Building RTEMS 6 toolchain on a Mac
Heinz Junkes junkes at fhi-berlin.mpg.de
Thu Apr 28 09:15:06 UTC 2022
Hallo Sebastian,
maybe too late, but this is the result of RTEMS 7 rsb on my Mac:
 Command Line: ../source-builder/sb-set-builder --jobs=4 --prefix=/Users/heinz/VE/ARM_WORK/rtems/7 7/rtems-arm
 Python: 3.8.5 (default, Sep  4 2020, 02:22:02) [Clang 10.0.0 ]
 https://github.com/RTEMS/rtems-source-builder.git/origin/a53d2c94322ed4fe261ba0c99bfb66a6cbd1def1
  CXX    unittests/tui-selftests.o
In file included from ../../sourceware-mirror-binutils-gdb-36b1241/gdb/unittests/string_view-selftests.c:34:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/fstream:579:17: warning: The symbol ::fdopen refers to the system function. Use gnulib::fdopen instead. [-Wuser-defined-warnings]
      __file_ = fdopen(__fd, __mdstr);
../gnulib/import/stdio.h:826:1: note: from 'diagnose_if' attribute on 'fdopen':
_GL_CXXALIASWARN (fdopen);
../gnulib/import/stdio.h:461:4: note: expanded from macro '_GL_CXXALIASWARN'
   _GL_CXXALIASWARN_1 (func, GNULIB_NAMESPACE)
../gnulib/import/stdio.h:463:4: note: expanded from macro '_GL_CXXALIASWARN_1'
   _GL_CXXALIASWARN_2 (func, namespace)
../gnulib/import/stdio.h:468:5: note: expanded from macro '_GL_CXXALIASWARN_2'
    _GL_WARN_ON_USE (func, \
../gnulib/import/stdio.h:632:19: note: expanded from macro '_GL_WARN_ON_USE'
  __attribute__ ((__diagnose_if__ (1, message, "warning")))
  CXX    unittests/ui-file-selftests.o
  CXX    unittests/unique_xmalloc_ptr_char.o
  CXX    unittests/unpack-selftests.o
1 warning generated.
  CXX    unittests/utils-selftests.o
  CXX    unittests/vec-utils-selftests.o
  CXX    unittests/xml-utils-selftests.o
  CXX    user-regs.o
  CXX    utils.o
  CXX    valarith.o
  CXX    valops.o
  CXX    valprint.o
  CXX    value.o
  CXX    varobj.o
  GEN    stamp-version
  GEN    xml-builtin.c
  CXX    xml-support.o
  CXX    xml-syscall.o
  CXX    xml-tdesc.o
  GEN    init.c
  CXX    gdb.o
  CXX    aarch32-tdep.o
  CXX    ada-exp.o
  CXX    ada-lang.o
  CXX    ada-tasks.o
  CXX    ada-typeprint.o
  CXX    ada-valprint.o
  CXX    ada-varobj.o
  CXX    addrmap.o
  CXX    agent.o
  CXX    alloc.o
  CXX    annotate.o
  CXX    arch-utils.o
  CXX    arch/aarch32.o
  CXX    arch/arm-get-next-pcs.o
  CXX    arch/arm.o
  CXX    arm-none-tdep.o
  CXX    arm-pikeos-tdep.o
  CXX    arm-tdep.o
  CXX    async-event.o
  CXX    auto-load.o
  CXX    auxv.o
  CXX    ax-gdb.o
  CXX    ax-general.o
  CXX    bcache.o
  CXX    bfd-target.o
  CXX    block.o
  CXX    blockframe.o
  CXX    break-catch-exec.o
  CXX    break-catch-fork.o
  CXX    break-catch-sig.o
  CXX    break-catch-syscall.o
  CXX    break-catch-throw.o
  CXX    breakpoint.o
  CXX    bt-utils.o
  CXX    btrace.o
  CXX    build-id.o
  CXX    buildsym-legacy.o
  CXX    buildsym.o
  CXX    c-exp.o
  CXX    c-lang.o
  CXX    c-typeprint.o
  CXX    c-valprint.o
  CXX    c-varobj.o
  CXX    charset.o
  CXX    cli-out.o
  CXX    cli/cli-cmds.o
  CXX    cli/cli-decode.o
  CXX    cli/cli-dump.o
  CXX    cli/cli-interp.o
  CXX    cli/cli-logging.o
  CXX    cli/cli-option.o
  CXX    cli/cli-script.o
  CXX    cli/cli-setshow.o
  CXX    cli/cli-style.o
  CXX    cli/cli-utils.o
  CXX    coff-pe-read.o
  CXX    coffread.o
  CXX    compile/compile-c-support.o
  CXX    compile/compile-c-symbols.o
  CXX    compile/compile-c-types.o
  CXX    compile/compile-cplus-symbols.o
  CXX    compile/compile-cplus-types.o
  CXX    compile/compile-loc2c.o
  CXX    compile/compile-object-load.o
  CXX    compile/compile-object-run.o
  CXX    compile/compile.o
  CXX    complaints.o
  CXX    completer.o
  CXX    copying.o
  CXX    corefile.o
  CXX    corelow.o
  CXX    cp-abi.o
  CXX    cp-name-parser.o
  CXX    cp-namespace.o
  CXX    cp-support.o
  CXX    cp-valprint.o
  CXX    ctfread.o
  CXX    d-exp.o
  CXX    f-exp.o
  CXX    m2-exp.o
  CXX    go-exp.o
In file included from ../../sourceware-mirror-binutils-gdb-36b1241/gdb/m2-exp.y:42:
In file included from ../../sourceware-mirror-binutils-gdb-36b1241/gdb/language.h:26:
In file included from ../../sourceware-mirror-binutils-gdb-36b1241/gdb/symtab.h:39:
../../sourceware-mirror-binutils-gdb-36b1241/gdb/split-name.h:34:3: error: expected identifier
  DOT,
m2-exp.c:163:13: note: expanded from macro 'DOT'
#define DOT 302
../../sourceware-mirror-binutils-gdb-36b1241/gdb/symtab.h:306:23: error: expected unqualified-id
        style = split_style::DOT;
#define DOT 302
2 errors generated.
make[2]: *** [m2-exp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [all-gdb] Error 2
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex  /Users/heinz/VE/rsb/rtems/build/arm-rtems7-gdb-36b1241-x86_64-apple-darwin21.4.0-1/do-build
error: building arm-rtems7-gdb-36b1241-x86_64-apple-darwin21.4.0-1(base)
Gruss Heinz
> On 27. Apr 2022, at 07:49, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 27.04.22 07:46, Karel Gardas wrote:
>> On 4/27/22 06:46, Sebastian Huber wrote:
>>> On 26.04.22 22:57, Karel Gardas wrote:
>>>> On 4/25/22 10:10, Sebastian Huber wrote:
>>>>> Hello Heinz,
>>>>> you are probably one of the first persons building GCC 12 on this platform. I checked in a change which could fix the problem.
>>>> Not sure if this is related, but after this hacking I'm no longer able to build neither 6/rtems-arm not 6/rtems-x86_64.
>>> I changed the mpfr version from 3.1.4 to 4.1.0. This is the latest mpfr release and used by the GCC contrib/download_prerequisites script currently. If this version doesn't build on macOS, then it would be good to submit a bug report to mpfr.
>> Right. My build with:
>> commit 6cf31074fa51c44ec563478b026a3778f5f214be
>> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date:   Fri Apr 22 08:45:21 2022 +0200
>>     6/7: Update GCC prerequisites for GCC 10 and 12
>> reverted went fine on catalina.
> Could you please test with the latest RSB. I changed it to use mpfr-3.1.6.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
