[PATCH 06/15] samples: Manually adding file headers and licenses
Ryan Long ryan.long at oarcorp.com
Thu Apr 21 14:06:06 UTC 2022
These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
 testsuites/samples/base_mp/init1.c | 35 +++++++++++++++++++++++++++++++++++
 testsuites/samples/base_mp/init2.c | 35 +++++++++++++++++++++++++++++++++++
 testsuites/samples/nsecs/system.h  | 35 +++++++++++++++++++++++++++++++++++
 3 files changed, 105 insertions(+)
diff --git a/testsuites/samples/base_mp/init1.c b/testsuites/samples/base_mp/init1.c
index cfe033d..1a7ecff 100644
--- a/testsuites/samples/base_mp/init1.c
+++ b/testsuites/samples/base_mp/init1.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @ingroup samples
+ *  @brief This is init1 for base_mp.
+ * COPYRIGHT (C) 1989-1999 On-Line Applications Research Corporation (OAR).
+ * are met:
 #define CONFIGURE_MP_NODE_NUMBER 1
 #include "initimpl.h"
diff --git a/testsuites/samples/base_mp/init2.c b/testsuites/samples/base_mp/init2.c
index 40c2c81..318250d 100644
--- a/testsuites/samples/base_mp/init2.c
+++ b/testsuites/samples/base_mp/init2.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is init2 for base_mp.
+ * are met:
 #define CONFIGURE_MP_NODE_NUMBER 2
diff --git a/testsuites/samples/nsecs/system.h b/testsuites/samples/nsecs/system.h
index 31c17a4..70579e2 100644
--- a/testsuites/samples/nsecs/system.h
+++ b/testsuites/samples/nsecs/system.h
@@ -1,3 +1,38 @@
+ *  @file
+ *  @brief This is the system header file for nsecs.
+ * COPYRIGHT (C) 1989-2007 On-Line Applications Research Corporation (OAR).
+ * are met:
 #ifndef SYSTEM_H
 #define SYSTEM_H
1.8.3.1
