[PATCH 32/39] testsuites/psxtests/psxhdrs/signal*: Change license to BSD-2
Fri Apr 8 14:46:00 UTC 2022
Updates #3053.
 .../psxtests/psxhdrs/signal/pthread_sigmask.c | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/signal/raise.c    | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/signal/signal.c   | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/signal/sigpending.c      | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/signal/sigprocmask.c     | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/signal/sigsuspend.c      | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/signal/sigtimedwait.c    | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/signal/sigwait.c  | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/signal/sigwaitinfo.c     | 25 ++++++++++++++++---
 9 files changed, 198 insertions(+), 27 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/signal/pthread_sigmask.c b/testsuites/psxtests/psxhdrs/signal/pthread_sigmask.c
index 2820038d16..e1c2e989c5 100644
--- a/testsuites/psxtests/psxhdrs/signal/pthread_sigmask.c
+++ b/testsuites/psxtests/psxhdrs/signal/pthread_sigmask.c
@@ -1,3 +1,5 @@
  *  This test file is used to verify that the header files associated with
  *  invoking this function are correct.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxhdrs/signal/raise.c b/testsuites/psxtests/psxhdrs/signal/raise.c
index d504de881d..4fd920c4ce 100644
--- a/testsuites/psxtests/psxhdrs/signal/raise.c
+++ b/testsuites/psxtests/psxhdrs/signal/raise.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/signal.c b/testsuites/psxtests/psxhdrs/signal/signal.c
index 8985ee9647..4900f3814d 100644
--- a/testsuites/psxtests/psxhdrs/signal/signal.c
+++ b/testsuites/psxtests/psxhdrs/signal/signal.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/sigpending.c b/testsuites/psxtests/psxhdrs/signal/sigpending.c
index abe00ad25c..5436017382 100644
--- a/testsuites/psxtests/psxhdrs/signal/sigpending.c
+++ b/testsuites/psxtests/psxhdrs/signal/sigpending.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/sigprocmask.c b/testsuites/psxtests/psxhdrs/signal/sigprocmask.c
index f020395f5c..40e787c747 100644
--- a/testsuites/psxtests/psxhdrs/signal/sigprocmask.c
+++ b/testsuites/psxtests/psxhdrs/signal/sigprocmask.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/sigsuspend.c b/testsuites/psxtests/psxhdrs/signal/sigsuspend.c
index b4204af143..282125386e 100644
--- a/testsuites/psxtests/psxhdrs/signal/sigsuspend.c
+++ b/testsuites/psxtests/psxhdrs/signal/sigsuspend.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/sigtimedwait.c b/testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
index dce7c974af..32e7ac6e41 100644
--- a/testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
+++ b/testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/sigwait.c b/testsuites/psxtests/psxhdrs/signal/sigwait.c
index f007005b2a..9cd59f5abe 100644
--- a/testsuites/psxtests/psxhdrs/signal/sigwait.c
+++ b/testsuites/psxtests/psxhdrs/signal/sigwait.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c b/testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
index 836b1ba0fc..e6a0485680 100644
--- a/testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
+++ b/testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
2.24.4
