[PATCH 25/39] testsuites/psxtests/psx[g-m1]*: Change license to BSD-2
Fri Apr 8 14:45:53 UTC 2022
Updates #3053.
 testsuites/psxtests/psxgetattrnp01/init.c     | 25 ++++++++++++++++---
 .../psxgetattrnp01/psxgetattrnp01.doc         | 25 ++++++++++++++++---
 testsuites/psxtests/psxgetrusage01/init.c     | 25 ++++++++++++++++---
 .../psxgetrusage01/psxgetrusage01.doc         | 25 ++++++++++++++++---
 testsuites/psxtests/psxglobalcon01/init.cc    | 25 ++++++++++++++++---
 testsuites/psxtests/psxglobalcon02/init.cc    | 25 ++++++++++++++++---
 testsuites/psxtests/psxid01/init.c            | 25 ++++++++++++++++---
 testsuites/psxtests/psxid01/psxid01.doc       | 25 ++++++++++++++++---
 testsuites/psxtests/psximfs01/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psximfs01/psximfs01.doc   | 25 ++++++++++++++++---
 testsuites/psxtests/psximfs02/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psximfs02/psximfs02.doc   | 25 ++++++++++++++++---
 testsuites/psxtests/psxintrcritical01/init.c  | 25 ++++++++++++++++---
 .../psxintrcritical01/psxintrcritical01.doc   | 25 ++++++++++++++++---
 testsuites/psxtests/psxitimer/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey01/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey01/system.h         | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey02/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey02/psxkey02.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey03/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey03/psxkey03.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey04/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey04/psxkey04.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey05/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey05/psxkey05.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey06/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey06/psxkey06.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey07/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey07/psxkey07.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey08/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey08/psxkey08.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey09/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey09/psxkey09.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey10/init.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxkey10/psxkey10.doc     | 25 ++++++++++++++++---
 testsuites/psxtests/psxmmap01/system.h        | 25 ++++++++++++++++---
 testsuites/psxtests/psxmmap01/test_driver.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxmmap01/test_driver.h   | 25 ++++++++++++++++---
 testsuites/psxtests/psxmmap01/test_helper.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxmmap01/test_helper.h   | 25 ++++++++++++++++---
 testsuites/psxtests/psxmount/test.c           | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq01/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq01/system.h        | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq02/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq02/system.h        | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq03/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq03/psxmsgq03.doc   | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq03/system.h        | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq04/init.c          | 25 ++++++++++++++++---
 testsuites/psxtests/psxmsgq04/psxmsgq04.doc   | 25 ++++++++++++++++---
 testsuites/psxtests/psxmutexattr01/init.c     | 25 ++++++++++++++++---
 .../psxmutexattr01/psxmutexattr01.doc         | 25 ++++++++++++++++---
 52 files changed, 1144 insertions(+), 156 deletions(-)
diff --git a/testsuites/psxtests/psxgetattrnp01/init.c b/testsuites/psxtests/psxgetattrnp01/init.c
index dca5a25dae..ac2bab5d27 100644
--- a/testsuites/psxtests/psxgetattrnp01/init.c
+++ b/testsuites/psxtests/psxgetattrnp01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #define _GNU_SOURCE
diff --git a/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.doc b/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.doc
index 52366e091f..c0d4446067 100644
--- a/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.doc
+++ b/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 1989-2014.
 #  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/psxtests/psxgetrusage01/init.c b/testsuites/psxtests/psxgetrusage01/init.c
index ee69c998f1..91ea1d3a11 100644
--- a/testsuites/psxtests/psxgetrusage01/init.c
+++ b/testsuites/psxtests/psxgetrusage01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2010.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxgetrusage01/psxgetrusage01.doc b/testsuites/psxtests/psxgetrusage01/psxgetrusage01.doc
index 603f7a752c..b4ee0515d6 100644
--- a/testsuites/psxtests/psxgetrusage01/psxgetrusage01.doc
+++ b/testsuites/psxtests/psxgetrusage01/psxgetrusage01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2010.
+# are met:
diff --git a/testsuites/psxtests/psxglobalcon01/init.cc b/testsuites/psxtests/psxglobalcon01/init.cc
index d8b6cf498c..2ccbba9e34 100644
--- a/testsuites/psxtests/psxglobalcon01/init.cc
+++ b/testsuites/psxtests/psxglobalcon01/init.cc
@@ -1,9 +1,28 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/testsuites/psxtests/psxglobalcon02/init.cc b/testsuites/psxtests/psxglobalcon02/init.cc
index 0a3e9edff0..0e530246e0 100644
--- a/testsuites/psxtests/psxglobalcon02/init.cc
+++ b/testsuites/psxtests/psxglobalcon02/init.cc
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxid01/init.c b/testsuites/psxtests/psxid01/init.c
index 85cb40a7e9..383f1bc7a0 100644
--- a/testsuites/psxtests/psxid01/init.c
+++ b/testsuites/psxtests/psxid01/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/psxtests/psxid01/psxid01.doc b/testsuites/psxtests/psxid01/psxid01.doc
index a8ce42abd5..26f3df555e 100644
--- a/testsuites/psxtests/psxid01/psxid01.doc
+++ b/testsuites/psxtests/psxid01/psxid01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psximfs01/init.c b/testsuites/psxtests/psximfs01/init.c
index f8bea196b7..324baa5723 100644
--- a/testsuites/psxtests/psximfs01/init.c
+++ b/testsuites/psxtests/psximfs01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psximfs01/psximfs01.doc b/testsuites/psxtests/psximfs01/psximfs01.doc
index 88c884b975..0471605e56 100644
--- a/testsuites/psxtests/psximfs01/psximfs01.doc
+++ b/testsuites/psxtests/psximfs01/psximfs01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psximfs02/init.c b/testsuites/psxtests/psximfs02/init.c
index 04f806f565..1d196aa6ba 100644
--- a/testsuites/psxtests/psximfs02/init.c
+++ b/testsuites/psxtests/psximfs02/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2015.
+ * are met:
diff --git a/testsuites/psxtests/psximfs02/psximfs02.doc b/testsuites/psxtests/psximfs02/psximfs02.doc
index 4ee23d6e69..a8ccbdc1fc 100644
--- a/testsuites/psxtests/psximfs02/psximfs02.doc
+++ b/testsuites/psxtests/psximfs02/psximfs02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxintrcritical01/init.c b/testsuites/psxtests/psxintrcritical01/init.c
index ea60b38c5b..deb95da994 100644
--- a/testsuites/psxtests/psxintrcritical01/init.c
+++ b/testsuites/psxtests/psxintrcritical01/init.c
@@ -1,12 +1,31 @@
  *  Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
diff --git a/testsuites/psxtests/psxintrcritical01/psxintrcritical01.doc b/testsuites/psxtests/psxintrcritical01/psxintrcritical01.doc
index f1f3415e73..de06bad80c 100644
--- a/testsuites/psxtests/psxintrcritical01/psxintrcritical01.doc
+++ b/testsuites/psxtests/psxintrcritical01/psxintrcritical01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2009.
+# are met:
diff --git a/testsuites/psxtests/psxitimer/init.c b/testsuites/psxtests/psxitimer/init.c
index 8292b6ebe7..2cb00851da 100644
--- a/testsuites/psxtests/psxitimer/init.c
+++ b/testsuites/psxtests/psxitimer/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey01/init.c b/testsuites/psxtests/psxkey01/init.c
index 6b8f57eccc..089a469f29 100644
--- a/testsuites/psxtests/psxkey01/init.c
+++ b/testsuites/psxtests/psxkey01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey01/system.h b/testsuites/psxtests/psxkey01/system.h
index 186e1b71f0..66304b9684 100644
--- a/testsuites/psxtests/psxkey01/system.h
+++ b/testsuites/psxtests/psxkey01/system.h
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psxkey02/init.c b/testsuites/psxtests/psxkey02/init.c
index 6c6a3a0be5..500b809cfb 100644
--- a/testsuites/psxtests/psxkey02/init.c
+++ b/testsuites/psxtests/psxkey02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey02/psxkey02.doc b/testsuites/psxtests/psxkey02/psxkey02.doc
index 92a33b2250..5adf5d49c9 100644
--- a/testsuites/psxtests/psxkey02/psxkey02.doc
+++ b/testsuites/psxtests/psxkey02/psxkey02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey03/init.c b/testsuites/psxtests/psxkey03/init.c
index 8f0a890752..c154f614bc 100644
--- a/testsuites/psxtests/psxkey03/init.c
+++ b/testsuites/psxtests/psxkey03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey03/psxkey03.doc b/testsuites/psxtests/psxkey03/psxkey03.doc
index 2f9fa7c298..046fb9be6c 100644
--- a/testsuites/psxtests/psxkey03/psxkey03.doc
+++ b/testsuites/psxtests/psxkey03/psxkey03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey04/init.c b/testsuites/psxtests/psxkey04/init.c
index d42633ce25..0cd12361cf 100644
--- a/testsuites/psxtests/psxkey04/init.c
+++ b/testsuites/psxtests/psxkey04/init.c
@@ -1,11 +1,30 @@
  *  Copyright (c) 2012 Zhongwei Yao.
+ * are met:
diff --git a/testsuites/psxtests/psxkey04/psxkey04.doc b/testsuites/psxtests/psxkey04/psxkey04.doc
index 73302caaa9..5aefb2fc75 100644
--- a/testsuites/psxtests/psxkey04/psxkey04.doc
+++ b/testsuites/psxtests/psxkey04/psxkey04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey05/init.c b/testsuites/psxtests/psxkey05/init.c
index e849e7bae5..88eb0c2329 100644
--- a/testsuites/psxtests/psxkey05/init.c
+++ b/testsuites/psxtests/psxkey05/init.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey05/psxkey05.doc b/testsuites/psxtests/psxkey05/psxkey05.doc
index 90158eb3e2..95ae8c73c8 100644
--- a/testsuites/psxtests/psxkey05/psxkey05.doc
+++ b/testsuites/psxtests/psxkey05/psxkey05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey06/init.c b/testsuites/psxtests/psxkey06/init.c
index aa5977759d..615e196807 100644
--- a/testsuites/psxtests/psxkey06/init.c
+++ b/testsuites/psxtests/psxkey06/init.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey06/psxkey06.doc b/testsuites/psxtests/psxkey06/psxkey06.doc
index 0c0c3d4ba7..ae8c8b8364 100644
--- a/testsuites/psxtests/psxkey06/psxkey06.doc
+++ b/testsuites/psxtests/psxkey06/psxkey06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey07/init.c b/testsuites/psxtests/psxkey07/init.c
index 378349bbe6..d9696a0e28 100644
--- a/testsuites/psxtests/psxkey07/init.c
+++ b/testsuites/psxtests/psxkey07/init.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey07/psxkey07.doc b/testsuites/psxtests/psxkey07/psxkey07.doc
index 120e26b7b9..b16297872d 100644
--- a/testsuites/psxtests/psxkey07/psxkey07.doc
+++ b/testsuites/psxtests/psxkey07/psxkey07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey08/init.c b/testsuites/psxtests/psxkey08/init.c
index e5277baf8a..2bd00bc53d 100644
--- a/testsuites/psxtests/psxkey08/init.c
+++ b/testsuites/psxtests/psxkey08/init.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey08/psxkey08.doc b/testsuites/psxtests/psxkey08/psxkey08.doc
index 63d0b402bc..86229745a2 100644
--- a/testsuites/psxtests/psxkey08/psxkey08.doc
+++ b/testsuites/psxtests/psxkey08/psxkey08.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxkey09/init.c b/testsuites/psxtests/psxkey09/init.c
index ac346b4289..b01a1dde61 100644
--- a/testsuites/psxtests/psxkey09/init.c
+++ b/testsuites/psxtests/psxkey09/init.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey09/psxkey09.doc b/testsuites/psxtests/psxkey09/psxkey09.doc
index 46a9332e45..210edfd00e 100644
--- a/testsuites/psxtests/psxkey09/psxkey09.doc
+++ b/testsuites/psxtests/psxkey09/psxkey09.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2013.
+# are met:
diff --git a/testsuites/psxtests/psxkey10/init.c b/testsuites/psxtests/psxkey10/init.c
index 0cd24c0a14..9c57e6b752 100644
--- a/testsuites/psxtests/psxkey10/init.c
+++ b/testsuites/psxtests/psxkey10/init.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/psxtests/psxkey10/psxkey10.doc b/testsuites/psxtests/psxkey10/psxkey10.doc
index de01699274..37f510f350 100644
--- a/testsuites/psxtests/psxkey10/psxkey10.doc
+++ b/testsuites/psxtests/psxkey10/psxkey10.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxmmap01/system.h b/testsuites/psxtests/psxmmap01/system.h
index 526465b5e9..418523f5b8 100644
--- a/testsuites/psxtests/psxmmap01/system.h
+++ b/testsuites/psxtests/psxmmap01/system.h
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 Kevin Kirspel.
+ * are met:
 #include <pmacros.h>
diff --git a/testsuites/psxtests/psxmmap01/test_driver.c b/testsuites/psxtests/psxmmap01/test_driver.c
index 95edd3e9c8..839334f346 100644
--- a/testsuites/psxtests/psxmmap01/test_driver.c
+++ b/testsuites/psxtests/psxmmap01/test_driver.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmmap01/test_driver.h b/testsuites/psxtests/psxmmap01/test_driver.h
index 5afdb9b46e..351073fb98 100644
--- a/testsuites/psxtests/psxmmap01/test_driver.h
+++ b/testsuites/psxtests/psxmmap01/test_driver.h
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmmap01/test_helper.c b/testsuites/psxtests/psxmmap01/test_helper.c
index cf68e8f6cd..bf71b345fa 100644
--- a/testsuites/psxtests/psxmmap01/test_helper.c
+++ b/testsuites/psxtests/psxmmap01/test_helper.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmmap01/test_helper.h b/testsuites/psxtests/psxmmap01/test_helper.h
index 65ca3c11bd..fa42371307 100644
--- a/testsuites/psxtests/psxmmap01/test_helper.h
+++ b/testsuites/psxtests/psxmmap01/test_helper.h
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmount/test.c b/testsuites/psxtests/psxmount/test.c
index 57f43db9a8..9ce68dda59 100644
--- a/testsuites/psxtests/psxmount/test.c
+++ b/testsuites/psxtests/psxmount/test.c
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
  *  Modifications to support reference counting in the file system are
  *  Copyright (c) 2012 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/psxtests/psxmsgq01/init.c b/testsuites/psxtests/psxmsgq01/init.c
index d22238dfb8..3c77beb038 100644
--- a/testsuites/psxtests/psxmsgq01/init.c
+++ b/testsuites/psxtests/psxmsgq01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmsgq01/system.h b/testsuites/psxtests/psxmsgq01/system.h
index 27d158a3da..b153e74cf6 100644
--- a/testsuites/psxtests/psxmsgq01/system.h
+++ b/testsuites/psxtests/psxmsgq01/system.h
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psxmsgq02/init.c b/testsuites/psxtests/psxmsgq02/init.c
index 290663d22d..5949cac4f0 100644
--- a/testsuites/psxtests/psxmsgq02/init.c
+++ b/testsuites/psxtests/psxmsgq02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmsgq02/system.h b/testsuites/psxtests/psxmsgq02/system.h
index 5b87dab619..5a1084f3ec 100644
--- a/testsuites/psxtests/psxmsgq02/system.h
+++ b/testsuites/psxtests/psxmsgq02/system.h
@@ -1,3 +1,5 @@
 /*  system.h
  *  This include file contains information that is included in every
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psxmsgq03/init.c b/testsuites/psxtests/psxmsgq03/init.c
index 281d8b837e..961ab61601 100644
--- a/testsuites/psxtests/psxmsgq03/init.c
+++ b/testsuites/psxtests/psxmsgq03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmsgq03/psxmsgq03.doc b/testsuites/psxtests/psxmsgq03/psxmsgq03.doc
index b5d093bdc9..6c6b13e1b1 100644
--- a/testsuites/psxtests/psxmsgq03/psxmsgq03.doc
+++ b/testsuites/psxtests/psxmsgq03/psxmsgq03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxmsgq03/system.h b/testsuites/psxtests/psxmsgq03/system.h
index a2a3d73284..7da0b6a7f7 100644
--- a/testsuites/psxtests/psxmsgq03/system.h
+++ b/testsuites/psxtests/psxmsgq03/system.h
@@ -1,3 +1,5 @@
 /*  system.h
@@ -6,9 +8,26 @@
+ * are met:
 /* functions */
diff --git a/testsuites/psxtests/psxmsgq04/init.c b/testsuites/psxtests/psxmsgq04/init.c
index 07bd5ef87b..6057b6cb40 100644
--- a/testsuites/psxtests/psxmsgq04/init.c
+++ b/testsuites/psxtests/psxmsgq04/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmsgq04/psxmsgq04.doc b/testsuites/psxtests/psxmsgq04/psxmsgq04.doc
index 6d0b3a7931..62afee510a 100644
--- a/testsuites/psxtests/psxmsgq04/psxmsgq04.doc
+++ b/testsuites/psxtests/psxmsgq04/psxmsgq04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtests/psxmutexattr01/init.c b/testsuites/psxtests/psxmutexattr01/init.c
index b65eeefccd..3c5f99d610 100644
--- a/testsuites/psxtests/psxmutexattr01/init.c
+++ b/testsuites/psxtests/psxmutexattr01/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/psxtests/psxmutexattr01/psxmutexattr01.doc b/testsuites/psxtests/psxmutexattr01/psxmutexattr01.doc
index f198119252..762806a693 100644
--- a/testsuites/psxtests/psxmutexattr01/psxmutexattr01.doc
+++ b/testsuites/psxtests/psxmutexattr01/psxmutexattr01.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
