[PATCH 2/2] gdb: Split python's version into major/minor and check for embed option
Tue Apr 26 00:34:05 UTC 2022
On 26/4/2022 8:04 am, Chris Johns wrote:
> On 26/4/2022 4:01 am, Frank Kühndel wrote:
>> I tested your two patches for ARM on top of
>> 990e3f05e62cf48117f6de8346e9ea8a8d9b1ba3 (Git master
>> rtems-source-builder, RTEMS 6) on the following OS:
>> * openSUSE Leap 15.3 Python 2.7.18
>> * openSUSE Leap 15.3 Python 3.6.15
>> * Ubuntu 22.04 LTS Python 3.10.4
>> * AlmaLinux 8.5 (Arctic Sphynx) Python 3.6.8
>> * Debian GNU/Linux 11 (bullseye) Python 3.9.2
>> * Fedora Linux 35 (Container Image) Python 3.10.4
>> Everything worked fine.
> Thank you for the testing, it is appreciated.
>> But inspecting the code, I wonder about this line:
>>     %if %{gdb-python-ver-major} <= 3 && %{gdb-python-ver-minor} < 8
>> What if the Python version would be 2.9? (No, I do not I believe that I
>> will ever see Python 2.8 or 2.9.)
> Oh yes nice catch. I suppose this is needed:
> %if %{gdb-python-ver-major} < 3 || \
>     %{gdb-python-ver-major} == 3 && %{gdb-python-ver-minor} < 8
> I will give this a test and if it looks ok I will push the patch with this change.
I ended up posting v2 because I needed to update the compound if statement
logic. There is no precedence ability, just left to right and the logic short
circuits if true when an OR is seen.
