[PATCH 36/39] testsuites/psxtests/psxhdrs/unistd/*: Change license to BSD-2
Fri Apr 8 14:46:04 UTC 2022
Updates #3053.
 testsuites/psxtests/psxhdrs/unistd/alarm.c    | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/unistd/fdatasync.c       | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/fsync.c    | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getegid.c  | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/geteuid.c  | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getgid.c   | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/unistd/getgroups.c       | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getlogin.c | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/unistd/getlogin_r.c      | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getpgrp.c  | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getpid.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getppid.c  | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/getuid.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/pause.c    | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/setgid.c   | 25 ++++++++++++++++---
 .../psxtests/psxhdrs/unistd/setgroups.c       | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/setpgid.c  | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/setsid.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/setuid.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/sleep.c    | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/sync.c     | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/ualarm.c   | 25 ++++++++++++++++---
 testsuites/psxtests/psxhdrs/unistd/usleep.c   | 25 ++++++++++++++++---
 23 files changed, 506 insertions(+), 69 deletions(-)
diff --git a/testsuites/psxtests/psxhdrs/unistd/alarm.c b/testsuites/psxtests/psxhdrs/unistd/alarm.c
index 7bafabddbb..b3d20f0f8a 100644
--- a/testsuites/psxtests/psxhdrs/unistd/alarm.c
+++ b/testsuites/psxtests/psxhdrs/unistd/alarm.c
@@ -1,3 +1,5 @@
  *  This test file is used to verify that the header files associated with
  *  invoking this function are correct.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/psxtests/psxhdrs/unistd/fdatasync.c b/testsuites/psxtests/psxhdrs/unistd/fdatasync.c
index 8d1900b9e7..01b53148f1 100644
--- a/testsuites/psxtests/psxhdrs/unistd/fdatasync.c
+++ b/testsuites/psxtests/psxhdrs/unistd/fdatasync.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/fsync.c b/testsuites/psxtests/psxhdrs/unistd/fsync.c
index f7ef722bfb..d7b9454c05 100644
--- a/testsuites/psxtests/psxhdrs/unistd/fsync.c
+++ b/testsuites/psxtests/psxhdrs/unistd/fsync.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getegid.c b/testsuites/psxtests/psxhdrs/unistd/getegid.c
index 1626223c90..44b8e90838 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getegid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getegid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/geteuid.c b/testsuites/psxtests/psxhdrs/unistd/geteuid.c
index a580ecf18a..cc68ff7b86 100644
--- a/testsuites/psxtests/psxhdrs/unistd/geteuid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/geteuid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getgid.c b/testsuites/psxtests/psxhdrs/unistd/getgid.c
index 6f0d9328be..633b4506d4 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getgid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getgid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getgroups.c b/testsuites/psxtests/psxhdrs/unistd/getgroups.c
index 6101e2aa0c..9b0b68b784 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getgroups.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getgroups.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getlogin.c b/testsuites/psxtests/psxhdrs/unistd/getlogin.c
index 6646461751..310fa97ed4 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getlogin.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getlogin.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getlogin_r.c b/testsuites/psxtests/psxhdrs/unistd/getlogin_r.c
index 587206e44c..279494497b 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getlogin_r.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getlogin_r.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getpgrp.c b/testsuites/psxtests/psxhdrs/unistd/getpgrp.c
index 22d1cc5d2c..4c525fb833 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getpgrp.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getpgrp.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getpid.c b/testsuites/psxtests/psxhdrs/unistd/getpid.c
index f46bbff2ad..15eaf2689d 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getpid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getpid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getppid.c b/testsuites/psxtests/psxhdrs/unistd/getppid.c
index 2be588847c..04525178fd 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getppid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getppid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/getuid.c b/testsuites/psxtests/psxhdrs/unistd/getuid.c
index e06b407232..7132bfb00d 100644
--- a/testsuites/psxtests/psxhdrs/unistd/getuid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/getuid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/pause.c b/testsuites/psxtests/psxhdrs/unistd/pause.c
index 47898bce0e..5c2b267d98 100644
--- a/testsuites/psxtests/psxhdrs/unistd/pause.c
+++ b/testsuites/psxtests/psxhdrs/unistd/pause.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/setgid.c b/testsuites/psxtests/psxhdrs/unistd/setgid.c
index 5a3a984d2e..43f5f0d0cc 100644
--- a/testsuites/psxtests/psxhdrs/unistd/setgid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/setgid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/setgroups.c b/testsuites/psxtests/psxhdrs/unistd/setgroups.c
index ae1fedfa2a..b40547a5e8 100644
--- a/testsuites/psxtests/psxhdrs/unistd/setgroups.c
+++ b/testsuites/psxtests/psxhdrs/unistd/setgroups.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/setpgid.c b/testsuites/psxtests/psxhdrs/unistd/setpgid.c
index 5bf1f7833a..8af4ee0c07 100644
--- a/testsuites/psxtests/psxhdrs/unistd/setpgid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/setpgid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/setsid.c b/testsuites/psxtests/psxhdrs/unistd/setsid.c
index cb0e65ff62..f984830852 100644
--- a/testsuites/psxtests/psxhdrs/unistd/setsid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/setsid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/setuid.c b/testsuites/psxtests/psxhdrs/unistd/setuid.c
index 55a42515d5..6948b51cfb 100644
--- a/testsuites/psxtests/psxhdrs/unistd/setuid.c
+++ b/testsuites/psxtests/psxhdrs/unistd/setuid.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/sleep.c b/testsuites/psxtests/psxhdrs/unistd/sleep.c
index 2807eef9e8..9c3f94abeb 100644
--- a/testsuites/psxtests/psxhdrs/unistd/sleep.c
+++ b/testsuites/psxtests/psxhdrs/unistd/sleep.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/sync.c b/testsuites/psxtests/psxhdrs/unistd/sync.c
index decdbefbc1..0b78be5e1f 100644
--- a/testsuites/psxtests/psxhdrs/unistd/sync.c
+++ b/testsuites/psxtests/psxhdrs/unistd/sync.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/ualarm.c b/testsuites/psxtests/psxhdrs/unistd/ualarm.c
index ba2ec219a6..9472f05399 100644
--- a/testsuites/psxtests/psxhdrs/unistd/ualarm.c
+++ b/testsuites/psxtests/psxhdrs/unistd/ualarm.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/testsuites/psxtests/psxhdrs/unistd/usleep.c b/testsuites/psxtests/psxhdrs/unistd/usleep.c
index 738c088c85..624f613e69 100644
--- a/testsuites/psxtests/psxhdrs/unistd/usleep.c
+++ b/testsuites/psxtests/psxhdrs/unistd/usleep.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
+ * are met:
2.24.4
