CAN Options and Licensing, Testing, etc
Prashanth S
fishesprashanth at gmail.com
Tue Apr 12 17:13:11 UTC 2022
Hi All,
This is to ask for suggestions on implementing the CAN driver for BBB.
Can I proceed with defining driver specific structures for the CAN driver
or go with adding a generic API layer for ADC and GPIO.
Regards
Prashanth S
On Tue, 12 Apr 2022 at 19:14, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I didn't want to post this in the other thread and turn it from a
> technical into licensing discussion but that must be the first filter for a
> CAN solution for RTEMS if it uses third-party code. If I have extracted the
> options correctly, we have:
> + LinCAN - GPL
> + SocketCAN - GPL
> + NuttX CAN - Apache
> + CANOpen - Apache
> The licensing alone eliminates two of the solutions.
> My other concern was how you were going to test the drivers you wrote.
> Pavel mentions CAN in qemu. Perhaps the project should drop the ADC and
> focus on a CAN solution using the BSP supported by Qemu along with whatever
> analysis tools Pavel recommends. I am sure Pavel has some driver code for
> the Qemu path (not sure if it is in RTEMS or not) This would move the
> project from a single driver to trying to provide a CAN solution. This is
> much more valuable to the project long term.
> And since CANOpen is an independent and long running project, I'd lean to
> it as the selection.
> Just my thoughts
> --joel
