[PATCH 31/39] testsuites/psxtests/psxhdrs/sched/*: Change license to BSD-2
Fri Apr 8 14:45:59 UTC 2022
Updates #3053.
 .../psxhdrs/sched/sched_get_priority_max.c    | 25 ++++++++++++++++---
 .../psxhdrs/sched/sched_get_priority_min.c    | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sched/sched_getparam.c   | 25 ++++++++++++++++---
 .../psxhdrs/sched/sched_getscheduler.c        | 25 ++++++++++++++++---
 .../psxhdrs/sched/sched_rr_get_interval.c     | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sched/sched_setparam.c   | 25 ++++++++++++++++---
 .../psxhdrs/sched/sched_setscheduler.c        | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sched/sched_yield.c      | 25 ++++++++++++++++---
 8 files changed, 176 insertions(+), 24 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_get_priority_max.c b/testsuites/psxtests/psxhdrs/sched/sched_get_priority_max.c
index 1180af5af0..4f29137aec 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_get_priority_max.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_get_priority_max.c
@@ -1,3 +1,5 @@
  *  This test file is used to verify that the header files associated with
  *  invoking this function are correct.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_get_priority_min.c b/testsuites/psxtests/psxhdrs/sched/sched_get_priority_min.c
index f9cabaf95c..d9a1a71739 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_get_priority_min.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_get_priority_min.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_getparam.c b/testsuites/psxtests/psxhdrs/sched/sched_getparam.c
index 00a9a81656..6dda45340b 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_getparam.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_getparam.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_getscheduler.c b/testsuites/psxtests/psxhdrs/sched/sched_getscheduler.c
index 111597d70f..4f91d02bca 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_getscheduler.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_getscheduler.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_rr_get_interval.c b/testsuites/psxtests/psxhdrs/sched/sched_rr_get_interval.c
index 6fe2a1b22d..ae114ac247 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_rr_get_interval.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_rr_get_interval.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_setparam.c b/testsuites/psxtests/psxhdrs/sched/sched_setparam.c
index f653d228b7..b3cfd8f3d6 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_setparam.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_setparam.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_setscheduler.c b/testsuites/psxtests/psxhdrs/sched/sched_setscheduler.c
index 54bfbb8f28..5d42c0c0fc 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_setscheduler.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_setscheduler.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sched/sched_yield.c b/testsuites/psxtests/psxhdrs/sched/sched_yield.c
index 0f2ac9200d..b10b7abd5b 100644
--- a/testsuites/psxtests/psxhdrs/sched/sched_yield.c
+++ b/testsuites/psxtests/psxhdrs/sched/sched_yield.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
2.24.4
