List third party files in cpukit and testsuites
Ryan Long
ryan.long at oarcorp.com
Fri Apr 8 18:34:43 UTC 2022
This is the set of files in the source code that are all third party.
This means they should not be re-licensed or re-formatted.
If anything on this list is wrong, or if I missed some, please comment.
Thanks,
Ryan
David Gibson, IBM Corporation
cpukit/dtc/libfdt/fdt.c
cpukit/dtc/libfdt/fdt_empty_tree.c
cpukit/dtc/libfdt/fdt_ro.c
cpukit/dtc/libfdt/fdt_rw.c
cpukit/dtc/libfdt/fdt_strerror.c
cpukit/dtc/libfdt/fdt_sw.c
cpukit/dtc/libfdt/fdt_wip.c
cpukit/dtc/libfdt/libfdt_internal.h
cpukit/include/fdt.h
cpukit/include/libfdt.h
cpukit/include/libfdt_env.h
The Regents of the University of California
cpukit/include/arpa/ftp.h
cpukit/include/machine/_kernel_in.h
cpukit/include/machine/_kernel_mman.h
.cpukit/libmisc/shell/dd-args.c
cpukit/libmisc/shell/dd-conv.c
cpukit/libmisc/shell/dd-conv_tab.c
cpukit/libmisc/shell/dd-misc.c
cpukit/libmisc/shell/dd-position.c
cpukit/libmisc/shell/dd.h
cpukit/libmisc/shell/err.c
cpukit/libmisc/shell/err.h
cpukit/libmisc/shell/errx.c
cpukit/libmisc/shell/extern-cp.h
cpukit/libmisc/shell/extern-dd.h
cpukit/libmisc/shell/extern-ls.h
cpukit/libmisc/shell/filemode.c
cpukit/libmisc/shell/fts.c
cpukit/libmisc/shell/fts.h
cpukit/libmisc/shell/hexdump-conv.c
cpukit/libmisc/shell/hexdump-display.c
cpukit/libmisc/shell/hexdump-odsyntax.c
cpukit/libmisc/shell/hexdump-parse.c
cpukit/libmisc/shell/hexdump.h
cpukit/libmisc/shell/hexsyntax.c
cpukit/libmisc/shell/main_cp.c
cpukit/libmisc/shell/main_dd.c
cpukit/libmisc/shell/main_echo.c
cpukit/libmisc/shell/main_hexdump.c
cpukit/libmisc/shell/main_mv.c
cpukit/libmisc/shell/main_ln.c
cpukit/libmisc/shell/main_ls.c
cpukit/libmisc/shell/main_rm.c
cpukit/libmisc/shell/pathnames-mv.h
cpukit/libmisc/shell/print-ls.c
cpukit/libmisc/shell/pwcache.c
cpukit/libmisc/shell/sysexits.h
cpukit/libmisc/shell/utils-cp.c
cpukit/libmisc/shell/utils-ls.c
cpukit/libmisc/shell/verr.c
cpukit/libmisc/shell/verrx.c
cpukit/libmisc/shell/vis.c
cpukit/libmisc/shell/vis.h
cpukit/libmisc/shell/vwarn.c
cpukit/libmisc/shell/vwarnx.c
cpukit/libmisc/shell/warn.c
cpukit/libmisc/shell/warnx.c
cpukit/score/src/iovprintf.c
cpukit/libcsupport/src/cfmakeraw.c
cpukit/libcsupport/src/cfmakesane.c
/include/machine/_kernel_uio.h
Mark Murray
cpukit/include/crypt.h
NetBSD
cpukit/include/dlfcn.h
cpukit/include/link.h
cpukit/include/link_elf.h
cpukit/libmisc/shell/cmp-ls.c
cpukit/libdl/rtl-mdreloc-arm.c
cpukit/libdl/rtl-mdreloc-i386.c
cpukit/libdl/rtl-mdreloc-m68k.c
cpukit/libdl/rtl-mdreloc-riscv.c
cpukit/libdl/rtl-mdreloc-sparc.c
cpukit/libmisc/shell/main_mknod.c
cpukit/libmisc/shell/mknod-pack_dev.c
cpukit/libmisc/shell/mknod-pack_dev.h
cpukit/score/cpu/i386/include/machine/elf_machdep.h
cpukit/score/cpu/m68k/include/machine/elf_machdep.h
cpukit/score/cpu/mips/include/machine/elf_machdep.h
cpukit/score/cpu/nios2/include/machine/elf_machdep.h
cpukit/score/cpu/sparc/include/machine/elf_machdep.h
cpukit/score/cpu/x86_64/include/machine/elf_machdep.h
cpukit/include/sys/cdefs_elf.h
cpukit/include/sys/exec_elf.h
cpukit/telnetd/des.c
WIDE Project
cpukit/include/machine/_kernel_in6.h
RSA Data Security, Inc.
cpukit/include/md4.h
cpukit/include/md5.h
Sergey Lyubka
cpukit/include/mghttpd/mongoose.h
cpukit/mghttpd/mongoose.c
FreeBSD
cpukit/include/pci/pcireg.h
cpukit/libstdthreads/call_once.c
cpukit/libstdthreads/thrd.c
cpukit/libstdthreads/tss.c
cpukit/include/sys/endian.h
cpukit/include/sys/event.h
cpukit/include/sys/poll.h
cpukit/include/sys/priority.h
cpukit/include/sys/timepps.h
cpukit/include/sys/timetc.h
cpukit/include/sys/timex.h
cpukit/libcrypt/crypt-sha256.c
cpukit/libcrypt/crypt-sha512.c
cpukit/score/src/kern_ntptime.c
cpukit/score/src/kern_tc.c
cpukit/include/sha256.h
cpukit/include/sha512.h
cpukit/include/sys/_ffcounter.h
cpukit/include/sys/timeffc.h
Public Software Group
cpukit/include/utf8proc/utf8proc.h
cpukit/libmisc/utf8proc/utf8proc.c
Poul-Henning Kamp
cpukit/libcrypt/crypt-md5.c
cpukit/libcrypt/misc.c
testsuites/samples/paranoia/paranoia.c
Ariya Hidayat <ariya at kde.org>
cpukit/libdl/fastlz.c
cpukit/libdl/fastlz.h
Kevin Kirspel <kirspkt at gmail.com>
cpukit/libfs/src/defaults/default_mmap.c
Red Hat
cpukit/libfs/src/jffs2/include/asm/atomic.h
cpukit/libfs/src/jffs2/include/asm/bug.h
cpukit/libfs/src/jffs2/include/asm/page.h
cpukit/libfs/src/jffs2/include/cyg/crc/crc.h
cpukit/libfs/src/jffs2/include/cyg/infra/cyg_type.h
cpukit/libfs/src/jffs2/include/linux/compiler.h
cpukit/libfs/src/jffs2/include/linux/completion.h
cpukit/libfs/src/jffs2/include/linux/config.h
cpukit/libfs/src/jffs2/include/linux/crc32.h
cpukit/libfs/src/jffs2/include/linux/errno.h
cpukit/libfs/src/jffs2/include/linux/fs.h
cpukit/libfs/src/jffs2/include/linux/jffs2.h
cpukit/libfs/src/jffs2/include/linux/kernel.h
cpukit/libfs/src/jffs2/include/linux/list.h
cpukit/libfs/src/jffs2/include/linux/magic.h
cpukit/libfs/src/jffs2/include/linux/mm.h
cpukit/libfs/src/jffs2/include/linux/mtd/compatmac.h
cpukit/libfs/src/jffs2/include/linux/mtd/mtd.h
cpukit/libfs/src/jffs2/include/linux/mutex.h
cpukit/libfs/src/jffs2/include/linux/pagemap.h
cpukit/libfs/src/jffs2/include/linux/posix_acl.h
cpukit/libfs/src/jffs2/include/linux/rwsem.h
cpukit/libfs/src/jffs2/include/linux/sched.h
cpukit/libfs/src/jffs2/include/linux/sched/signal.h
cpukit/libfs/src/jffs2/include/linux/slab.h
cpukit/libfs/src/jffs2/include/linux/spinlock.h
cpukit/libfs/src/jffs2/include/linux/stat.h
cpukit/libfs/src/jffs2/include/linux/string.h
cpukit/libfs/src/jffs2/include/linux/timer.h
cpukit/libfs/src/jffs2/include/linux/types.h
cpukit/libfs/src/jffs2/include/linux/uio.h
cpukit/libfs/src/jffs2/include/linux/version.h
cpukit/libfs/src/jffs2/include/linux/vmalloc.h
cpukit/libfs/src/jffs2/include/linux/wait.h
cpukit/libfs/src/jffs2/include/linux/workqueue.h
cpukit/libfs/src/jffs2/include/linux/xattr.h
cpukit/libfs/src/jffs2/include/linux/zlib.h
cpukit/libfs/src/jffs2/include/linux/zutil.h
cpukit/libfs/src/jffs2/src/acl.h
cpukit/libfs/src/jffs2/src/build.c
cpukit/libfs/src/jffs2/src/compat-crc32.c
cpukit/libfs/src/jffs2/src/compr.h
cpukit/libfs/src/jffs2/src/compr_rtime.c
cpukit/libfs/src/jffs2/src/compr_rubin.c
cpukit/libfs/src/jffs2/src/compr_zlib.c
cpukit/libfs/src/jffs2/src/debug.c
cpukit/libfs/src/jffs2/src/debug.h
cpukit/libfs/src/jffs2/src/erase.c
cpukit/libfs/src/jffs2/src/flashio.c
cpukit/libfs/src/jffs2/src/gc.c
cpukit/libfs/src/jffs2/src/jffs2_fs_i.h
cpukit/libfs/src/jffs2/src/jffs2_fs_sb.h
cpukit/libfs/src/jffs2/src/malloc-rtems.c
cpukit/libfs/src/jffs2/src/nodelist.c
cpukit/libfs/src/jffs2/src/nodelist.h
cpukit/libfs/src/jffs2/src/nodemgmt.c
cpukit/libfs/src/jffs2/src/read.c
cpukit/libfs/src/jffs2/src/readinode.c
cpukit/libfs/src/jffs2/src/rtems-jffs2-config.h
cpukit/libfs/src/jffs2/src/scan.c
cpukit/libfs/src/jffs2/src/summary.h
cpukit/libfs/src/jffs2/src/write.c
cpukit/libfs/src/jffs2/src/xattr.h
Gred Haerr <greg at censoft.com>
cpukit/libmisc/mouse/mouse_parser.c
Michael Ringgaard
cpukit/libmisc/shell/main_edit.c
Unicode
cpukit/libmisc/utf8proc/utf8proc_data.c
Theodore Ts'o
cpukit/libmisc/uuid/clear.c
cpukit/libmisc/uuid/compare.c
cpukit/libmisc/uuid/copy.c
cpukit/libmisc/uuid/gen_uuid.c
cpukit/libmisc/uuid/isnull.c
cpukit/libmisc/uuid/pack.c
cpukit/libmisc/uuid/parse.c
cpukit/libmisc/uuid/unpack.c
cpukit/libmisc/uuid/unparse.c
cpukit/libmisc/uuid/uuidP.h
cpukit/libmisc/uuid/uuid_time.c
cpukit/libmisc/uuid/uuidd.h
cpukit/include/uuid/uuid.h
Lasse Collin <lasse.collin at tukaani.org>
cpukit/include/xz.h
cpukit/libmisc/xz/xz_config.h
cpukit/libmisc/xz/xz_crc32.c
cpukit/libmisc/xz/xz_crc64.c
cpukit/libmisc/xz/xz_dec_lzma2.c
cpukit/libmisc/xz/xz_dec_stream.c
cpukit/libmisc/xz/xz_lzma2.h
cpukit/libmisc/xz/xz_private.h
cpukit/libmisc/xz/xz_stream.h
Integrated Device Technology, Inc
cpukit/score/cpu/mips/include/rtems/mips/idtcpu.h
cpukit/score/cpu/mips/include/rtems/mips/iregdef.h
Los Alamos National Security, LLC
cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h
Mark Adler, Jean-loup Gailly
cpukit/zlib/adler32.c
cpukit/zlib/crc32.c
cpukit/zlib/gzclose.c
cpukit/zlib/gzguts.h
cpukit/zlib/gzlib.c
cpukit/zlib/gzread.c
cpukit/zlib/gzwrite.c
cpukit/zlib/infback.c
cpukit/zlib/inffast.c
cpukit/zlib/inffast.h
cpukit/zlib/inflate.c
cpukit/zlib/inflate.h
cpukit/zlib/inftrees.c
cpukit/zlib/inftrees.h
cpukit/zlib/compress.c
cpukit/zlib/deflate.c
cpukit/zlib/deflate.h
cpukit/zlib/trees.c
cpukit/zlib/uncompr.c
cpukit/zlib/zutil.c
cpukit/zlib/zutil.h
cpukit/include/zconf.h
cpukit/include/zlib.h
cpukit/zlib/crc32.h
cpukit/zlib/inffixed.h
cpukit/zlib/trees.h
Reinhold P. Weicker
testsuites/benchmarks/dhrystone/dhry.h
testsuites/benchmarks/dhrystone/dhry_1.c
testsuites/benchmarks/dhrystone/dhry_2.c
testsuites/benchmarks/linpack/linpack-pc.c
testsuites/benchmarks/whetstone/whetstone.c
