[PATCH v2 02/15] tmtests: Manually adding file headers and licenses
Ryan Long
ryan.long at oarcorp.com
Fri Apr 22 19:12:11 UTC 2022
These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
testsuites/tmtests/tm02/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm03/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm31/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm32/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm33/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm34/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm35/task1.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/tmtests/tm36/task1.c | 35 +++++++++++++++++++++++++++++++++++
8 files changed, 280 insertions(+)
diff --git a/testsuites/tmtests/tm02/task1.c b/testsuites/tmtests/tm02/task1.c
index c770390..9eb19d0 100644
--- a/testsuites/tmtests/tm02/task1.c
+++ b/testsuites/tmtests/tm02/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @ingroup tmtests
+ * @brief This is task1 for the tm02 test.
+ * Copyright (C) 1989-1999 On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#define TM02
#include "tm02impl.h"
diff --git a/testsuites/tmtests/tm03/task1.c b/testsuites/tmtests/tm03/task1.c
index 88c13f3..69e76ac 100644
--- a/testsuites/tmtests/tm03/task1.c
+++ b/testsuites/tmtests/tm03/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm03 test.
+ * are met:
#define TM03
#include "tm03impl.h"
diff --git a/testsuites/tmtests/tm31/task1.c b/testsuites/tmtests/tm31/task1.c
index 158c2d3..1e26085 100644
--- a/testsuites/tmtests/tm31/task1.c
+++ b/testsuites/tmtests/tm31/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm31 test.
+ * Copyright (C) 1989-2014 On-Line Applications Research Corporation (OAR).
+ * are met:
#define TM31
#include "../tm02/tm02impl.h"
diff --git a/testsuites/tmtests/tm32/task1.c b/testsuites/tmtests/tm32/task1.c
index a1787fd..49800a2 100644
--- a/testsuites/tmtests/tm32/task1.c
+++ b/testsuites/tmtests/tm32/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm32 test.
+ * are met:
#define TM32
#include "../tm03/tm03impl.h"
diff --git a/testsuites/tmtests/tm33/task1.c b/testsuites/tmtests/tm33/task1.c
index 17917e1..98793ae 100644
--- a/testsuites/tmtests/tm33/task1.c
+++ b/testsuites/tmtests/tm33/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm33 test.
+ * are met:
#define TM33
diff --git a/testsuites/tmtests/tm34/task1.c b/testsuites/tmtests/tm34/task1.c
index 2f3a888..f3c50bb 100644
--- a/testsuites/tmtests/tm34/task1.c
+++ b/testsuites/tmtests/tm34/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm34 test.
+ * are met:
#define TM34
diff --git a/testsuites/tmtests/tm35/task1.c b/testsuites/tmtests/tm35/task1.c
index 4f1ee85..1550c4b 100644
--- a/testsuites/tmtests/tm35/task1.c
+++ b/testsuites/tmtests/tm35/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm35 test.
+ * are met:
#define TM35
diff --git a/testsuites/tmtests/tm36/task1.c b/testsuites/tmtests/tm36/task1.c
index 1dcdcef..91e9124 100644
--- a/testsuites/tmtests/tm36/task1.c
+++ b/testsuites/tmtests/tm36/task1.c
@@ -1,2 +1,37 @@
+ * @file
+ * @brief This is task1 for the tm36 test.
+ * are met:
#define TM36
1.8.3.1
