[PATCH 26/39] testsuites/psxtests/psx[n-z]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:54 UTC 2022
Updates #3053.
testsuites/psxtests/psxobj01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxobj01/psxobj01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxonce01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxonce01/psxonce01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxonce01/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxpasswd01/init.c | 25 ++++++++++++++++---
.../psxtests/psxpasswd01/psxpasswd01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxpasswd02/init.c | 25 ++++++++++++++++---
.../psxtests/psxpasswd02/psxpasswd02.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxpipe01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxpipe01/psxpipe01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxrdwrv/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxrdwrv/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxreaddir/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxrwlock01/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxrwlock01/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxsem01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxshm01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxshm01/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxshm02/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxshm02/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxsignal01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxsignal01/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxsignal01/task1.c | 25 ++++++++++++++++---
testsuites/psxtests/psxsignal02/init.c | 25 ++++++++++++++++---
.../psxtests/psxsignal02/psxsignal02.doc | 25 ++++++++++++++++---
.../psxtests/psxsignal03/psxsignal03.doc | 25 ++++++++++++++++---
.../psxtests/psxsignal03/psxsignal0ximpl.h | 25 ++++++++++++++++---
.../psxtests/psxsignal04/psxsignal04.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxsignal05/init.c | 25 ++++++++++++++++---
.../psxtests/psxsignal05/psxsignal05.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxsignal06/init.c | 25 ++++++++++++++++---
.../psxtests/psxsignal06/psxsignal06.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxspin01/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxspin01/psxspin01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxspin01/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxstack01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxstack01/psxstack01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxstack02/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxstack02/psxstack02.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxstat/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxstat/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxstrsignal01/init.c | 25 ++++++++++++++++---
.../psxstrsignal01/psxstrsignal01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxsysconf/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxsysconf/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxthreadname01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxtime/main.c | 25 ++++++++++++++++---
testsuites/psxtests/psxtime/psxtime.doc | 2 ++
testsuites/psxtests/psxtime/test.c | 25 ++++++++++++++++---
testsuites/psxtests/psxtimer01/psxtimer.c | 25 ++++++++++++++++---
testsuites/psxtests/psxtimer01/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxtimer02/psxtimer.c | 25 ++++++++++++++++---
testsuites/psxtests/psxtimer02/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxtimes01/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxtimes01/psxtimes01.doc | 25 ++++++++++++++++---
testsuites/psxtests/psxualarm/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxualarm/system.h | 25 ++++++++++++++++---
testsuites/psxtests/psxusleep/init.c | 25 ++++++++++++++++---
testsuites/psxtests/psxusleep/psxusleep.doc | 25 ++++++++++++++++---
60 files changed, 1300 insertions(+), 177 deletions(-)
diff --git a/testsuites/psxtests/psxobj01/init.c b/testsuites/psxtests/psxobj01/init.c
index fef749b3e9..f9ea271b37 100644
--- a/testsuites/psxtests/psxobj01/init.c
+++ b/testsuites/psxtests/psxobj01/init.c
@@ -1,3 +1,5 @@
* @file
* Odd Object Name/Id Error Cases
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxobj01/psxobj01.doc b/testsuites/psxtests/psxobj01/psxobj01.doc
index 7c4d731a23..d028331b65 100644
--- a/testsuites/psxtests/psxobj01/psxobj01.doc
+++ b/testsuites/psxtests/psxobj01/psxobj01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
# COPYRIGHT (c) 1989-2009.
# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/psxtests/psxonce01/init.c b/testsuites/psxtests/psxonce01/init.c
index 3b50c945ab..dfa0204d62 100644
--- a/testsuites/psxtests/psxonce01/init.c
+++ b/testsuites/psxtests/psxonce01/init.c
@@ -1,3 +1,5 @@
* Copyright (C) 2019 embedded brains GmbH
* Copyright (C) 2019 Sebastian Huber
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/psxtests/psxonce01/psxonce01.doc b/testsuites/psxtests/psxonce01/psxonce01.doc
index 4f4da56c0a..7abbd2e037 100644
--- a/testsuites/psxtests/psxonce01/psxonce01.doc
+++ b/testsuites/psxtests/psxonce01/psxonce01.doc
@@ -1,11 +1,30 @@
# Copyright (c) 2013 Annelies Odermann <annelies.odermann at gmail.com>
# Copyright (c) 2014 embedded brains GmbH.
+# are met:
diff --git a/testsuites/psxtests/psxonce01/system.h b/testsuites/psxtests/psxonce01/system.h
index fe95285d5f..2ac48cf74e 100644
--- a/testsuites/psxtests/psxonce01/system.h
+++ b/testsuites/psxtests/psxonce01/system.h
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxpasswd01/init.c b/testsuites/psxtests/psxpasswd01/init.c
index 66dc5f0c49..d15d3a294a 100644
--- a/testsuites/psxtests/psxpasswd01/init.c
+++ b/testsuites/psxtests/psxpasswd01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxpasswd01/psxpasswd01.doc b/testsuites/psxtests/psxpasswd01/psxpasswd01.doc
index 02b02929e1..7964d9272e 100644
--- a/testsuites/psxtests/psxpasswd01/psxpasswd01.doc
+++ b/testsuites/psxtests/psxpasswd01/psxpasswd01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxpasswd02/init.c b/testsuites/psxtests/psxpasswd02/init.c
index ce250fce6e..f78f633d97 100644
--- a/testsuites/psxtests/psxpasswd02/init.c
+++ b/testsuites/psxtests/psxpasswd02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxpasswd02/psxpasswd02.doc b/testsuites/psxtests/psxpasswd02/psxpasswd02.doc
index b6a5b2cebd..b8d3c9dc0f 100644
--- a/testsuites/psxtests/psxpasswd02/psxpasswd02.doc
+++ b/testsuites/psxtests/psxpasswd02/psxpasswd02.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2010.
+# are met:
diff --git a/testsuites/psxtests/psxpipe01/init.c b/testsuites/psxtests/psxpipe01/init.c
index 90d4c5d8bc..5ae774a647 100644
--- a/testsuites/psxtests/psxpipe01/init.c
+++ b/testsuites/psxtests/psxpipe01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxpipe01/psxpipe01.doc b/testsuites/psxtests/psxpipe01/psxpipe01.doc
index 3fe5436d1a..92b07b8000 100644
--- a/testsuites/psxtests/psxpipe01/psxpipe01.doc
+++ b/testsuites/psxtests/psxpipe01/psxpipe01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxrdwrv/main.c b/testsuites/psxtests/psxrdwrv/main.c
index 44eda9e0d9..846cbd1dab 100644
--- a/testsuites/psxtests/psxrdwrv/main.c
+++ b/testsuites/psxtests/psxrdwrv/main.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxrdwrv/test.c b/testsuites/psxtests/psxrdwrv/test.c
index d9582d8d01..0d66ffd720 100644
--- a/testsuites/psxtests/psxrdwrv/test.c
+++ b/testsuites/psxtests/psxrdwrv/test.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxreaddir/test.c b/testsuites/psxtests/psxreaddir/test.c
index 25d7844bfc..09afb82b83 100644
--- a/testsuites/psxtests/psxreaddir/test.c
+++ b/testsuites/psxtests/psxreaddir/test.c
@@ -1,3 +1,5 @@
* @file
@@ -22,9 +24,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxrwlock01/main.c b/testsuites/psxtests/psxrwlock01/main.c
index d71218bfff..4d0af07742 100644
--- a/testsuites/psxtests/psxrwlock01/main.c
+++ b/testsuites/psxtests/psxrwlock01/main.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxrwlock01/test.c b/testsuites/psxtests/psxrwlock01/test.c
index 3599d1f64e..5767aa7c07 100644
--- a/testsuites/psxtests/psxrwlock01/test.c
+++ b/testsuites/psxtests/psxrwlock01/test.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsem01/init.c b/testsuites/psxtests/psxsem01/init.c
index 899e324fa0..988854193d 100644
--- a/testsuites/psxtests/psxsem01/init.c
+++ b/testsuites/psxtests/psxsem01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxshm01/init.c b/testsuites/psxtests/psxshm01/init.c
index 4636f9a0af..eb155ddbf5 100644
--- a/testsuites/psxtests/psxshm01/init.c
+++ b/testsuites/psxtests/psxshm01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2016 Gedare Bloom.
+ * are met:
diff --git a/testsuites/psxtests/psxshm01/system.h b/testsuites/psxtests/psxshm01/system.h
index 846d92d4e3..fdd9cf09ec 100644
--- a/testsuites/psxtests/psxshm01/system.h
+++ b/testsuites/psxtests/psxshm01/system.h
@@ -1,9 +1,28 @@
+ * are met:
#include <pmacros.h>
diff --git a/testsuites/psxtests/psxshm02/init.c b/testsuites/psxtests/psxshm02/init.c
index 071f4c4da8..0f0221b658 100644
--- a/testsuites/psxtests/psxshm02/init.c
+++ b/testsuites/psxtests/psxshm02/init.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxshm02/system.h b/testsuites/psxtests/psxshm02/system.h
index 90e40d2c5d..b148f1f555 100644
--- a/testsuites/psxtests/psxshm02/system.h
+++ b/testsuites/psxtests/psxshm02/system.h
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsignal01/init.c b/testsuites/psxtests/psxsignal01/init.c
index 6df3695c98..9cd3e31112 100644
--- a/testsuites/psxtests/psxsignal01/init.c
+++ b/testsuites/psxtests/psxsignal01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsignal01/system.h b/testsuites/psxtests/psxsignal01/system.h
index 418434bc80..2f26575602 100644
--- a/testsuites/psxtests/psxsignal01/system.h
+++ b/testsuites/psxtests/psxsignal01/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxsignal01/task1.c b/testsuites/psxtests/psxsignal01/task1.c
index 1fe88db268..4dde698f15 100644
--- a/testsuites/psxtests/psxsignal01/task1.c
+++ b/testsuites/psxtests/psxsignal01/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This routine serves as a test task.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsignal02/init.c b/testsuites/psxtests/psxsignal02/init.c
index c7a9432415..2a117d15f4 100644
--- a/testsuites/psxtests/psxsignal02/init.c
+++ b/testsuites/psxtests/psxsignal02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsignal02/psxsignal02.doc b/testsuites/psxtests/psxsignal02/psxsignal02.doc
index a587c46ccd..a88e011880 100644
--- a/testsuites/psxtests/psxsignal02/psxsignal02.doc
+++ b/testsuites/psxtests/psxsignal02/psxsignal02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxsignal03/psxsignal03.doc b/testsuites/psxtests/psxsignal03/psxsignal03.doc
index 22f3d199bf..baa1ea9b50 100644
--- a/testsuites/psxtests/psxsignal03/psxsignal03.doc
+++ b/testsuites/psxtests/psxsignal03/psxsignal03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h b/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
index 6410be1020..f727545c3f 100644
--- a/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
+++ b/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsignal04/psxsignal04.doc b/testsuites/psxtests/psxsignal04/psxsignal04.doc
index f8e5599f7d..21ba1c30ba 100644
--- a/testsuites/psxtests/psxsignal04/psxsignal04.doc
+++ b/testsuites/psxtests/psxsignal04/psxsignal04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxsignal05/init.c b/testsuites/psxtests/psxsignal05/init.c
index 40db63e4a1..85bb571e5d 100644
--- a/testsuites/psxtests/psxsignal05/init.c
+++ b/testsuites/psxtests/psxsignal05/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxsignal05/psxsignal05.doc b/testsuites/psxtests/psxsignal05/psxsignal05.doc
index 9a21333ec7..02419690c2 100644
--- a/testsuites/psxtests/psxsignal05/psxsignal05.doc
+++ b/testsuites/psxtests/psxsignal05/psxsignal05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxsignal06/init.c b/testsuites/psxtests/psxsignal06/init.c
index 650a0fa6c5..8770746639 100644
--- a/testsuites/psxtests/psxsignal06/init.c
+++ b/testsuites/psxtests/psxsignal06/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2013.
+ * are met:
diff --git a/testsuites/psxtests/psxsignal06/psxsignal06.doc b/testsuites/psxtests/psxsignal06/psxsignal06.doc
index 81db95f381..0ce55de625 100644
--- a/testsuites/psxtests/psxsignal06/psxsignal06.doc
+++ b/testsuites/psxtests/psxsignal06/psxsignal06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxspin01/main.c b/testsuites/psxtests/psxspin01/main.c
index 2c35d33b4e..a867527a5e 100644
--- a/testsuites/psxtests/psxspin01/main.c
+++ b/testsuites/psxtests/psxspin01/main.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxspin01/psxspin01.doc b/testsuites/psxtests/psxspin01/psxspin01.doc
index 39f13fb8b5..c32e28499f 100644
--- a/testsuites/psxtests/psxspin01/psxspin01.doc
+++ b/testsuites/psxtests/psxspin01/psxspin01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxspin01/test.c b/testsuites/psxtests/psxspin01/test.c
index e27db73d78..212b568e29 100644
--- a/testsuites/psxtests/psxspin01/test.c
+++ b/testsuites/psxtests/psxspin01/test.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxstack01/init.c b/testsuites/psxtests/psxstack01/init.c
index 762e3950f9..7abb0dc7ba 100644
--- a/testsuites/psxtests/psxstack01/init.c
+++ b/testsuites/psxtests/psxstack01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxstack01/psxstack01.doc b/testsuites/psxtests/psxstack01/psxstack01.doc
index c946a5944b..e3b0af3657 100644
--- a/testsuites/psxtests/psxstack01/psxstack01.doc
+++ b/testsuites/psxtests/psxstack01/psxstack01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxstack02/init.c b/testsuites/psxtests/psxstack02/init.c
index 2f7ba56e68..d58ff4d2a7 100644
--- a/testsuites/psxtests/psxstack02/init.c
+++ b/testsuites/psxtests/psxstack02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxstack02/psxstack02.doc b/testsuites/psxtests/psxstack02/psxstack02.doc
index a3d9f96219..07a344df2c 100644
--- a/testsuites/psxtests/psxstack02/psxstack02.doc
+++ b/testsuites/psxtests/psxstack02/psxstack02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxstat/main.c b/testsuites/psxtests/psxstat/main.c
index 472b91848c..a9bacbc4dc 100644
--- a/testsuites/psxtests/psxstat/main.c
+++ b/testsuites/psxtests/psxstat/main.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxstat/test.c b/testsuites/psxtests/psxstat/test.c
index 09ebb9613e..e24d09fbf1 100644
--- a/testsuites/psxtests/psxstat/test.c
+++ b/testsuites/psxtests/psxstat/test.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxstrsignal01/init.c b/testsuites/psxtests/psxstrsignal01/init.c
index 6c3a37cb52..e9970bf07a 100644
--- a/testsuites/psxtests/psxstrsignal01/init.c
+++ b/testsuites/psxtests/psxstrsignal01/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 2017.
+ * are met:
diff --git a/testsuites/psxtests/psxstrsignal01/psxstrsignal01.doc b/testsuites/psxtests/psxstrsignal01/psxstrsignal01.doc
index 43b362d0be..47c85cb06a 100644
--- a/testsuites/psxtests/psxstrsignal01/psxstrsignal01.doc
+++ b/testsuites/psxtests/psxstrsignal01/psxstrsignal01.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 2017.
+# are met:
diff --git a/testsuites/psxtests/psxsysconf/init.c b/testsuites/psxtests/psxsysconf/init.c
index 66d6dd3761..796496feb3 100644
--- a/testsuites/psxtests/psxsysconf/init.c
+++ b/testsuites/psxtests/psxsysconf/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/testsuites/psxtests/psxsysconf/system.h b/testsuites/psxtests/psxsysconf/system.h
index d0eaed6ca3..65458ef3f3 100644
--- a/testsuites/psxtests/psxsysconf/system.h
+++ b/testsuites/psxtests/psxsysconf/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxthreadname01/init.c b/testsuites/psxtests/psxthreadname01/init.c
index 50eba857c2..3183272ce8 100644
--- a/testsuites/psxtests/psxthreadname01/init.c
+++ b/testsuites/psxtests/psxthreadname01/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * are met:
#define _GNU_SOURCE
diff --git a/testsuites/psxtests/psxtime/main.c b/testsuites/psxtests/psxtime/main.c
index c45efbb019..28c29e5846 100644
--- a/testsuites/psxtests/psxtime/main.c
+++ b/testsuites/psxtests/psxtime/main.c
@@ -1,12 +1,31 @@
* Simple RTEMS startup to call main
+ * are met:
diff --git a/testsuites/psxtests/psxtime/psxtime.doc b/testsuites/psxtests/psxtime/psxtime.doc
index ec46f9293b..88f416713d 100644
--- a/testsuites/psxtests/psxtime/psxtime.doc
+++ b/testsuites/psxtests/psxtime/psxtime.doc
@@ -1,3 +1,5 @@
# testsuites/psxtests/psxtime/psxtime.doc
# Copyright (c) 2013 Shaily Sangwan <shailysangwan at gmail.com>.
diff --git a/testsuites/psxtests/psxtime/test.c b/testsuites/psxtests/psxtime/test.c
index f5544b19dd..796d3d5d35 100644
--- a/testsuites/psxtests/psxtime/test.c
+++ b/testsuites/psxtests/psxtime/test.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
diff --git a/testsuites/psxtests/psxtimer01/psxtimer.c b/testsuites/psxtests/psxtimer01/psxtimer.c
index 6ec049ac54..560dc2eebd 100644
--- a/testsuites/psxtests/psxtimer01/psxtimer.c
+++ b/testsuites/psxtests/psxtimer01/psxtimer.c
@@ -1,3 +1,5 @@
* This is a simple real-time applications which contains 3 periodic tasks.
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxtimer01/system.h b/testsuites/psxtests/psxtimer01/system.h
index 9cfd408d86..c04d81b3ef 100644
--- a/testsuites/psxtests/psxtimer01/system.h
+++ b/testsuites/psxtests/psxtimer01/system.h
@@ -1,11 +1,30 @@
/* system.h
* function in the test set.
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 874a789b7f..7da0f7acd1 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -1,3 +1,5 @@
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxtimer02/system.h b/testsuites/psxtests/psxtimer02/system.h
index a173f3eb02..57a73325ce 100644
--- a/testsuites/psxtests/psxtimer02/system.h
+++ b/testsuites/psxtests/psxtimer02/system.h
@@ -1,11 +1,30 @@
/* system.h
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxtimes01/init.c b/testsuites/psxtests/psxtimes01/init.c
index d5b573bf15..b7cf491d25 100644
--- a/testsuites/psxtests/psxtimes01/init.c
+++ b/testsuites/psxtests/psxtimes01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxtimes01/psxtimes01.doc b/testsuites/psxtests/psxtimes01/psxtimes01.doc
index 452a0dc252..f4479756dd 100644
--- a/testsuites/psxtests/psxtimes01/psxtimes01.doc
+++ b/testsuites/psxtests/psxtimes01/psxtimes01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxualarm/init.c b/testsuites/psxtests/psxualarm/init.c
index 2aa133bcd4..4a8ce86e05 100644
--- a/testsuites/psxtests/psxualarm/init.c
+++ b/testsuites/psxtests/psxualarm/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxualarm/system.h b/testsuites/psxtests/psxualarm/system.h
--- a/testsuites/psxtests/psxualarm/system.h
+++ b/testsuites/psxtests/psxualarm/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
/* functions */
diff --git a/testsuites/psxtests/psxusleep/init.c b/testsuites/psxtests/psxusleep/init.c
index 84eedd98dc..ab7600066c 100644
--- a/testsuites/psxtests/psxusleep/init.c
+++ b/testsuites/psxtests/psxusleep/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxusleep/psxusleep.doc b/testsuites/psxtests/psxusleep/psxusleep.doc
index ae62fd69f5..7b0b297f88 100644
--- a/testsuites/psxtests/psxusleep/psxusleep.doc
+++ b/testsuites/psxtests/psxusleep/psxusleep.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
