c b/testsuites/psxtests/psxclock/init.c
index 66d938868b..2300056f61 100644
--- a/testsuites/psxtests/psxclock/init.c
+++ b/testsuites/psxtests/psxclock/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxclock/psxclock.doc b/testsuites/psxtests/psxclock/psxclock.doc
index 64932f4952..4bf8822e41 100644
--- a/testsuites/psxtests/psxclock/psxclock.doc
+++ b/testsuites/psxtests/psxclock/psxclock.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxclock01/init.c b/testsuites/psxtests/psxclock01/init.c
index 123774e1c6..0401745f14 100644
--- a/testsuites/psxtests/psxclock01/init.c
+++ b/testsuites/psxtests/psxclock01/init.c
@@ -1,9 +1,28 @@
* Copyright (C) 2015 Gedare Bloom.
+ * are met:
#include <tmacros.h>
diff --git a/testsuites/psxtests/psxconcurrency01/init.c b/testsuites/psxtests/psxconcurrency01/init.c
index 44aeb5f606..1f81530f54 100644
--- a/testsuites/psxtests/psxconcurrency01/init.c
+++ b/testsuites/psxtests/psxconcurrency01/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2016
+ * are met:
diff --git a/testsuites/psxtests/psxconcurrency01/psxconcurrency01.doc b/testsuites/psxtests/psxconcurrency01/psxconcurrency01.doc
index 62492adfc9..25122fab5c 100644
--- a/testsuites/psxtests/psxconcurrency01/psxconcurrency01.doc
+++ b/testsuites/psxtests/psxconcurrency01/psxconcurrency01.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 2016.
+# are met:
diff --git a/testsuites/psxtests/psxcond01/init.c b/testsuites/psxtests/psxcond01/init.c
index 4d21531c8a..b1905599cc 100644
--- a/testsuites/psxtests/psxcond01/init.c
+++ b/testsuites/psxtests/psxcond01/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2013.
+ * are met:
diff --git a/testsuites/psxtests/psxcond01/psxcond01.doc b/testsuites/psxtests/psxcond01/psxcond01.doc
index 5031b7ccdf..30b9643d03 100644
--- a/testsuites/psxtests/psxcond01/psxcond01.doc
+++ b/testsuites/psxtests/psxcond01/psxcond01.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2013.
+# are met:
diff --git a/testsuites/psxtests/psxcond02/init.c b/testsuites/psxtests/psxcond02/init.c
index aa6d973083..d141d63f93 100644
--- a/testsuites/psxtests/psxcond02/init.c
+++ b/testsuites/psxtests/psxcond02/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2016.
+ * are met:
diff --git a/testsuites/psxtests/psxcond02/psxcond02.doc b/testsuites/psxtests/psxcond02/psxcond02.doc
index 9e6f88a212..9be7ec1daf 100644
--- a/testsuites/psxtests/psxcond02/psxcond02.doc
+++ b/testsuites/psxtests/psxcond02/psxcond02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index a7a3ec823a..f1fcfe2b3b 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* Copyright (c) 2014. On-Line Applications Research Corporation (OAR).
* Copyright (c) 2011-2014 embedded brains GmbH. All rights reserved.
+ * are met:
#define _GNU_SOURCE
diff --git a/testsuites/psxtests/psxconfig01/psxconfig01.doc b/testsuites/psxtests/psxconfig01/psxconfig01.doc
index 9f45d91230..524c8a9994 100644
--- a/testsuites/psxtests/psxconfig01/psxconfig01.doc
+++ b/testsuites/psxtests/psxconfig01/psxconfig01.doc
@@ -1,8 +1,27 @@
# Copyright (c) 2011 embedded brains GmbH.
+# are met:
diff --git a/testsuites/psxtests/psxdevctl01/main.c b/testsuites/psxtests/psxdevctl01/main.c
index 54776e2b24..652e95c178 100644
--- a/testsuites/psxtests/psxdevctl01/main.c
+++ b/testsuites/psxtests/psxdevctl01/main.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxdevctl01/psxdevctl01.doc b/testsuites/psxtests/psxdevctl01/psxdevctl01.doc
index 51f295d2f1..0251bf6a61 100644
--- a/testsuites/psxtests/psxdevctl01/psxdevctl01.doc
+++ b/testsuites/psxtests/psxdevctl01/psxdevctl01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxdevctl01/test.c b/testsuites/psxtests/psxdevctl01/test.c
index 2fe7df1834..b1d0e7a16c 100644
--- a/testsuites/psxtests/psxdevctl01/test.c
+++ b/testsuites/psxtests/psxdevctl01/test.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#define _POSIX_26_C_SOURCE
diff --git a/testsuites/psxtests/psxeintr_join/init.c b/testsuites/psxtests/psxeintr_join/init.c
index 725a198c95..13210db1b4 100644
--- a/testsuites/psxtests/psxeintr_join/init.c
+++ b/testsuites/psxtests/psxeintr_join/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxeintr_join/psxeintr_join.doc b/testsuites/psxtests/psxeintr_join/psxeintr_join.doc
index 40aa43be2f..a9db7cc475 100644
--- a/testsuites/psxtests/psxeintr_join/psxeintr_join.doc
+++ b/testsuites/psxtests/psxeintr_join/psxeintr_join.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxenosys/init.c b/testsuites/psxtests/psxenosys/init.c
index 00148eb50f..40f83aa0f0 100644
--- a/testsuites/psxtests/psxenosys/init.c
+++ b/testsuites/psxtests/psxenosys/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/testsuites/psxtests/psxenosys/psxenosys.doc b/testsuites/psxtests/psxenosys/psxenosys.doc
index e90b97433f..6a5aad871c 100644
--- a/testsuites/psxtests/psxenosys/psxenosys.doc
+++ b/testsuites/psxtests/psxenosys/psxenosys.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxenosys/system.h b/testsuites/psxtests/psxenosys/system.h
index d0eaed6ca3..65458ef3f3 100644
--- a/testsuites/psxtests/psxenosys/system.h
+++ b/testsuites/psxtests/psxenosys/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxfatal01/psxfatal01.doc b/testsuites/psxtests/psxfatal01/psxfatal01.doc
index 067fc55a7e..0eac138dcc 100644
--- a/testsuites/psxtests/psxfatal01/psxfatal01.doc
+++ b/testsuites/psxtests/psxfatal01/psxfatal01.doc
@@ -1,10 +1,29 @@
# testsuites/psxtests/psxfatal01/psxfatal01.doc
# Copyright (c) 2013 Mandar Juvekar <mjuvekar0 at gmail.com>.
+# are met:
diff --git a/testsuites/psxtests/psxfatal_support/psxfatal.h b/testsuites/psxtests/psxfatal_support/psxfatal.h
index 253828bdbd..601d299f1a 100644
--- a/testsuites/psxtests/psxfatal_support/psxfatal.h
+++ b/testsuites/psxtests/psxfatal_support/psxfatal.h
@@ -1,10 +1,29 @@
+ * are met:
#include <rtems/bspIo.h>
diff --git a/testsuites/psxtests/psxfatal_support/psxfatalimpl.h b/testsuites/psxtests/psxfatal_support/psxfatalimpl.h
index 928b07f335..4ad3cbdd1a 100644
--- a/testsuites/psxtests/psxfatal_support/psxfatalimpl.h
+++ b/testsuites/psxtests/psxfatal_support/psxfatalimpl.h
@@ -1,10 +1,29 @@
+ * are met:
const char rtems_test_name[] = "PSXFATAL " FATAL_ERROR_TEST_NAME;
diff --git a/testsuites/psxtests/psxfchx01/init.c b/testsuites/psxtests/psxfchx01/init.c
index 081db4050e..5367ea06f0 100644
--- a/testsuites/psxtests/psxfchx01/init.c
+++ b/testsuites/psxtests/psxfchx01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfchx01/psxfchx01.doc b/testsuites/psxtests/psxfchx01/psxfchx01.doc
index d3a4e0133a..d28a5eb316 100644
--- a/testsuites/psxtests/psxfchx01/psxfchx01.doc
+++ b/testsuites/psxtests/psxfchx01/psxfchx01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxfile01/main.c b/testsuites/psxtests/psxfile01/main.c
index 1703602d39..abe6cd3869 100644
--- a/testsuites/psxtests/psxfile01/main.c
+++ b/testsuites/psxtests/psxfile01/main.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfile01/test.c b/testsuites/psxtests/psxfile01/test.c
index 121b08f648..0aa8b1c062 100644
--- a/testsuites/psxtests/psxfile01/test.c
+++ b/testsuites/psxtests/psxfile01/test.c
@@ -1,3 +1,5 @@
* @file
@@ -17,9 +19,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfile01/test_cat.c b/testsuites/psxtests/psxfile01/test_cat.c
index 9eade89374..c2b3c4bb25 100644
--- a/testsuites/psxtests/psxfile01/test_cat.c
+++ b/testsuites/psxtests/psxfile01/test_cat.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfile01/test_extend.c b/testsuites/psxtests/psxfile01/test_extend.c
index 86272b6114..45ee32bd67 100644
--- a/testsuites/psxtests/psxfile01/test_extend.c
+++ b/testsuites/psxtests/psxfile01/test_extend.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfile01/test_write.c b/testsuites/psxtests/psxfile01/test_write.c
index 1830da7480..1e7bcffea9 100644
--- a/testsuites/psxtests/psxfile01/test_write.c
+++ b/testsuites/psxtests/psxfile01/test_write.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfile02/init.c b/testsuites/psxtests/psxfile02/init.c
index e419d96310..96f72fc97e 100644
--- a/testsuites/psxtests/psxfile02/init.c
+++ b/testsuites/psxtests/psxfile02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfile02/psxfile02.doc b/testsuites/psxtests/psxfile02/psxfile02.doc
index 035b97b15f..2376ee9c1c 100644
--- a/testsuites/psxtests/psxfile02/psxfile02.doc
+++ b/testsuites/psxtests/psxfile02/psxfile02.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2010.
+# are met:
diff --git a/testsuites/psxtests/psxfilelock01/init.c b/testsuites/psxtests/psxfilelock01/init.c
index 6ad9818be6..98a39b8175 100644
--- a/testsuites/psxtests/psxfilelock01/init.c
+++ b/testsuites/psxtests/psxfilelock01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxfilelock01/psxfilelock01.doc b/testsuites/psxtests/psxfilelock01/psxfilelock01.doc
index 375d3bf2e0..2fcaded77d 100644
--- a/testsuites/psxtests/psxfilelock01/psxfilelock01.doc
+++ b/testsuites/psxtests/psxfilelock01/psxfilelock01.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
