[PATCH rtems-lwip] lwip: Split sources into origin directories
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Apr 14 17:32:14 UTC 2022
Moving forward, each origin directory should have its own top-level
COPYING.origin file to describe its license as well as a ORIGIN.origin
file to describe where the code is sourced from.
COPYING.lwip | 25 ++++++++++++++
COPYING.uLan | 33 +++++++++++++++++++
ORIGIN.lwip | 2 ++
ORIGIN.uLan | 2 ++
README | 14 ++++++++
lwip.py | 10 +++---
.../ports/driver/tms570_emac}/eth_lwip.c | 0
.../ports/driver/tms570_emac}/eth_lwip.h | 0
.../driver/tms570_emac}/eth_lwip_default.h | 0
.../ports/driver/tms570_emac}/phy_dp83848h.c | 0
.../ports/driver/tms570_emac}/phy_dp83848h.h | 0
.../ports/driver/tms570_emac}/ti_drv_emac.h | 0
.../ports/driver/tms570_emac}/ti_drv_mdio.h | 0
.../ports/driver/tms570_emac}/tms570_emac.h | 0
.../ports/driver/tms570_emac}/tms570_netif.c | 0
.../ports/driver/tms570_emac}/tms570_netif.h | 0
{lwip => uLan}/ports/os/lwipopts.h | 0
{lwip => uLan}/ports/os/rtems/arch/cc.h | 0
{lwip => uLan}/ports/os/rtems/arch/perf.h | 0
{lwip => uLan}/ports/os/rtems/arch/sys_arch.c | 0
{lwip => uLan}/ports/os/rtems/arch/sys_arch.h | 0
21 files changed, 81 insertions(+), 5 deletions(-)
create mode 100644 COPYING.lwip
create mode 100644 COPYING.uLan
create mode 100644 ORIGIN.lwip
create mode 100644 ORIGIN.uLan
create mode 100644 README
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip.c (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip.h (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip_default.h (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/phy_dp83848h.c (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/phy_dp83848h.h (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/ti_drv_emac.h (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/ti_drv_mdio.h (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/tms570_emac.h (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/tms570_netif.c (100%)
rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/tms570_netif.h (100%)
rename {lwip => uLan}/ports/os/lwipopts.h (100%)
rename {lwip => uLan}/ports/os/rtems/arch/cc.h (100%)
rename {lwip => uLan}/ports/os/rtems/arch/perf.h (100%)
rename {lwip => uLan}/ports/os/rtems/arch/sys_arch.c (100%)
rename {lwip => uLan}/ports/os/rtems/arch/sys_arch.h (100%)
diff --git a/COPYING.lwip b/COPYING.lwip
new file mode 100644
index 0000000..90465f5
--- /dev/null
+++ b/COPYING.lwip
@@ -0,0 +1,25 @@
+Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
+All rights reserved.
+Redistribution and use in source and binary forms, with or without modification,
+are permitted provided that the following conditions are met:
+1. Redistributions of source code must retain the above copyright notice,
+ this list of conditions and the following disclaimer.
+2. Redistributions in binary form must reproduce the above copyright notice,
+ this list of conditions and the following disclaimer in the documentation
+ and/or other materials provided with the distribution.
+3. The name of the author may not be used to endorse or promote products
+ derived from this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+OF SUCH DAMAGE.
diff --git a/COPYING.uLan b/COPYING.uLan
index 0000000..e23898b
--- /dev/null
+++ b/COPYING.uLan
@@ -0,0 +1,33 @@
+ * Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+ * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+ * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+ * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+ * This file is part of the lwIP TCP/IP stack.
+ * Author: Adam Dunkels <adam at sics.se>
diff --git a/ORIGIN.lwip b/ORIGIN.lwip
index 0000000..c77755e
--- /dev/null
+++ b/ORIGIN.lwip
@@ -0,0 +1,2 @@
+The files under the lwip/ directory are sourced from:
+git://git.savannah.gnu.org/lwip.git
diff --git a/ORIGIN.uLan b/ORIGIN.uLan
index 0000000..8111d3d
--- /dev/null
+++ b/ORIGIN.uLan
@@ -0,0 +1,2 @@
+The files under the uLan/ directory are sourced from:
+git://git.code.sf.net/p/ulan/lwip-omk ulan-lwip-omk
diff --git a/README b/README
index 0000000..91e42ae
--- /dev/null
+++ b/README
@@ -0,0 +1,14 @@
+Overview
+The rtems-lwip repository serves as a central location to manage integration of
+lwIP with RTEMS in a more user-accessible manner and to provide a repository of
+network drivers for RTEMS BSPs.
+File Origins
+The sources presented here originate in one of several locations described by
+the ORIGIN.* files and whose license is described by the COPYING.* files.
+Commits adding such files should include the hash of the target repository if
+applicable.
diff --git a/lwip.py b/lwip.py
index a3eb7cb..848ff16 100644
--- a/lwip.py
+++ b/lwip.py
@@ -42,10 +42,10 @@ def build(bld):
if f[-2:] == '.c':
source_files.append(os.path.join('./lwip', f))
- for f in os.listdir('./lwip/ports/drivers'):
+ for f in os.listdir('./uLan/ports/driver/tms570_emac'):
if f[-2:] == '.c':
- driver_source.append(os.path.join('./lwip/ports/drivers', f))
- source_files.append('./lwip/ports/os/rtems/arch/sys_arch.c')
+ driver_source.append(os.path.join('./uLan/ports/driver/tms570_emac', f))
+ source_files.append('./uLan/ports/os/rtems/arch/sys_arch.c')
#source_files.append('./lwip/ports/port/sys_arch.c')
#source_files.append('./lwip/ports/port/perf.c')
@@ -57,7 +57,7 @@ def build(bld):
bld(features ='c',
target='lwip_obj',
- includes='./include ./lwip/src/include lwip/ports/port/include ./lwip/ports/os ./lwip/ports/drivers ./lwip/ports/os/rtems',
+ includes='./include ./lwip/src/include ./uLan/ports/os ./uLan/ports/driver/tms570_emac ./uLan/ports/os/rtems',
source=source_files,
# bld(features ='c',
@@ -74,4 +74,4 @@ def build(bld):
source='./lwip/test/sample_app.c',
use='lwip',
lib=['rtemscpu', 'rtemsbsp', 'rtemstest', 'lwip'],
- includes='./include ./lwip/ports/os/rtems ./lwip/ports/os ./lwip/src/include ./lwip/ports/os/rtems ./lwip/test/' + os.path.relpath(os.path.join(arch_lib_path,'include')))
+ includes='./include ./uLan/ports/os/rtems ./uLan/ports/os ./lwip/src/include ./uLan/ports/os/rtems ./lwip/test/' + os.path.relpath(os.path.join(arch_lib_path,'include')))
diff --git a/lwip/ports/drivers/eth_lwip.c b/uLan/ports/driver/tms570_emac/eth_lwip.c
similarity index 100%
rename from lwip/ports/drivers/eth_lwip.c
rename to uLan/ports/driver/tms570_emac/eth_lwip.c
diff --git a/lwip/ports/drivers/eth_lwip.h b/uLan/ports/driver/tms570_emac/eth_lwip.h
rename from lwip/ports/drivers/eth_lwip.h
rename to uLan/ports/driver/tms570_emac/eth_lwip.h
diff --git a/lwip/ports/drivers/eth_lwip_default.h b/uLan/ports/driver/tms570_emac/eth_lwip_default.h
rename from lwip/ports/drivers/eth_lwip_default.h
rename to uLan/ports/driver/tms570_emac/eth_lwip_default.h
diff --git a/lwip/ports/drivers/phy_dp83848h.c b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
rename from lwip/ports/drivers/phy_dp83848h.c
rename to uLan/ports/driver/tms570_emac/phy_dp83848h.c
diff --git a/lwip/ports/drivers/phy_dp83848h.h b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
rename from lwip/ports/drivers/phy_dp83848h.h
rename to uLan/ports/driver/tms570_emac/phy_dp83848h.h
diff --git a/lwip/ports/drivers/ti_drv_emac.h b/uLan/ports/driver/tms570_emac/ti_drv_emac.h
rename from lwip/ports/drivers/ti_drv_emac.h
rename to uLan/ports/driver/tms570_emac/ti_drv_emac.h
diff --git a/lwip/ports/drivers/ti_drv_mdio.h b/uLan/ports/driver/tms570_emac/ti_drv_mdio.h
rename from lwip/ports/drivers/ti_drv_mdio.h
rename to uLan/ports/driver/tms570_emac/ti_drv_mdio.h
diff --git a/lwip/ports/drivers/tms570_emac.h b/uLan/ports/driver/tms570_emac/tms570_emac.h
rename from lwip/ports/drivers/tms570_emac.h
rename to uLan/ports/driver/tms570_emac/tms570_emac.h
diff --git a/lwip/ports/drivers/tms570_netif.c b/uLan/ports/driver/tms570_emac/tms570_netif.c
rename from lwip/ports/drivers/tms570_netif.c
rename to uLan/ports/driver/tms570_emac/tms570_netif.c
diff --git a/lwip/ports/drivers/tms570_netif.h b/uLan/ports/driver/tms570_emac/tms570_netif.h
rename from lwip/ports/drivers/tms570_netif.h
rename to uLan/ports/driver/tms570_emac/tms570_netif.h
diff --git a/lwip/ports/os/lwipopts.h b/uLan/ports/os/lwipopts.h
rename from lwip/ports/os/lwipopts.h
rename to uLan/ports/os/lwipopts.h
diff --git a/lwip/ports/os/rtems/arch/cc.h b/uLan/ports/os/rtems/arch/cc.h
rename from lwip/ports/os/rtems/arch/cc.h
rename to uLan/ports/os/rtems/arch/cc.h
diff --git a/lwip/ports/os/rtems/arch/perf.h b/uLan/ports/os/rtems/arch/perf.h
rename from lwip/ports/os/rtems/arch/perf.h
rename to uLan/ports/os/rtems/arch/perf.h
diff --git a/lwip/ports/os/rtems/arch/sys_arch.c b/uLan/ports/os/rtems/arch/sys_arch.c
rename from lwip/ports/os/rtems/arch/sys_arch.c
rename to uLan/ports/os/rtems/arch/sys_arch.c
diff --git a/lwip/ports/os/rtems/arch/sys_arch.h b/uLan/ports/os/rtems/arch/sys_arch.h
rename from lwip/ports/os/rtems/arch/sys_arch.h
rename to uLan/ports/os/rtems/arch/sys_arch.h
2.30.2
