AW: AW: [PATCH 12/12] spec/build/cpukit: Add option for enabling PPS synchronization
Sebastian Huber
Tue Apr 12 08:27:01 UTC 2022
On 12/04/2022 10:22, Gabriel.Moyano at dlr.de wrote:
>>>> In general, the patch set lacks test cases.
>>> I was thinking that the next step could be to add a generic device which is required to use the API (a file descriptor is needed). This is
>> something that wanted to ask in the mailing list first. When this device is added, also the test cases can be. Furthermore I wanted to
>> split the submitted changes in order to make a review easier.
>> A file descriptor should be optional. It should be possible to add a PPS driver just using struct pps_state.
> What do you mean with optional?
> The RFC 2783 defines only a user API. For example for config the function time_pps_setparams() is needed. If we don't follow the RFC 2783, we will need to create an RTEMS API. Is that what you mean?
For the user API, using a file descriptor is fine.
I am referring to the PPS driver itself. It should just use struct
pps_state. A PPS driver may register a device file which can be accessed
by the user API. Providing a device file should be optional to be able
to use PPS in applications which do not use a filesystem at all.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
