[PATCH 39/39] psxtmtests/psxtmkey02/init.c: Manually change license to BSD-2
Fri Apr 8 14:46:07 UTC 2022
    This has yet another typo in the license and was missed by the script.
Updates #3053.
 testsuites/psxtmtests/psxtmkey02/init.c | 23 ++++++++++++++++++++---
 1 file changed, 20 insertions(+), 3 deletions(-)
diff --git a/testsuites/psxtmtests/psxtmkey02/init.c b/testsuites/psxtmtests/psxtmkey02/init.c
index 268bbfe3a3..fa24387f9b 100644
--- a/testsuites/psxtmtests/psxtmkey02/init.c
+++ b/testsuites/psxtmtests/psxtmkey02/init.c
@@ -2,9 +2,26 @@
  *  COPYRIGHT (c) 1989-2013.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http:www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
2.24.4
