Tool Suite Build Failed - machine 'arm64-apple' not recognized
Jay Zhu
jinghui at usc.edu
Sun Apr 10 18:37:27 UTC 2022
Hi,
I am a student new to RTEMS and trying to get my first lines to run. When following the quick-start guide, I was stuck in Install Tool Suite procedure. Using this command:
../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
The output was:
error: building expat-2.1.0-arm64-apple-darwin21.4.0-1
Build FAILED
See error report: rsb-report-expat-2.1.0-arm64-apple-darwin21.4.0-1.txt
Then I lookup the log file, in which the errors are:
Invalid configuration `arm64-apple-darwin21.4.0': machine `arm64-apple' not recognized
configure: error: /bin/sh conftools/config.sub arm64-apple-darwin21.4.0 failed
checking build system type...
shell cmd failed: /bin/sh -ex /Users/Jay/quick-start/src/rsb/rtems/build/expat-2.1.0-arm64-apple-darwin21.4.0-1/do-build
Can you kindly tell me how can I fix this?
Sincere,
Jinghui
