[PATCH 37/39] testsuites/samples: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:46:05 UTC 2022
Updates #3053.
testsuites/samples/base_mp/apptask.c | 25 ++++++++++++++++++++++---
testsuites/samples/base_mp/initimpl.h | 25 ++++++++++++++++++++++---
testsuites/samples/base_mp/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/base_sp/apptask.c | 25 ++++++++++++++++++++++---
testsuites/samples/base_sp/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/base_sp/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/capture/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/capture/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/capture/test1.c | 25 ++++++++++++++++++++++---
testsuites/samples/cdtest/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/cdtest/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/fileio/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/fileio/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/hello/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/iostream/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/minimum/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/nsecs/empty.c | 25 ++++++++++++++++++++++---
testsuites/samples/nsecs/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/paranoia/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/paranoia/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/ticker/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/ticker/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/ticker/tasks.c | 25 ++++++++++++++++++++++---
testsuites/samples/unlimited/init.c | 25 ++++++++++++++++++++++---
testsuites/samples/unlimited/system.h | 25 ++++++++++++++++++++++---
testsuites/samples/unlimited/test1.c | 25 ++++++++++++++++++++++---
testsuites/samples/unlimited/test2.c | 25 ++++++++++++++++++++++---
testsuites/samples/unlimited/test3.c | 25 ++++++++++++++++++++++---
28 files changed, 616 insertions(+), 84 deletions(-)
diff --git a/testsuites/samples/base_mp/apptask.c b/testsuites/samples/base_mp/apptask.c
index 063328ed42..154748b05b 100644
--- a/testsuites/samples/base_mp/apptask.c
+++ b/testsuites/samples/base_mp/apptask.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-1999, 2016.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/samples/base_mp/initimpl.h b/testsuites/samples/base_mp/initimpl.h
index f2bd12d0fc..93ac5fa0d0 100644
--- a/testsuites/samples/base_mp/initimpl.h
+++ b/testsuites/samples/base_mp/initimpl.h
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/samples/base_mp/system.h b/testsuites/samples/base_mp/system.h
index 97c76f5e24..d4c163aa94 100644
--- a/testsuites/samples/base_mp/system.h
+++ b/testsuites/samples/base_mp/system.h
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/testsuites/samples/base_sp/apptask.c b/testsuites/samples/base_sp/apptask.c
index 02df777bea..940a05dc93 100644
--- a/testsuites/samples/base_sp/apptask.c
+++ b/testsuites/samples/base_sp/apptask.c
@@ -1,3 +1,5 @@
/* Application_task
* This routine is as an example of an application task which
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/testsuites/samples/base_sp/init.c b/testsuites/samples/base_sp/init.c
index 071913a390..ad8b1c41b8 100644
--- a/testsuites/samples/base_sp/init.c
+++ b/testsuites/samples/base_sp/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/base_sp/system.h b/testsuites/samples/base_sp/system.h
index 0b49edb465..2a88767323 100644
--- a/testsuites/samples/base_sp/system.h
+++ b/testsuites/samples/base_sp/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/samples/capture/init.c b/testsuites/samples/capture/init.c
index 2bf395fdad..78b1082b7f 100644
--- a/testsuites/samples/capture/init.c
+++ b/testsuites/samples/capture/init.c
@@ -1,10 +1,29 @@
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
+ * are met:
#define CONFIGURE_INIT
diff --git a/testsuites/samples/capture/system.h b/testsuites/samples/capture/system.h
index 7f915dc830..181235d0df 100644
--- a/testsuites/samples/capture/system.h
+++ b/testsuites/samples/capture/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-1997.
+ * are met:
diff --git a/testsuites/samples/capture/test1.c b/testsuites/samples/capture/test1.c
index 2f4193adb2..9a538e27fe 100644
--- a/testsuites/samples/capture/test1.c
+++ b/testsuites/samples/capture/test1.c
@@ -1,3 +1,5 @@
/* Test1
* This test uses creates a number of tasks so the capture engine
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/samples/cdtest/init.c b/testsuites/samples/cdtest/init.c
index 1cf2b20f77..77b5878b79 100644
--- a/testsuites/samples/cdtest/init.c
+++ b/testsuites/samples/cdtest/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/cdtest/system.h b/testsuites/samples/cdtest/system.h
index 7d14747a32..748e2ef1bc 100644
--- a/testsuites/samples/cdtest/system.h
+++ b/testsuites/samples/cdtest/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
index c552d33613..084d54d81a 100644
--- a/testsuites/samples/fileio/init.c
+++ b/testsuites/samples/fileio/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
index 54e2441184..711facf94e 100644
--- a/testsuites/samples/fileio/system.h
+++ b/testsuites/samples/fileio/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 34ded37c55..83f6342ab3 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/iostream/system.h b/testsuites/samples/iostream/system.h
index 696cb8df34..63d27f9996 100644
--- a/testsuites/samples/iostream/system.h
+++ b/testsuites/samples/iostream/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/samples/minimum/init.c b/testsuites/samples/minimum/init.c
index a63e7783da..c988d6d750 100644
--- a/testsuites/samples/minimum/init.c
+++ b/testsuites/samples/minimum/init.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/samples/nsecs/empty.c b/testsuites/samples/nsecs/empty.c
index e426455bca..ba41878347 100644
--- a/testsuites/samples/nsecs/empty.c
+++ b/testsuites/samples/nsecs/empty.c
@@ -1,9 +1,28 @@
/* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/testsuites/samples/nsecs/init.c b/testsuites/samples/nsecs/init.c
index 59995f1da8..6f63cbd51f 100644
--- a/testsuites/samples/nsecs/init.c
+++ b/testsuites/samples/nsecs/init.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/samples/paranoia/init.c b/testsuites/samples/paranoia/init.c
index f2420baaf6..b40ad9e0bc 100644
--- a/testsuites/samples/paranoia/init.c
+++ b/testsuites/samples/paranoia/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/paranoia/system.h b/testsuites/samples/paranoia/system.h
index 740c8ec5b9..7915a78c44 100644
--- a/testsuites/samples/paranoia/system.h
+++ b/testsuites/samples/paranoia/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/samples/ticker/init.c b/testsuites/samples/ticker/init.c
index 5bd5568c18..86f87ad736 100644
--- a/testsuites/samples/ticker/init.c
+++ b/testsuites/samples/ticker/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/ticker/system.h b/testsuites/samples/ticker/system.h
index 4ac3f59f16..9495f45547 100644
--- a/testsuites/samples/ticker/system.h
+++ b/testsuites/samples/ticker/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/samples/ticker/tasks.c b/testsuites/samples/ticker/tasks.c
index 7ff6eb7319..26fe228646 100644
--- a/testsuites/samples/ticker/tasks.c
+++ b/testsuites/samples/ticker/tasks.c
@@ -1,3 +1,5 @@
/* Test_task
* This routine serves as a test task. It verifies the basic task
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/samples/unlimited/init.c b/testsuites/samples/unlimited/init.c
index 77f4dedd3a..c80ec87786 100644
--- a/testsuites/samples/unlimited/init.c
+++ b/testsuites/samples/unlimited/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
index 4138b658fe..daf80975a7 100644
--- a/testsuites/samples/unlimited/system.h
+++ b/testsuites/samples/unlimited/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/testsuites/samples/unlimited/test1.c b/testsuites/samples/unlimited/test1.c
index 3fe2688681..5c5e427761 100644
--- a/testsuites/samples/unlimited/test1.c
+++ b/testsuites/samples/unlimited/test1.c
@@ -1,3 +1,5 @@
/* Test1
* This test uses a hack to disable suto-extend then checks to see only the
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/samples/unlimited/test2.c b/testsuites/samples/unlimited/test2.c
index 411a401c4e..72546c4f91 100644
--- a/testsuites/samples/unlimited/test2.c
+++ b/testsuites/samples/unlimited/test2.c
@@ -1,3 +1,5 @@
/* Init
* This routine is the initialization task for this test program.
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/samples/unlimited/test3.c b/testsuites/samples/unlimited/test3.c
index 6330f3c445..c67bdb9351 100644
--- a/testsuites/samples/unlimited/test3.c
+++ b/testsuites/samples/unlimited/test3.c
@@ -1,3 +1,5 @@
/* Init
@@ -13,9 +15,26 @@
+ * are met:
2.24.4
