AW: AW: [PATCH 12/12] spec/build/cpukit: Add option for enabling PPS synchronization
Gabriel.Moyano at dlr.de Gabriel.Moyano at dlr.de
Tue Apr 12 08:22:57 UTC 2022
> >> In general, the patch set lacks test cases.
> > I was thinking that the next step could be to add a generic device which is required to use the API (a file descriptor is needed). This is
> something that wanted to ask in the mailing list first. When this device is added, also the test cases can be. Furthermore I wanted to
> split the submitted changes in order to make a review easier.
> A file descriptor should be optional. It should be possible to add a PPS driver just using struct pps_state.
What do you mean with optional?
The RFC 2783 defines only a user API. For example for config the function time_pps_setparams() is needed. If we don't follow the RFC 2783, we will need to create an RTEMS API. Is that what you mean?
