Tool Suite Build Failed - machine 'arm64-apple' not recognized
Karel Gardas karel at functional.vision
Tue Apr 19 22:11:56 UTC 2022
On 4/19/22 19:13, Cedric Berger wrote:
> Yeah, you're right: I patched GMP because I first tried to build the
> toolchain on aarch64-mac. Both patches were definitely needed for that.
Just verified what's needed on x64 catalina 10.15.7/darwin 19.6.0 and
indeed, *only* expat patch is needed for x64 platform which means gmp
6.1.0 probably suffers from the same issue like expat not recognizing
aarch64-darwin properly and as you confirm 6.2.1 should fix this...
Karel
> Cedric
> On 19.04.22 17:50, Alan Cudmore wrote:
>> Karel Gardas just submitted patches this morning to upgrade expat to
>> work on 64 bit Arm.
>> A couple of months ago, I was able to build an RTEMS toolchain on
>> aarch64 Linux with just an expat upgrade. I was not aware that GMP was
>> needed as well.
>> Alan
>> *From: *Cedric Berger <mailto:cedric at precidata.com>
>> *Sent: *Tuesday, April 19, 2022 11:23 AM
>> *To: *Jay Zhu <mailto:jinghui at usc.edu>; devel at rtems.org
>> *Subject: *Re: Tool Suite Build Failed - machine 'arm64-apple' not
>> recognized
>> Hello,
>> On 10.04.22 20:37, Jay Zhu wrote:
>> > Hi,
>> > I am a student new to RTEMS and trying to get my first lines to run.
>> When following the quick-start guide, I was stuck in Install Tool
>> Suite procedure. Using this command:
>> > ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6
>> 6/rtems-sparc
>> > The output was:
>> > error: building expat-2.1.0-arm64-apple-darwin21.4.0-1
>> > Build FAILED
>> >    See error report:
>> rsb-report-expat-2.1.0-arm64-apple-darwin21.4.0-1.txt
>> > Then I lookup the log file, in which the errors are:
>> > Invalid configuration `arm64-apple-darwin21.4.0': machine
>> `arm64-apple' not recognized
>> > configure: error: /bin/sh conftools/config.sub
>> arm64-apple-darwin21.4.0 failed
>> > checking build system type...
>> > shell cmd failed: /bin/sh -ex
>> /Users/Jay/quick-start/src/rsb/rtems/build/expat-2.1.0-arm64-apple-darwin21.4.0-1/do-build
>> > Can you kindly tell me how can I fix this?
>> I can't help you fix this, but I've successfully built 6/rtems-arm tools
>> + BSP on a M1 Mac using multipass. basically:
>> 1) create the ubuntu VM: "multipass launch -n u2004 -c 6 -d 16G -m 4G
>> 20.04"
>> 2) create a shared folder: "multipass mount /opt/vm/rtems
>> u2004:/opt/vm/rtems"
>> 3) upgrade expat to 2.4.8 and gmp to 6.2.1
>> 4) before building, specify "ulimit -n 4096" on the linux VM otherwise
>> GCC will fail to link with incomprehensible error.
>> Cedric
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
