[PATCH 29/39] testsuites/psxtests/psxhdrs/devctl/*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:57 UTC 2022
Updates #3053.
.../psxtests/psxhdrs/devctl/posix_devctl.c | 25 ++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/devctl/posix_devctl.c b/testsuites/psxtests/psxhdrs/devctl/posix_devctl.c
index db034599de..93826a8d5b 100644
--- a/testsuites/psxtests/psxhdrs/devctl/posix_devctl.c
+++ b/testsuites/psxtests/psxhdrs/devctl/posix_devctl.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2016.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#define _POSIX_26_C_SOURCE
2.24.4
