Building RTEMS 6 toolchain on a Mac
Wed Apr 27 05:49:45 UTC 2022
On 27.04.22 07:46, Karel Gardas wrote:
> On 4/27/22 06:46, Sebastian Huber wrote:
>> On 26.04.22 22:57, Karel Gardas wrote:
>>> On 4/25/22 10:10, Sebastian Huber wrote:
>>>> Hello Heinz,
>>>> you are probably one of the first persons building GCC 12 on this
>>>> platform. I checked in a change which could fix the problem.
>>> Not sure if this is related, but after this hacking I'm no longer
>>> able to build neither 6/rtems-arm not 6/rtems-x86_64.
>> I changed the mpfr version from 3.1.4 to 4.1.0. This is the latest
>> mpfr release and used by the GCC contrib/download_prerequisites script
>> currently. If this version doesn't build on macOS, then it would be
>> good to submit a bug report to mpfr.
> Right. My build with:
> commit 6cf31074fa51c44ec563478b026a3778f5f214be
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:   Fri Apr 22 08:45:21 2022 +0200
>      6/7: Update GCC prerequisites for GCC 10 and 12
> reverted went fine on catalina.
Could you please test with the latest RSB. I changed it to use mpfr-3.1.6.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
