[PATCH rtems-lwip] lwip: Split sources into origin directories
Vijay Kumar Banerjee vijay at rtems.org
Thu Apr 14 20:08:00 UTC 2022
Hi Kinsey,
Thank you for sorting this out. I will merge it on Monday if no one objects.
Best regards,
Vijay
On Thu, Apr 14, 2022 at 11:33 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Moving forward, each origin directory should have its own top-level
> COPYING.origin file to describe its license as well as a ORIGIN.origin
> file to describe where the code is sourced from.
>  COPYING.lwip                                  | 25 ++++++++++++++
>  COPYING.uLan                                  | 33 +++++++++++++++++++
>  ORIGIN.lwip                                   |  2 ++
>  ORIGIN.uLan                                   |  2 ++
>  README                                        | 14 ++++++++
>  lwip.py                                       | 10 +++---
>  .../ports/driver/tms570_emac}/eth_lwip.c      |  0
>  .../ports/driver/tms570_emac}/eth_lwip.h      |  0
>  .../driver/tms570_emac}/eth_lwip_default.h    |  0
>  .../ports/driver/tms570_emac}/phy_dp83848h.c  |  0
>  .../ports/driver/tms570_emac}/phy_dp83848h.h  |  0
>  .../ports/driver/tms570_emac}/ti_drv_emac.h   |  0
>  .../ports/driver/tms570_emac}/ti_drv_mdio.h   |  0
>  .../ports/driver/tms570_emac}/tms570_emac.h   |  0
>  .../ports/driver/tms570_emac}/tms570_netif.c  |  0
>  .../ports/driver/tms570_emac}/tms570_netif.h  |  0
>  {lwip => uLan}/ports/os/lwipopts.h            |  0
>  {lwip => uLan}/ports/os/rtems/arch/cc.h       |  0
>  {lwip => uLan}/ports/os/rtems/arch/perf.h     |  0
>  {lwip => uLan}/ports/os/rtems/arch/sys_arch.c |  0
>  {lwip => uLan}/ports/os/rtems/arch/sys_arch.h |  0
>  21 files changed, 81 insertions(+), 5 deletions(-)
>  create mode 100644 COPYING.lwip
>  create mode 100644 COPYING.uLan
>  create mode 100644 ORIGIN.lwip
>  create mode 100644 ORIGIN.uLan
>  create mode 100644 README
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip.c (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip.h (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/eth_lwip_default.h (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/phy_dp83848h.c (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/phy_dp83848h.h (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/ti_drv_emac.h (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/ti_drv_mdio.h (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/tms570_emac.h (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/tms570_netif.c (100%)
>  rename {lwip/ports/drivers => uLan/ports/driver/tms570_emac}/tms570_netif.h (100%)
>  rename {lwip => uLan}/ports/os/lwipopts.h (100%)
>  rename {lwip => uLan}/ports/os/rtems/arch/cc.h (100%)
>  rename {lwip => uLan}/ports/os/rtems/arch/perf.h (100%)
>  rename {lwip => uLan}/ports/os/rtems/arch/sys_arch.c (100%)
>  rename {lwip => uLan}/ports/os/rtems/arch/sys_arch.h (100%)
> diff --git a/COPYING.lwip b/COPYING.lwip
> new file mode 100644
> index 0000000..90465f5
> --- /dev/null
> +++ b/COPYING.lwip
> @@ -0,0 +1,25 @@
> +Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
> +All rights reserved.
> +Redistribution and use in source and binary forms, with or without modification,
> +are permitted provided that the following conditions are met:
> +1. Redistributions of source code must retain the above copyright notice,
> +   this list of conditions and the following disclaimer.
> +2. Redistributions in binary form must reproduce the above copyright notice,
> +   this list of conditions and the following disclaimer in the documentation
> +   and/or other materials provided with the distribution.
> +3. The name of the author may not be used to endorse or promote products
> +   derived from this software without specific prior written permission.
> +THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
> +WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> +MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
> +SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> +EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> +OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> +IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> +OF SUCH DAMAGE.
> diff --git a/COPYING.uLan b/COPYING.uLan
> index 0000000..e23898b
> --- /dev/null
> +++ b/COPYING.uLan
> @@ -0,0 +1,33 @@
> + * Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without modification,
> + * are permitted provided that the following conditions are met:
> + * 1. Redistributions of source code must retain the above copyright notice,
> + *    this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright notice,
> + *    this list of conditions and the following disclaimer in the documentation
> + *    and/or other materials provided with the distribution.
> + * 3. The name of the author may not be used to endorse or promote products
> + *    derived from this software without specific prior written permission.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
> + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
> + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> + * OF SUCH DAMAGE.
> + * This file is part of the lwIP TCP/IP stack.
> + * Author: Adam Dunkels <adam at sics.se>
> diff --git a/ORIGIN.lwip b/ORIGIN.lwip
> index 0000000..c77755e
> --- /dev/null
> +++ b/ORIGIN.lwip
> @@ -0,0 +1,2 @@
> +The files under the lwip/ directory are sourced from:
> +git://git.savannah.gnu.org/lwip.git
> diff --git a/ORIGIN.uLan b/ORIGIN.uLan
> index 0000000..8111d3d
> --- /dev/null
> +++ b/ORIGIN.uLan
> @@ -0,0 +1,2 @@
> +The files under the uLan/ directory are sourced from:
> +git://git.code.sf.net/p/ulan/lwip-omk ulan-lwip-omk
> diff --git a/README b/README
> index 0000000..91e42ae
> --- /dev/null
> +++ b/README
> @@ -0,0 +1,14 @@
> +Overview
> +The rtems-lwip repository serves as a central location to manage integration of
> +lwIP with RTEMS in a more user-accessible manner and to provide a repository of
> +network drivers for RTEMS BSPs.
> +File Origins
> +The sources presented here originate in one of several locations described by
> +the ORIGIN.* files and whose license is described by the COPYING.* files.
> +Commits adding such files should include the hash of the target repository if
> +applicable.
> diff --git a/lwip.py b/lwip.py
> index a3eb7cb..848ff16 100644
> --- a/lwip.py
> +++ b/lwip.py
> @@ -42,10 +42,10 @@ def build(bld):
>              if f[-2:] == '.c':
>                  source_files.append(os.path.join('./lwip', f))
> -        for f in os.listdir('./lwip/ports/drivers'):
> +        for f in os.listdir('./uLan/ports/driver/tms570_emac'):
>              if f[-2:] == '.c':
> -                driver_source.append(os.path.join('./lwip/ports/drivers', f))
> -    source_files.append('./lwip/ports/os/rtems/arch/sys_arch.c')
> +                driver_source.append(os.path.join('./uLan/ports/driver/tms570_emac', f))
> +    source_files.append('./uLan/ports/os/rtems/arch/sys_arch.c')
>      #source_files.append('./lwip/ports/port/sys_arch.c')
>      #source_files.append('./lwip/ports/port/perf.c')
> @@ -57,7 +57,7 @@ def build(bld):
>      bld(features ='c',
>          target='lwip_obj',
> -        includes='./include ./lwip/src/include lwip/ports/port/include ./lwip/ports/os ./lwip/ports/drivers ./lwip/ports/os/rtems',
> +        includes='./include ./lwip/src/include ./uLan/ports/os ./uLan/ports/driver/tms570_emac ./uLan/ports/os/rtems',
>          source=source_files,
>  #    bld(features ='c',
> @@ -74,4 +74,4 @@ def build(bld):
>                  source='./lwip/test/sample_app.c',
>                  use='lwip',
>                  lib=['rtemscpu', 'rtemsbsp', 'rtemstest', 'lwip'],
> -                includes='./include ./lwip/ports/os/rtems ./lwip/ports/os ./lwip/src/include ./lwip/ports/os/rtems ./lwip/test/' + os.path.relpath(os.path.join(arch_lib_path,'include')))
> +                includes='./include ./uLan/ports/os/rtems ./uLan/ports/os ./lwip/src/include ./uLan/ports/os/rtems ./lwip/test/' + os.path.relpath(os.path.join(arch_lib_path,'include')))
> diff --git a/lwip/ports/drivers/eth_lwip.c b/uLan/ports/driver/tms570_emac/eth_lwip.c
> similarity index 100%
> rename from lwip/ports/drivers/eth_lwip.c
> rename to uLan/ports/driver/tms570_emac/eth_lwip.c
> diff --git a/lwip/ports/drivers/eth_lwip.h b/uLan/ports/driver/tms570_emac/eth_lwip.h
> rename from lwip/ports/drivers/eth_lwip.h
> rename to uLan/ports/driver/tms570_emac/eth_lwip.h
> diff --git a/lwip/ports/drivers/eth_lwip_default.h b/uLan/ports/driver/tms570_emac/eth_lwip_default.h
> rename from lwip/ports/drivers/eth_lwip_default.h
> rename to uLan/ports/driver/tms570_emac/eth_lwip_default.h
> diff --git a/lwip/ports/drivers/phy_dp83848h.c b/uLan/ports/driver/tms570_emac/phy_dp83848h.c
> rename from lwip/ports/drivers/phy_dp83848h.c
> rename to uLan/ports/driver/tms570_emac/phy_dp83848h.c
> diff --git a/lwip/ports/drivers/phy_dp83848h.h b/uLan/ports/driver/tms570_emac/phy_dp83848h.h
> rename from lwip/ports/drivers/phy_dp83848h.h
> rename to uLan/ports/driver/tms570_emac/phy_dp83848h.h
> diff --git a/lwip/ports/drivers/ti_drv_emac.h b/uLan/ports/driver/tms570_emac/ti_drv_emac.h
> rename from lwip/ports/drivers/ti_drv_emac.h
> rename to uLan/ports/driver/tms570_emac/ti_drv_emac.h
> diff --git a/lwip/ports/drivers/ti_drv_mdio.h b/uLan/ports/driver/tms570_emac/ti_drv_mdio.h
> rename from lwip/ports/drivers/ti_drv_mdio.h
> rename to uLan/ports/driver/tms570_emac/ti_drv_mdio.h
> diff --git a/lwip/ports/drivers/tms570_emac.h b/uLan/ports/driver/tms570_emac/tms570_emac.h
> rename from lwip/ports/drivers/tms570_emac.h
> rename to uLan/ports/driver/tms570_emac/tms570_emac.h
> diff --git a/lwip/ports/drivers/tms570_netif.c b/uLan/ports/driver/tms570_emac/tms570_netif.c
> rename from lwip/ports/drivers/tms570_netif.c
> rename to uLan/ports/driver/tms570_emac/tms570_netif.c
> diff --git a/lwip/ports/drivers/tms570_netif.h b/uLan/ports/driver/tms570_emac/tms570_netif.h
> rename from lwip/ports/drivers/tms570_netif.h
> rename to uLan/ports/driver/tms570_emac/tms570_netif.h
> diff --git a/lwip/ports/os/lwipopts.h b/uLan/ports/os/lwipopts.h
> rename from lwip/ports/os/lwipopts.h
> rename to uLan/ports/os/lwipopts.h
> diff --git a/lwip/ports/os/rtems/arch/cc.h b/uLan/ports/os/rtems/arch/cc.h
> rename from lwip/ports/os/rtems/arch/cc.h
> rename to uLan/ports/os/rtems/arch/cc.h
> diff --git a/lwip/ports/os/rtems/arch/perf.h b/uLan/ports/os/rtems/arch/perf.h
> rename from lwip/ports/os/rtems/arch/perf.h
> rename to uLan/ports/os/rtems/arch/perf.h
> diff --git a/lwip/ports/os/rtems/arch/sys_arch.c b/uLan/ports/os/rtems/arch/sys_arch.c
> rename from lwip/ports/os/rtems/arch/sys_arch.c
> rename to uLan/ports/os/rtems/arch/sys_arch.c
> diff --git a/lwip/ports/os/rtems/arch/sys_arch.h b/uLan/ports/os/rtems/arch/sys_arch.h
> rename from lwip/ports/os/rtems/arch/sys_arch.h
> rename to uLan/ports/os/rtems/arch/sys_arch.h
> 2.30.2
> devel mailing list
> devel at rtems.org
