List third party files in cpukit and testsuites
Joel Sherrill
joel at rtems.org
Mon Apr 11 14:57:21 UTC 2022
On Mon, Apr 11, 2022 at 9:46 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Apr 8, 2022 at 12:35 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> > This is the set of files in the source code that are all third party.
> > This means they should not be re-licensed or re-formatted.
> > If anything on this list is wrong, or if I missed some, please comment.
> > Thanks,
> > Ryan
> > David Gibson, IBM Corporation
> > cpukit/dtc/libfdt/fdt.c
> > cpukit/dtc/libfdt/fdt_empty_tree.c
> > cpukit/dtc/libfdt/fdt_ro.c
> > cpukit/dtc/libfdt/fdt_rw.c
> > cpukit/dtc/libfdt/fdt_strerror.c
> > cpukit/dtc/libfdt/fdt_sw.c
> > cpukit/dtc/libfdt/fdt_wip.c
> > cpukit/dtc/libfdt/libfdt_internal.h
> > cpukit/include/fdt.h
> > cpukit/include/libfdt.h
> > cpukit/include/libfdt_env.h
> ok, the dtc/libfdt is 3rd party. It should be specified as cpukit/dtc
> > The Regents of the University of California
> > cpukit/include/arpa/ftp.h
> > cpukit/include/machine/_kernel_in.h
> > cpukit/include/machine/_kernel_mman.h
> > .cpukit/libmisc/shell/dd-args.c
> > cpukit/libmisc/shell/dd-conv.c
> > cpukit/libmisc/shell/dd-conv_tab.c
> > cpukit/libmisc/shell/dd-misc.c
> > cpukit/libmisc/shell/dd-position.c
> > cpukit/libmisc/shell/dd.h
> > cpukit/libmisc/shell/err.c
> > cpukit/libmisc/shell/err.h
> > cpukit/libmisc/shell/errx.c
> > cpukit/libmisc/shell/extern-cp.h
> > cpukit/libmisc/shell/extern-dd.h
> > cpukit/libmisc/shell/extern-ls.h
> > cpukit/libmisc/shell/filemode.c
> > cpukit/libmisc/shell/fts.c
> > cpukit/libmisc/shell/fts.h
> > cpukit/libmisc/shell/hexdump-conv.c
> > cpukit/libmisc/shell/hexdump-display.c
> > cpukit/libmisc/shell/hexdump-odsyntax.c
> > cpukit/libmisc/shell/hexdump-parse.c
> > cpukit/libmisc/shell/hexdump.h
> > cpukit/libmisc/shell/hexsyntax.c
> > cpukit/libmisc/shell/main_cp.c
> > cpukit/libmisc/shell/main_dd.c
> > cpukit/libmisc/shell/main_echo.c
> > cpukit/libmisc/shell/main_hexdump.c
> > cpukit/libmisc/shell/main_mv.c
> > cpukit/libmisc/shell/main_ln.c
> > cpukit/libmisc/shell/main_ls.c
> > cpukit/libmisc/shell/main_rm.c
> > cpukit/libmisc/shell/pathnames-mv.h
> > cpukit/libmisc/shell/print-ls.c
> > cpukit/libmisc/shell/pwcache.c
> > cpukit/libmisc/shell/sysexits.h
> > cpukit/libmisc/shell/utils-cp.c
> > cpukit/libmisc/shell/utils-ls.c
> > cpukit/libmisc/shell/verr.c
> > cpukit/libmisc/shell/verrx.c
> > cpukit/libmisc/shell/vis.c
> > cpukit/libmisc/shell/vis.h
> > cpukit/libmisc/shell/vwarn.c
> > cpukit/libmisc/shell/vwarnx.c
> > cpukit/libmisc/shell/warn.c
> > cpukit/libmisc/shell/warnx.c
> > cpukit/score/src/iovprintf.c
> > cpukit/libcsupport/src/cfmakeraw.c
> > cpukit/libcsupport/src/cfmakesane.c
> > /include/machine/_kernel_uio.h
> I've had this question in the past about whether or not 'shell' is 3rd
> party. I never had a great answer. The question about not touching 3rd
> party sources is more about whether or not there is someone upstream
> that maintains them. If there's not any update path, then we
> effectively own the code now (clone and own).
A lot (68/104) files in shell have RTEMS GPL so most of the code is
really ours. There often is enough hacking to argue clone and own on
some but it is still possible to compare and update. I think Ryan did a
fair bit of this and reporting upstream when addressing Coverity issues.
> That said, everything that is copyrighted by The Regents of the
> University of California can be licensed to 3-BSD.
I politely ask you to make this change. You understand the why
and how.
> Meanwhile, this list has me thinking that you should also use grep
> "\$FreeBSD" to find source files imported from there. Ditto for
> NetBSD. I think it makes more sense to track 3rd party software based
> on where it comes from rather than based on the contributor/copyright
> holder.
That was a manual flag for third party but I don't think it ever got to
a grep.
> > Mark Murray
> > cpukit/include/crypt.h
> For example, this would be better identified as being part of the
> NetBSD libcrypt
Where it came from is just for discussion now. Ultimately we only
care that it is third party.
> > NetBSD
> > cpukit/include/dlfcn.h
> > cpukit/include/link.h
> > cpukit/include/link_elf.h
> > cpukit/libmisc/shell/cmp-ls.c
> > cpukit/libdl/rtl-mdreloc-arm.c
> > cpukit/libdl/rtl-mdreloc-i386.c
> > cpukit/libdl/rtl-mdreloc-m68k.c
> > cpukit/libdl/rtl-mdreloc-riscv.c
> > cpukit/libdl/rtl-mdreloc-sparc.c
> > cpukit/libmisc/shell/main_mknod.c
> > cpukit/libmisc/shell/mknod-pack_dev.c
> > cpukit/libmisc/shell/mknod-pack_dev.h
> > cpukit/score/cpu/i386/include/machine/elf_machdep.h
> > cpukit/score/cpu/m68k/include/machine/elf_machdep.h
> > cpukit/score/cpu/mips/include/machine/elf_machdep.h
> > cpukit/score/cpu/nios2/include/machine/elf_machdep.h
> > cpukit/score/cpu/sparc/include/machine/elf_machdep.h
> > cpukit/score/cpu/x86_64/include/machine/elf_machdep.h
> > cpukit/include/sys/cdefs_elf.h
> > cpukit/include/sys/exec_elf.h
> > cpukit/telnetd/des.c
> > WIDE Project
> > cpukit/include/machine/_kernel_in6.h
> > RSA Data Security, Inc.
> > cpukit/include/md4.h
> > cpukit/include/md5.h
> > Sergey Lyubka
> > cpukit/include/mghttpd/mongoose.h
> > cpukit/mghttpd/mongoose.c
> > FreeBSD
> > cpukit/include/pci/pcireg.h
> > cpukit/libstdthreads/call_once.c
> > cpukit/libstdthreads/thrd.c
> > cpukit/libstdthreads/tss.c
> > cpukit/include/sys/endian.h
> > cpukit/include/sys/event.h
> > cpukit/include/sys/poll.h
> > cpukit/include/sys/priority.h
> > cpukit/include/sys/timepps.h
> > cpukit/include/sys/timetc.h
> > cpukit/include/sys/timex.h
> > cpukit/libcrypt/crypt-sha256.c
> > cpukit/libcrypt/crypt-sha512.c
> > cpukit/score/src/kern_ntptime.c
> > cpukit/score/src/kern_tc.c
> > cpukit/include/sha256.h
> > cpukit/include/sha512.h
> > cpukit/include/sys/_ffcounter.h
> > cpukit/include/sys/timeffc.h
> > Public Software Group
> > cpukit/include/utf8proc/utf8proc.h
> > cpukit/libmisc/utf8proc/utf8proc.c
> > Poul-Henning Kamp
> > cpukit/libcrypt/crypt-md5.c
> ditto.
> > cpukit/libcrypt/misc.c
> > testsuites/samples/paranoia/paranoia.c
> I'm guessing this was supposed to be the Regents of ... (I don't think
> there is such a thing as "University of California" as an entity)
> > Ariya Hidayat <ariya at kde.org>
> > cpukit/libdl/fastlz.c
> > cpukit/libdl/fastlz.h
> > Kevin Kirspel <kirspkt at gmail.com>
> > cpukit/libfs/src/defaults/default_mmap.c
> Kevin lurks around here. That said, this file is probably not even
> copyrightable software. That's a separate point altogether though.
This is RTEMS code. I mentioned that in the review.
Ryan .. make sure Kevin is on the track down for permission list.
> > Red Hat
> > cpukit/libfs/src/jffs2/include/asm/atomic.h
> > cpukit/libfs/src/jffs2/include/asm/bug.h
> > cpukit/libfs/src/jffs2/include/asm/page.h
> > cpukit/libfs/src/jffs2/include/cyg/crc/crc.h
> > cpukit/libfs/src/jffs2/include/cyg/infra/cyg_type.h
> > cpukit/libfs/src/jffs2/include/linux/compiler.h
> > cpukit/libfs/src/jffs2/include/linux/completion.h
> > cpukit/libfs/src/jffs2/include/linux/config.h
> > cpukit/libfs/src/jffs2/include/linux/crc32.h
> > cpukit/libfs/src/jffs2/include/linux/errno.h
> > cpukit/libfs/src/jffs2/include/linux/fs.h
> > cpukit/libfs/src/jffs2/include/linux/jffs2.h
> > cpukit/libfs/src/jffs2/include/linux/kernel.h
> > cpukit/libfs/src/jffs2/include/linux/list.h
> > cpukit/libfs/src/jffs2/include/linux/magic.h
> > cpukit/libfs/src/jffs2/include/linux/mm.h
> > cpukit/libfs/src/jffs2/include/linux/mtd/compatmac.h
> > cpukit/libfs/src/jffs2/include/linux/mtd/mtd.h
> > cpukit/libfs/src/jffs2/include/linux/mutex.h
> > cpukit/libfs/src/jffs2/include/linux/pagemap.h
> > cpukit/libfs/src/jffs2/include/linux/posix_acl.h
> > cpukit/libfs/src/jffs2/include/linux/rwsem.h
> > cpukit/libfs/src/jffs2/include/linux/sched.h
> > cpukit/libfs/src/jffs2/include/linux/sched/signal.h
> > cpukit/libfs/src/jffs2/include/linux/slab.h
> > cpukit/libfs/src/jffs2/include/linux/spinlock.h
> > cpukit/libfs/src/jffs2/include/linux/stat.h
> > cpukit/libfs/src/jffs2/include/linux/string.h
> > cpukit/libfs/src/jffs2/include/linux/timer.h
> > cpukit/libfs/src/jffs2/include/linux/types.h
> > cpukit/libfs/src/jffs2/include/linux/uio.h
> > cpukit/libfs/src/jffs2/include/linux/version.h
> > cpukit/libfs/src/jffs2/include/linux/vmalloc.h
> > cpukit/libfs/src/jffs2/include/linux/wait.h
> > cpukit/libfs/src/jffs2/include/linux/workqueue.h
> > cpukit/libfs/src/jffs2/include/linux/xattr.h
> > cpukit/libfs/src/jffs2/include/linux/zlib.h
> > cpukit/libfs/src/jffs2/include/linux/zutil.h
> > cpukit/libfs/src/jffs2/src/acl.h
> > cpukit/libfs/src/jffs2/src/build.c
> > cpukit/libfs/src/jffs2/src/compat-crc32.c
> > cpukit/libfs/src/jffs2/src/compr.h
> > cpukit/libfs/src/jffs2/src/compr_rtime.c
> > cpukit/libfs/src/jffs2/src/compr_rubin.c
> > cpukit/libfs/src/jffs2/src/compr_zlib.c
> > cpukit/libfs/src/jffs2/src/debug.c
> > cpukit/libfs/src/jffs2/src/debug.h
> > cpukit/libfs/src/jffs2/src/erase.c
> > cpukit/libfs/src/jffs2/src/flashio.c
> > cpukit/libfs/src/jffs2/src/gc.c
> > cpukit/libfs/src/jffs2/src/jffs2_fs_i.h
> > cpukit/libfs/src/jffs2/src/jffs2_fs_sb.h
> > cpukit/libfs/src/jffs2/src/malloc-rtems.c
> > cpukit/libfs/src/jffs2/src/nodelist.c
> > cpukit/libfs/src/jffs2/src/nodelist.h
> > cpukit/libfs/src/jffs2/src/nodemgmt.c
> > cpukit/libfs/src/jffs2/src/read.c
> > cpukit/libfs/src/jffs2/src/readinode.c
> > cpukit/libfs/src/jffs2/src/rtems-jffs2-config.h
> > cpukit/libfs/src/jffs2/src/scan.c
> > cpukit/libfs/src/jffs2/src/summary.h
> > cpukit/libfs/src/jffs2/src/write.c
> > cpukit/libfs/src/jffs2/src/xattr.h
> yeah JFFS2 as a directory is exempt
Except for at least one file with RTEMS in the name.
> > Gred Haerr <greg at censoft.com>
> > cpukit/libmisc/mouse/mouse_parser.c
> I'm pretty sure we own this now. Also, I think it can be
> re/dual-licensed, but that's a separate point to discuss as well.
> > Michael Ringgaard
> > cpukit/libmisc/shell/main_edit.c
> > Unicode
> > cpukit/libmisc/utf8proc/utf8proc_data.c
> > Theodore Ts'o
> > cpukit/libmisc/uuid/clear.c
> > cpukit/libmisc/uuid/compare.c
> > cpukit/libmisc/uuid/copy.c
> > cpukit/libmisc/uuid/gen_uuid.c
> > cpukit/libmisc/uuid/isnull.c
> > cpukit/libmisc/uuid/pack.c
> > cpukit/libmisc/uuid/parse.c
> > cpukit/libmisc/uuid/unpack.c
> > cpukit/libmisc/uuid/unparse.c
> > cpukit/libmisc/uuid/uuidP.h
> > cpukit/libmisc/uuid/uuid_time.c
> > cpukit/libmisc/uuid/uuidd.h
> > cpukit/include/uuid/uuid.h
> ok to UUID
> > Lasse Collin <lasse.collin at tukaani.org>
> > cpukit/include/xz.h
> > cpukit/libmisc/xz/xz_config.h
> > cpukit/libmisc/xz/xz_crc32.c
> > cpukit/libmisc/xz/xz_crc64.c
> > cpukit/libmisc/xz/xz_dec_lzma2.c
> > cpukit/libmisc/xz/xz_dec_stream.c
> > cpukit/libmisc/xz/xz_lzma2.h
> > cpukit/libmisc/xz/xz_private.h
> > cpukit/libmisc/xz/xz_stream.h
> ok to XZ
> > Integrated Device Technology, Inc
> > cpukit/score/cpu/mips/include/rtems/mips/idtcpu.h
> > cpukit/score/cpu/mips/include/rtems/mips/iregdef.h
> > Los Alamos National Security, LLC
> > cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h
> This is from Jeff Hill. We should see if he is allowed to get
> relicensing permission.
OK. So not third party and Ryan can add it to the "to track down" list.
> > Mark Adler, Jean-loup Gailly
> > cpukit/zlib/adler32.c
> > cpukit/zlib/crc32.c
> > cpukit/zlib/gzclose.c
> > cpukit/zlib/gzguts.h
> > cpukit/zlib/gzlib.c
> > cpukit/zlib/gzread.c
> > cpukit/zlib/gzwrite.c
> > cpukit/zlib/infback.c
> > cpukit/zlib/inffast.c
> > cpukit/zlib/inffast.h
> > cpukit/zlib/inflate.c
> > cpukit/zlib/inflate.h
> > cpukit/zlib/inftrees.c
> > cpukit/zlib/inftrees.h
> > cpukit/zlib/compress.c
> > cpukit/zlib/deflate.c
> > cpukit/zlib/deflate.h
> > cpukit/zlib/trees.c
> > cpukit/zlib/uncompr.c
> > cpukit/zlib/zutil.c
> > cpukit/zlib/zutil.h
> > cpukit/include/zconf.h
> > cpukit/include/zlib.h
> > cpukit/zlib/crc32.h
> > cpukit/zlib/inffixed.h
> > cpukit/zlib/trees.h
> ok to zlib
> > Reinhold P. Weicker
> > testsuites/benchmarks/dhrystone/dhry.h
> > testsuites/benchmarks/dhrystone/dhry_1.c
> > testsuites/benchmarks/dhrystone/dhry_2.c
> > testsuites/benchmarks/linpack/linpack-pc.c
> > testsuites/benchmarks/whetstone/whetstone.c
> ok to select benchmarks.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
