[PATCH v2 03/15] sptests: Manually adding file headers and licenses
Ryan Long ryan.long at oarcorp.com
Fri Apr 22 19:12:12 UTC 2022
Theses files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
 testsuites/sptests/sp52/init.c             | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/sp53/init.c             | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/sp66/init.c             | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spcpuset01/init.c       | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spcpuset01/test.c       | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spfatal01/init.c        | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spfatal04/init.c        | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical01/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical02/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical03/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical04/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical05/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical11/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical12/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical13/init.c | 35 ++++++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical14/init.c | 35 ++++++++++++++++++++++++++++++
 16 files changed, 560 insertions(+)
diff --git a/testsuites/sptests/sp52/init.c b/testsuites/sptests/sp52/init.c
index 6cf79eb..d1c8662 100644
--- a/testsuites/sptests/sp52/init.c
+++ b/testsuites/sptests/sp52/init.c
@@ -1 +1,36 @@
+ *  @file
+ *  @ingroup sptests
+ *  @brief This is the init for sp52.
+ * Copyright (C) 1989-2009 On-Line Applications Research Corporation (OAR).
+ * are met:
 #include "sp52impl.h"
diff --git a/testsuites/sptests/sp53/init.c b/testsuites/sptests/sp53/init.c
index 3ff09bc..9a81e17 100644
--- a/testsuites/sptests/sp53/init.c
+++ b/testsuites/sptests/sp53/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for sp53.
+ * are met:
 #define USE_TIMER_SERVER
 #include "../sp52/sp52impl.h"
diff --git a/testsuites/sptests/sp66/init.c b/testsuites/sptests/sp66/init.c
index 3dd8e75..ba29515 100644
--- a/testsuites/sptests/sp66/init.c
+++ b/testsuites/sptests/sp66/init.c
@@ -1,3 +1,38 @@
+ *  @file
+ *  @brief This is the init for sp66.
+ * are met:
 #define INHERIT_CEILING
 #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
 #include "../sp65/sp65impl.h"
diff --git a/testsuites/sptests/spcpuset01/init.c b/testsuites/sptests/spcpuset01/init.c
index b13be49..4033adf 100644
--- a/testsuites/sptests/spcpuset01/init.c
+++ b/testsuites/sptests/spcpuset01/init.c
@@ -1,3 +1,38 @@
+ *  @file
+ *  @brief This is the init for spcpuset01.
+ * Copyright (C) 1989-2013 On-Line Applications Research Corporation (OAR).
+ * are met:
  *  Fully exercise CPU_SET() methods
diff --git a/testsuites/sptests/spcpuset01/test.c b/testsuites/sptests/spcpuset01/test.c
index 2e44270..b29c117 100644
--- a/testsuites/sptests/spcpuset01/test.c
+++ b/testsuites/sptests/spcpuset01/test.c
@@ -1,3 +1,38 @@
+ *  @file
+ *  @brief This is the test for spcpuset01.
+ * are met:
 #ifdef HAVE_CONFIG_H
 #include "config.h"
 #endif
diff --git a/testsuites/sptests/spfatal01/init.c b/testsuites/sptests/spfatal01/init.c
index 4f0c008..2682200 100644
--- a/testsuites/sptests/spfatal01/init.c
+++ b/testsuites/sptests/spfatal01/init.c
@@ -1,3 +1,38 @@
+ *  @file
+ *  @brief This is the init for spfatal01.
+ * are met:
 #include "config.h"
 #endif
diff --git a/testsuites/sptests/spfatal04/init.c b/testsuites/sptests/spfatal04/init.c
index 89a4be8..24d5d10 100644
--- a/testsuites/sptests/spfatal04/init.c
+++ b/testsuites/sptests/spfatal04/init.c
@@ -1,3 +1,38 @@
+ *  @file
+ *  @brief This is the init for spfatal04.
+ * are met:
 #include "config.h"
 #endif
diff --git a/testsuites/sptests/spintrcritical01/init.c b/testsuites/sptests/spintrcritical01/init.c
index 0df5160..d3dc015 100644
--- a/testsuites/sptests/spintrcritical01/init.c
+++ b/testsuites/sptests/spintrcritical01/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical01.
+ * are met:
 #define FIFO_NO_TIMEOUT
 #include "spintrcritical01impl.h"
diff --git a/testsuites/sptests/spintrcritical02/init.c b/testsuites/sptests/spintrcritical02/init.c
index 2559eea..864e202 100644
--- a/testsuites/sptests/spintrcritical02/init.c
+++ b/testsuites/sptests/spintrcritical02/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical02.
+ * are met:
 #define FIFO_WITH_TIMEOUT
 #include "../spintrcritical01/spintrcritical01impl.h"
diff --git a/testsuites/sptests/spintrcritical03/init.c b/testsuites/sptests/spintrcritical03/init.c
index 46e8bbb..8b50b29 100644
--- a/testsuites/sptests/spintrcritical03/init.c
+++ b/testsuites/sptests/spintrcritical03/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical03.
+ * are met:
 #define PRIORITY_NO_TIMEOUT
diff --git a/testsuites/sptests/spintrcritical04/init.c b/testsuites/sptests/spintrcritical04/init.c
index 16d0752..eab2f8c 100644
--- a/testsuites/sptests/spintrcritical04/init.c
+++ b/testsuites/sptests/spintrcritical04/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical04.
+ * are met:
 #define PRIORITY_WITH_TIMEOUT
diff --git a/testsuites/sptests/spintrcritical05/init.c b/testsuites/sptests/spintrcritical05/init.c
index d77a683..9894482 100644
--- a/testsuites/sptests/spintrcritical05/init.c
+++ b/testsuites/sptests/spintrcritical05/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical05.
+ * are met:
 #define PRIORITY_NO_TIMEOUT_REVERSE
diff --git a/testsuites/sptests/spintrcritical11/init.c b/testsuites/sptests/spintrcritical11/init.c
index 126a76d..e55887b 100644
--- a/testsuites/sptests/spintrcritical11/init.c
+++ b/testsuites/sptests/spintrcritical11/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical11.
+ * are met:
 #define EVENT_ANY
 #include "spintrcritical11impl.h"
diff --git a/testsuites/sptests/spintrcritical12/init.c b/testsuites/sptests/spintrcritical12/init.c
index 243acfd..259ae4b 100644
--- a/testsuites/sptests/spintrcritical12/init.c
+++ b/testsuites/sptests/spintrcritical12/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical12.
+ * are met:
 #define EVENT_ALL
 #include "../spintrcritical11/spintrcritical11impl.h"
diff --git a/testsuites/sptests/spintrcritical13/init.c b/testsuites/sptests/spintrcritical13/init.c
index 86d9cc4..23a545d 100644
--- a/testsuites/sptests/spintrcritical13/init.c
+++ b/testsuites/sptests/spintrcritical13/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical13.
+ * are met:
 #define FIRE_AFTER
 #include "spintrcritical13impl.h"
diff --git a/testsuites/sptests/spintrcritical14/init.c b/testsuites/sptests/spintrcritical14/init.c
index b9c972c..b52024a 100644
--- a/testsuites/sptests/spintrcritical14/init.c
+++ b/testsuites/sptests/spintrcritical14/init.c
@@ -1,2 +1,37 @@
+ *  @file
+ *  @brief This is the init for spintrcritical14.
+ * are met:
 #define SERVER_FIRE_AFTER
 #include "../spintrcritical13/spintrcritical13impl.h"
1.8.3.1
