[PATCH 2/2] gdb: Split python's version into major/minor and check for embed option
Mon Apr 25 22:04:47 UTC 2022
On 26/4/2022 4:01 am, Frank Kühndel wrote:
> I tested your two patches for ARM on top of
> 990e3f05e62cf48117f6de8346e9ea8a8d9b1ba3 (Git master
> rtems-source-builder, RTEMS 6) on the following OS:
> * openSUSE Leap 15.3 Python 2.7.18
> * openSUSE Leap 15.3 Python 3.6.15
> * Ubuntu 22.04 LTS Python 3.10.4
> * AlmaLinux 8.5 (Arctic Sphynx) Python 3.6.8
> * Debian GNU/Linux 11 (bullseye) Python 3.9.2
> * Fedora Linux 35 (Container Image) Python 3.10.4
> Everything worked fine.
Thank you for the testing, it is appreciated.
> But inspecting the code, I wonder about this line:
>     %if %{gdb-python-ver-major} <= 3 && %{gdb-python-ver-minor} < 8
> What if the Python version would be 2.9? (No, I do not I believe that I
> will ever see Python 2.8 or 2.9.)
Oh yes nice catch. I suppose this is needed:
%if %{gdb-python-ver-major} < 3 || \
    %{gdb-python-ver-major} == 3 && %{gdb-python-ver-minor} < 8
I will give this a test and if it looks ok I will push the patch with this change.
Thanks
