[PATCH 07/15] support: Manually adding file headers and licenses
Ryan Long
ryan.long at oarcorp.com
Thu Apr 21 14:06:07 UTC 2022
This file had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
testsuites/support/include/buffer_test_io.h | 35 +++++++++++++++++++++++++++++
1 file changed, 35 insertions(+)
diff --git a/testsuites/support/include/buffer_test_io.h b/testsuites/support/include/buffer_test_io.h
index f0eae50..3ff5ca1 100644
--- a/testsuites/support/include/buffer_test_io.h
+++ b/testsuites/support/include/buffer_test_io.h
@@ -1,3 +1,38 @@
+ * @file
+ * @ingroup support
+ * @brief This is the buffer_test_io header file.
+ * COPYRIGHT (C) 1989-2011 On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* Support for running the test output through a buffer
1.8.3.1
