[PATCH 28/39] testsuites/psxtmtests: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:56 UTC 2022
Updates #3053.
testsuites/psxtmtests/psxtmbarrier01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmbarrier02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmbarrier03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmbarrier04/init.c | 25 +++++++++++++++---
.../psxtmtests/psxtmclocknanosleep01/init.c | 25 +++++++++++++++---
.../psxtmtests/psxtmclocknanosleep02/init.c | 25 +++++++++++++++---
.../psxtmtests/psxtmclocknanosleep03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond04/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond05/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond06/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmcond07/init.c | 25 +++++++++++++++---
.../psxtmtests/psxtmcond08/psxtmcond08impl.h | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmkey01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmq01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex04/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex05/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex06/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmmutex07/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmnanosleep01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmnanosleep02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock04/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock05/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock06/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmrwlock07/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsem01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsem02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsem03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsem04/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsem05/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsleep01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmsleep02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmthread01/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmthread02/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmthread03/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmthread04/init.c | 25 +++++++++++++++---
testsuites/psxtmtests/psxtmthread05/init.c | 26 ++++++++++++++++---
45 files changed, 990 insertions(+), 136 deletions(-)
diff --git a/testsuites/psxtmtests/psxtmbarrier01/init.c b/testsuites/psxtmtests/psxtmbarrier01/init.c
index 4c9697a8a3..1dd66b8c7b 100644
--- a/testsuites/psxtmtests/psxtmbarrier01/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier01/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2013.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#if !defined(OPERATION_COUNT)
diff --git a/testsuites/psxtmtests/psxtmbarrier02/init.c b/testsuites/psxtmtests/psxtmbarrier02/init.c
index 47b5a964e6..a54eed4d87 100644
--- a/testsuites/psxtmtests/psxtmbarrier02/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmbarrier03/init.c b/testsuites/psxtmtests/psxtmbarrier03/init.c
index 49c3ed893d..d3e7b0157d 100644
--- a/testsuites/psxtmtests/psxtmbarrier03/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmbarrier04/init.c b/testsuites/psxtmtests/psxtmbarrier04/init.c
index a463d9a8d2..2ee520b6e2 100644
--- a/testsuites/psxtmtests/psxtmbarrier04/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep01/init.c b/testsuites/psxtmtests/psxtmclocknanosleep01/init.c
index c0dab16b9d..458b257194 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep01/init.c
+++ b/testsuites/psxtmtests/psxtmclocknanosleep01/init.c
@@ -1,12 +1,31 @@
* Copyright (c) 2016. Gedare Bloom.
+ * are met:
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep02/init.c b/testsuites/psxtmtests/psxtmclocknanosleep02/init.c
index 77d4dabc34..c4fc962791 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep02/init.c
+++ b/testsuites/psxtmtests/psxtmclocknanosleep02/init.c
@@ -1,12 +1,31 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep03/init.c b/testsuites/psxtmtests/psxtmclocknanosleep03/init.c
index 12e2db96fc..067c05c1cf 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep03/init.c
+++ b/testsuites/psxtmtests/psxtmclocknanosleep03/init.c
@@ -1,12 +1,31 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond01/init.c b/testsuites/psxtmtests/psxtmcond01/init.c
index e201ab0844..f797113724 100644
--- a/testsuites/psxtmtests/psxtmcond01/init.c
+++ b/testsuites/psxtmtests/psxtmcond01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond02/init.c b/testsuites/psxtmtests/psxtmcond02/init.c
index ec5a2e9572..044e74f9bb 100644
--- a/testsuites/psxtmtests/psxtmcond02/init.c
+++ b/testsuites/psxtmtests/psxtmcond02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond03/init.c b/testsuites/psxtmtests/psxtmcond03/init.c
index 1aa958819d..1243b7130a 100644
--- a/testsuites/psxtmtests/psxtmcond03/init.c
+++ b/testsuites/psxtmtests/psxtmcond03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond04/init.c b/testsuites/psxtmtests/psxtmcond04/init.c
index 316205a8ef..d5d14ae025 100644
--- a/testsuites/psxtmtests/psxtmcond04/init.c
+++ b/testsuites/psxtmtests/psxtmcond04/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2013.
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond05/init.c b/testsuites/psxtmtests/psxtmcond05/init.c
index 7791768fa2..b6ce4dc447 100644
--- a/testsuites/psxtmtests/psxtmcond05/init.c
+++ b/testsuites/psxtmtests/psxtmcond05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond06/init.c b/testsuites/psxtmtests/psxtmcond06/init.c
index c385cbfa30..1deec68850 100644
--- a/testsuites/psxtmtests/psxtmcond06/init.c
+++ b/testsuites/psxtmtests/psxtmcond06/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond07/init.c b/testsuites/psxtmtests/psxtmcond07/init.c
index 42394f7633..816d64a90f 100644
--- a/testsuites/psxtmtests/psxtmcond07/init.c
+++ b/testsuites/psxtmtests/psxtmcond07/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h b/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
index 15664d5d6d..91f5b4f638 100644
--- a/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
+++ b/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmkey01/init.c b/testsuites/psxtmtests/psxtmkey01/init.c
index fc5b8174b0..d09160b449 100644
--- a/testsuites/psxtmtests/psxtmkey01/init.c
+++ b/testsuites/psxtmtests/psxtmkey01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmq01/init.c b/testsuites/psxtmtests/psxtmmq01/init.c
index d4bdf6d8f6..90505d6458 100644
--- a/testsuites/psxtmtests/psxtmmq01/init.c
+++ b/testsuites/psxtmtests/psxtmmq01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex01/init.c b/testsuites/psxtmtests/psxtmmutex01/init.c
index 3356113014..4af8cf14e0 100644
--- a/testsuites/psxtmtests/psxtmmutex01/init.c
+++ b/testsuites/psxtmtests/psxtmmutex01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex02/init.c b/testsuites/psxtmtests/psxtmmutex02/init.c
index 6cd29468a0..69aa67be74 100644
--- a/testsuites/psxtmtests/psxtmmutex02/init.c
+++ b/testsuites/psxtmtests/psxtmmutex02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex03/init.c b/testsuites/psxtmtests/psxtmmutex03/init.c
index bda72ac80e..9e990281b4 100644
--- a/testsuites/psxtmtests/psxtmmutex03/init.c
+++ b/testsuites/psxtmtests/psxtmmutex03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex04/init.c b/testsuites/psxtmtests/psxtmmutex04/init.c
index ce439c5eb3..d79f424206 100644
--- a/testsuites/psxtmtests/psxtmmutex04/init.c
+++ b/testsuites/psxtmtests/psxtmmutex04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex05/init.c b/testsuites/psxtmtests/psxtmmutex05/init.c
index c2934ce53b..af485c38be 100644
--- a/testsuites/psxtmtests/psxtmmutex05/init.c
+++ b/testsuites/psxtmtests/psxtmmutex05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex06/init.c b/testsuites/psxtmtests/psxtmmutex06/init.c
index 402c1cca82..5325c4efd4 100644
--- a/testsuites/psxtmtests/psxtmmutex06/init.c
+++ b/testsuites/psxtmtests/psxtmmutex06/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmmutex07/init.c b/testsuites/psxtmtests/psxtmmutex07/init.c
index b86fe419de..acd4a5c3d9 100644
--- a/testsuites/psxtmtests/psxtmmutex07/init.c
+++ b/testsuites/psxtmtests/psxtmmutex07/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmnanosleep01/init.c b/testsuites/psxtmtests/psxtmnanosleep01/init.c
index 24a34ee7fa..aab6fd0f67 100644
--- a/testsuites/psxtmtests/psxtmnanosleep01/init.c
+++ b/testsuites/psxtmtests/psxtmnanosleep01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmnanosleep02/init.c b/testsuites/psxtmtests/psxtmnanosleep02/init.c
index 97138f0426..0f4083defc 100644
--- a/testsuites/psxtmtests/psxtmnanosleep02/init.c
+++ b/testsuites/psxtmtests/psxtmnanosleep02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock01/init.c b/testsuites/psxtmtests/psxtmrwlock01/init.c
index 4b791e4652..1132867dae 100644
--- a/testsuites/psxtmtests/psxtmrwlock01/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock02/init.c b/testsuites/psxtmtests/psxtmrwlock02/init.c
index 99d2c0eabc..dfbf5420ab 100644
--- a/testsuites/psxtmtests/psxtmrwlock02/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock03/init.c b/testsuites/psxtmtests/psxtmrwlock03/init.c
index 100e7d0394..6cd239acac 100644
--- a/testsuites/psxtmtests/psxtmrwlock03/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock04/init.c b/testsuites/psxtmtests/psxtmrwlock04/init.c
index c0c795e0b0..6200306cbf 100644
--- a/testsuites/psxtmtests/psxtmrwlock04/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock05/init.c b/testsuites/psxtmtests/psxtmrwlock05/init.c
index 49eccd6d68..1bd440fcbf 100644
--- a/testsuites/psxtmtests/psxtmrwlock05/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock06/init.c b/testsuites/psxtmtests/psxtmrwlock06/init.c
index 67fb69272d..0dcdc0e5d0 100644
--- a/testsuites/psxtmtests/psxtmrwlock06/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock06/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock07/init.c b/testsuites/psxtmtests/psxtmrwlock07/init.c
index 836c4eb84b..f2f28bfde4 100644
--- a/testsuites/psxtmtests/psxtmrwlock07/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock07/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsem01/init.c b/testsuites/psxtmtests/psxtmsem01/init.c
index 4409b89b81..e20fa73a7f 100644
--- a/testsuites/psxtmtests/psxtmsem01/init.c
+++ b/testsuites/psxtmtests/psxtmsem01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsem02/init.c b/testsuites/psxtmtests/psxtmsem02/init.c
index 4f1f4026d9..ab9b440ff2 100644
--- a/testsuites/psxtmtests/psxtmsem02/init.c
+++ b/testsuites/psxtmtests/psxtmsem02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsem03/init.c b/testsuites/psxtmtests/psxtmsem03/init.c
index 69ac86d070..51f8b12363 100644
--- a/testsuites/psxtmtests/psxtmsem03/init.c
+++ b/testsuites/psxtmtests/psxtmsem03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsem04/init.c b/testsuites/psxtmtests/psxtmsem04/init.c
index 7d490c7bb5..68cee9e119 100644
--- a/testsuites/psxtmtests/psxtmsem04/init.c
+++ b/testsuites/psxtmtests/psxtmsem04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsem05/init.c b/testsuites/psxtmtests/psxtmsem05/init.c
index 9d4a763f32..2bdb447692 100644
--- a/testsuites/psxtmtests/psxtmsem05/init.c
+++ b/testsuites/psxtmtests/psxtmsem05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsleep01/init.c b/testsuites/psxtmtests/psxtmsleep01/init.c
index 3ce4e58aa6..3d8bd444cf 100644
--- a/testsuites/psxtmtests/psxtmsleep01/init.c
+++ b/testsuites/psxtmtests/psxtmsleep01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmsleep02/init.c b/testsuites/psxtmtests/psxtmsleep02/init.c
index ffc87e2070..c474513177 100644
--- a/testsuites/psxtmtests/psxtmsleep02/init.c
+++ b/testsuites/psxtmtests/psxtmsleep02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmthread01/init.c b/testsuites/psxtmtests/psxtmthread01/init.c
index c7c27559dc..189e56509a 100644
--- a/testsuites/psxtmtests/psxtmthread01/init.c
+++ b/testsuites/psxtmtests/psxtmthread01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmthread02/init.c b/testsuites/psxtmtests/psxtmthread02/init.c
index e7cfd7d724..8f087ddc0f 100644
--- a/testsuites/psxtmtests/psxtmthread02/init.c
+++ b/testsuites/psxtmtests/psxtmthread02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmthread03/init.c b/testsuites/psxtmtests/psxtmthread03/init.c
index ae30e305e6..3747e422a9 100644
--- a/testsuites/psxtmtests/psxtmthread03/init.c
+++ b/testsuites/psxtmtests/psxtmthread03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmthread04/init.c b/testsuites/psxtmtests/psxtmthread04/init.c
index ed8e4bb9b4..cd46f7eda2 100644
--- a/testsuites/psxtmtests/psxtmthread04/init.c
+++ b/testsuites/psxtmtests/psxtmthread04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtmtests/psxtmthread05/init.c b/testsuites/psxtmtests/psxtmthread05/init.c
index 4203e4b951..50bea75825 100644
--- a/testsuites/psxtmtests/psxtmthread05/init.c
+++ b/testsuites/psxtmtests/psxtmthread05/init.c
@@ -1,11 +1,29 @@
- * COPYRIGHT (c) 2013.
+ * are met:
2.24.4
