[PATCH 35/39] testsuites/psxtests/psxhdrs/time/*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:46:03 UTC 2022
Updates #3053.
testsuites/psxtests/psxhdrs/time/asctime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/asctime_r.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/clock.c | 25 ++++++++++++++++---
.../psxhdrs/time/clock_getcpuclockid.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/clock_getres.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/clock_gettime.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/clock_nanosleep.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/clock_settime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/ctime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/ctime_r.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/difftime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/gmtime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/gmtime_r.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/localtime.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/localtime_r.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/mktime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/nanosleep.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/strftime.c | 25 ++++++++++++++++---
testsuites/psxtests/psxhdrs/time/time.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/timer_create.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/timer_delete.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/timer_getoverrun.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/timer_gettime.c | 25 ++++++++++++++++---
.../psxtests/psxhdrs/time/timer_settime.c | 25 ++++++++++++++++---
24 files changed, 528 insertions(+), 72 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/time/asctime.c b/testsuites/psxtests/psxhdrs/time/asctime.c
index 1145fc9936..c02a543d6b 100644
--- a/testsuites/psxtests/psxhdrs/time/asctime.c
+++ b/testsuites/psxtests/psxhdrs/time/asctime.c
@@ -1,3 +1,5 @@
* This test file is used to verify that the header files associated with
* invoking this function are correct.
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2009.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxhdrs/time/asctime_r.c b/testsuites/psxtests/psxhdrs/time/asctime_r.c
index 609709b223..231ea14dfb 100644
--- a/testsuites/psxtests/psxhdrs/time/asctime_r.c
+++ b/testsuites/psxtests/psxhdrs/time/asctime_r.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/clock.c b/testsuites/psxtests/psxhdrs/time/clock.c
index de836968e0..2ea3e09f00 100644
--- a/testsuites/psxtests/psxhdrs/time/clock.c
+++ b/testsuites/psxtests/psxhdrs/time/clock.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/clock_getcpuclockid.c b/testsuites/psxtests/psxhdrs/time/clock_getcpuclockid.c
index b15210ebc4..3d50bfc580 100644
--- a/testsuites/psxtests/psxhdrs/time/clock_getcpuclockid.c
+++ b/testsuites/psxtests/psxhdrs/time/clock_getcpuclockid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/clock_getres.c b/testsuites/psxtests/psxhdrs/time/clock_getres.c
index 9e11405d73..773f057399 100644
--- a/testsuites/psxtests/psxhdrs/time/clock_getres.c
+++ b/testsuites/psxtests/psxhdrs/time/clock_getres.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/clock_gettime.c b/testsuites/psxtests/psxhdrs/time/clock_gettime.c
index c45141ab78..a992fac632 100644
--- a/testsuites/psxtests/psxhdrs/time/clock_gettime.c
+++ b/testsuites/psxtests/psxhdrs/time/clock_gettime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/clock_nanosleep.c b/testsuites/psxtests/psxhdrs/time/clock_nanosleep.c
index 1c0fe0b496..6298d0c045 100644
--- a/testsuites/psxtests/psxhdrs/time/clock_nanosleep.c
+++ b/testsuites/psxtests/psxhdrs/time/clock_nanosleep.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
* Copyright (c) 2016 Gedare Bloom.
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/clock_settime.c b/testsuites/psxtests/psxhdrs/time/clock_settime.c
index f81a148f89..8a4d88c37f 100644
--- a/testsuites/psxtests/psxhdrs/time/clock_settime.c
+++ b/testsuites/psxtests/psxhdrs/time/clock_settime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/ctime.c b/testsuites/psxtests/psxhdrs/time/ctime.c
index bc22186d2c..f778e726a9 100644
--- a/testsuites/psxtests/psxhdrs/time/ctime.c
+++ b/testsuites/psxtests/psxhdrs/time/ctime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/ctime_r.c b/testsuites/psxtests/psxhdrs/time/ctime_r.c
index b28f185d34..b973a504ae 100644
--- a/testsuites/psxtests/psxhdrs/time/ctime_r.c
+++ b/testsuites/psxtests/psxhdrs/time/ctime_r.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/difftime.c b/testsuites/psxtests/psxhdrs/time/difftime.c
index 59d7ec9214..df357c5650 100644
--- a/testsuites/psxtests/psxhdrs/time/difftime.c
+++ b/testsuites/psxtests/psxhdrs/time/difftime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/gmtime.c b/testsuites/psxtests/psxhdrs/time/gmtime.c
index 6f9160175b..7118162c84 100644
--- a/testsuites/psxtests/psxhdrs/time/gmtime.c
+++ b/testsuites/psxtests/psxhdrs/time/gmtime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/gmtime_r.c b/testsuites/psxtests/psxhdrs/time/gmtime_r.c
index 4b3a53c980..58f6a3212a 100644
--- a/testsuites/psxtests/psxhdrs/time/gmtime_r.c
+++ b/testsuites/psxtests/psxhdrs/time/gmtime_r.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/localtime.c b/testsuites/psxtests/psxhdrs/time/localtime.c
index be6a5fd117..674d8e43c2 100644
--- a/testsuites/psxtests/psxhdrs/time/localtime.c
+++ b/testsuites/psxtests/psxhdrs/time/localtime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/localtime_r.c b/testsuites/psxtests/psxhdrs/time/localtime_r.c
index 19bb6917f7..be85af36c5 100644
--- a/testsuites/psxtests/psxhdrs/time/localtime_r.c
+++ b/testsuites/psxtests/psxhdrs/time/localtime_r.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/mktime.c b/testsuites/psxtests/psxhdrs/time/mktime.c
index c8654b813c..07920211a8 100644
--- a/testsuites/psxtests/psxhdrs/time/mktime.c
+++ b/testsuites/psxtests/psxhdrs/time/mktime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/nanosleep.c b/testsuites/psxtests/psxhdrs/time/nanosleep.c
index ef41e67c87..1082dc162e 100644
--- a/testsuites/psxtests/psxhdrs/time/nanosleep.c
+++ b/testsuites/psxtests/psxhdrs/time/nanosleep.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/strftime.c b/testsuites/psxtests/psxhdrs/time/strftime.c
index 5c456ca079..ee27e7b8d4 100644
--- a/testsuites/psxtests/psxhdrs/time/strftime.c
+++ b/testsuites/psxtests/psxhdrs/time/strftime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/time.c b/testsuites/psxtests/psxhdrs/time/time.c
index a940748b43..2932e898c2 100644
--- a/testsuites/psxtests/psxhdrs/time/time.c
+++ b/testsuites/psxtests/psxhdrs/time/time.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/timer_create.c b/testsuites/psxtests/psxhdrs/time/timer_create.c
index 7291b97c09..0b2e705ffe 100644
--- a/testsuites/psxtests/psxhdrs/time/timer_create.c
+++ b/testsuites/psxtests/psxhdrs/time/timer_create.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/timer_delete.c b/testsuites/psxtests/psxhdrs/time/timer_delete.c
index f64c8a2f09..8e6a3ce30e 100644
--- a/testsuites/psxtests/psxhdrs/time/timer_delete.c
+++ b/testsuites/psxtests/psxhdrs/time/timer_delete.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/timer_getoverrun.c b/testsuites/psxtests/psxhdrs/time/timer_getoverrun.c
index d5808b4844..14946f5793 100644
--- a/testsuites/psxtests/psxhdrs/time/timer_getoverrun.c
+++ b/testsuites/psxtests/psxhdrs/time/timer_getoverrun.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/timer_gettime.c b/testsuites/psxtests/psxhdrs/time/timer_gettime.c
index b722daf13f..f941a89b7e 100644
--- a/testsuites/psxtests/psxhdrs/time/timer_gettime.c
+++ b/testsuites/psxtests/psxhdrs/time/timer_gettime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/time/timer_settime.c b/testsuites/psxtests/psxhdrs/time/timer_settime.c
index 99b13267d3..9332e01813 100644
--- a/testsuites/psxtests/psxhdrs/time/timer_settime.c
+++ b/testsuites/psxtests/psxhdrs/time/timer_settime.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
2.24.4
