[PATCH 34/39] testsuites/psxtests/psxhdrs/sys/socket/*: Change license to BSD-2
Fri Apr 8 14:46:02 UTC 2022
Updates #3053.
 .../psxtests/psxhdrs/sys/socket/accept.c      | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/sys/socket/bind.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/connect.c     | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/getpeername.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/getsockname.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/getsockopt.c  | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/listen.c      | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/sys/socket/recv.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/recvfrom.c    | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/recvmsg.c     | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/sys/socket/send.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/sendmsg.c     | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/sendto.c      | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/setsockopt.c  | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/shutdown.c    | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/socket.c      | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/sys/socket/socketpair.c  | 25 ++++++++++++++++---
 17 files changed, 374 insertions(+), 51 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/accept.c b/testsuites/psxtests/psxhdrs/sys/socket/accept.c
index f57ecd5410..5dc58ba595 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/accept.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/accept.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 2015.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/bind.c b/testsuites/psxtests/psxhdrs/sys/socket/bind.c
index 8572fc20b3..3da39b31ff 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/bind.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/bind.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/connect.c b/testsuites/psxtests/psxhdrs/sys/socket/connect.c
index 2f852bfc97..1b8f5b9001 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/connect.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/connect.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/getpeername.c b/testsuites/psxtests/psxhdrs/sys/socket/getpeername.c
index 94c5988466..0027d9ad15 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/getpeername.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/getpeername.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/getsockname.c b/testsuites/psxtests/psxhdrs/sys/socket/getsockname.c
index 53863a8b00..1f80eeca41 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/getsockname.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/getsockname.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c b/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
index 9554068a98..0ecf27dda5 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/listen.c b/testsuites/psxtests/psxhdrs/sys/socket/listen.c
index 0edb16bc8b..9e243a5c22 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/listen.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/listen.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/recv.c b/testsuites/psxtests/psxhdrs/sys/socket/recv.c
index 05bc608b10..3e99e0a3a3 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/recv.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/recv.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/recvfrom.c b/testsuites/psxtests/psxhdrs/sys/socket/recvfrom.c
index 0f9f948e5d..4473ef4ac6 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/recvfrom.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/recvfrom.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/recvmsg.c b/testsuites/psxtests/psxhdrs/sys/socket/recvmsg.c
index 76723268af..b10550864f 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/recvmsg.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/recvmsg.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/send.c b/testsuites/psxtests/psxhdrs/sys/socket/send.c
index 65394a9586..b93a87f482 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/send.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/send.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c b/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
index bf6115b00f..3205271572 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/sendto.c b/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
index e93f4c1aac..298d17f4ec 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c b/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
index 2dd396a1a1..d373add6de 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/shutdown.c b/testsuites/psxtests/psxhdrs/sys/socket/shutdown.c
index d804295aa3..03d14836fc 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/shutdown.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/shutdown.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/socket.c b/testsuites/psxtests/psxhdrs/sys/socket/socket.c
index ac692fe443..c2fe0331c6 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/socket.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/socket.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/sys/socket/socketpair.c b/testsuites/psxtests/psxhdrs/sys/socket/socketpair.c
index 9cc67a9b63..41018fa48c 100644
--- a/testsuites/psxtests/psxhdrs/sys/socket/socketpair.c
+++ b/testsuites/psxtests/psxhdrs/sys/socket/socketpair.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
2.24.4
