[PATCH 07/15] support: Manually adding file headers and licenses
Chris Johns
chrisj at rtems.org
Fri Apr 22 01:21:10 UTC 2022
Looking at the git history maybe this is both OAR and me?
The rest look fine to me
... and the empty @brief additions to the libdl files has been noted :)
On 22/4/2022 12:06 am, Ryan Long wrote:
> This file had no file header, copyright, or license. Based on git
> history, added appropriate copyright and license.
> testsuites/support/include/buffer_test_io.h | 35 +++++++++++++++++++++++++++++
> 1 file changed, 35 insertions(+)
> diff --git a/testsuites/support/include/buffer_test_io.h b/testsuites/support/include/buffer_test_io.h
> index f0eae50..3ff5ca1 100644
> --- a/testsuites/support/include/buffer_test_io.h
> +++ b/testsuites/support/include/buffer_test_io.h
> @@ -1,3 +1,38 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup support
> + * @brief This is the buffer_test_io header file.
> + * COPYRIGHT (C) 1989-2011 On-Line Applications Research Corporation (OAR).
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> * Support for running the test output through a buffer
